Question about Sewing Machines
Tension in the bottom thread is loose, We've tighten the bottom bobin and we had change the tension on dial. What else can we do?
  • Paul Howell
    Paul Howell May 11, 2010
    What make and model do you have and please describe what the stitch looks like.
  • Paul Howell
    Which brand do you have and what is the model?
    Problem Solver:
  • 9 Answers
Are you turning the little screw in the piece that holds the bobbin? That is how you adjust the tension for the bobbin
Posted on Jun 30, 2009
I have multiple threads coming out the bobin space and making a mess of the back side.
called bird nesting and is a result of too loose a needle thread tension
if you use an automatic tensioner or using the numbers
and you still have a problem, the correct tension is a resistance to you pulling the thread prior to threading the needle
Feb 08, 2018 | Sewing Machines
I have an Eden Rose 250M, for several months no. Suddenly the thread tension is not working properly. I've tried all suggestions in the manul but still the needle thread is very loose. The b
The tension control has a screw on the inside wall of the sewing machine. It probably came loose and will not allow the tension to pull taught. If you take the top off you can look down to where the tension knob is coming from. There is a screw that you can tighten while you push forward on the tension knob while set to zero. Keep the presser foot up.
Feb 01, 2015 | Husqvarna Sewing Machines
Brother vx 860
First, make sure the upper thread is threaded correctly. I don't have this model but see if this helps. If the bobbin thread is visible from the right side of fabric, the upper thread is too tight. If the upper thread is visible from the wrong side of the fabric, the tension is too loose. Turn the thread tension dial to the right to tighten and left to loosen upper thread. Good luck. Loverly Lou
Jul 17, 2014 | Brother Sewing Machines
What is solution of lose stitching from bobbin
Hi: Always remember that it is impossible for bobbin thread to loop as it simply spools off bobbin, the problem will always be with the top tension. Make sure you top tension dial is centered (half of the numbers on the dial). Re thread top of machine with presser foot UP, thread to needle, pull thread (should be loose), then lower presser foot and thread should tighten up, if it doesn't that means lint in between the tension discs, threaded wrong or tension to loose. If it tightens up then should sew properly if you haven't changes adjustments on machine. Have repaired over 20,000 machines over the years and 95% of the time the problem always starts with improper threading.
Nov 30, 2013 | Sewing Machines
How to thread the bobbin on a brother vx-810
The sewing on the bottom is loose because you don't have enough tension on the TOP thread. First, make absolutely sure you are threading the machine correctly. Next, while using 2 different colours of thread, tighten the top tension dial one number at a time and then checking the stitching, continue tightening the top tension until the sewing is even on the top and bottom of your cloth.
Apr 02, 2013 | Brother Sewing Machines
How do I tighten the tension. My bottom thread is
To increase the tension,turn the dial one number up until the thread length/tension is correct for your needs. You may download the manual free and info on adjustments is on page 28. Happy Sewing!       http://www.sewingmachinesplus.com/media/products/singer/2932/Manual_2932.pdf
              # 0             0
Jul 24, 2011 | Singer 2932 Mechanical Sewing Machine
I am trying to sew a boat canvas top with sunbrella canvas. my top stitch is beautiful but the bottom stitch is loose and messy. Is this just a tension adjustment and if so what should I be adjusting?
Try adjusting the top tension dial to tighten up the loose stitching on the underside. Generally if you have loose threads underneath, its the top tension and visa versa.
However, if you are using a thread heavier than normal sewing thread through the needle and bobbin (which you probably need for this canvas) then the machine may struggle. I've sewed vinyl seat covers and gave up with my domestic machine and purchased a second hand industrial Singer machine 20U to cope with this heavier weight textile. Generally for anything heavier than upholstery fabric a domestic machine may not be strong enough.
May 04, 2011 | Husqvarna Sewing Machines
How do I tighten the tension on the bobin thread I am quitiing with invisible thread on the top and dark blue on the bottom, the bobin thread shows. I don't want that
you can either increase the bottom tension or reduce the top tension .. you will notice a little screw on the bobin case ... that screw adjusts the force on a small flat spring which provides the bottom tension (the thread goes under the spring when properly threaded) .. .. tighten that screw a little to increase bottom tension .. you can pull thread thru the bobin case to get a feel for how much tension you have ... you dont have to turn the screw very far to make a significant difference .. try just 1/4 of a turn at a time .. remember where it was originally set so you can put it back when you are finished with your present project .. the greater the bottom tension the less bobin thread will show at the top ... if you get the tension too high then you might see some puckering as you sew ..
Jan 03, 2010 | Sewing Machines
BOTTOM STITCH IS ALWAYS LOOSE
If the top stitch is loose, then you need to tighten the bobbin tension: if the bottom stitch is loose, tighten the top tension. Hope this helps. It could also be the size needle and thread you are using for a particular fabric. Different fabrics require different notions.
Mar 13, 2008 | Sewing Machines
Sewing Machines Logo
119 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Are you a Sewing Machine Expert? Answer questions, earn points and help others
