Question about Umax PowerLook 1100 Flatbed Scanner
Ihave a Umax Power Look 1100 with 2
I have an older Umax Power Look 1100 with 2 FireWire/11394 6-pin connectors. Will I just need a FireWire 6-pin to 9-pin adabtor cable to use it with my new iMac? Thank you.
  • 221 Answers
Hello, yes you will just need a firewire 400 (6 pin) to 800 (9 pin) cable as the new iMac no longer supports the 6 pin connector.
Posted on Jun 27, 2009
Firewire port usff 7010
If you're asking if a Dell OptiPlex 7010 USFF will support Firewire the answer is No...Unless you purchase and install a Firewire card
The OptiPlex 7010 USFF has the following external connections:
  • Front Panel: one microphone connector and one headphone connector
  • Back Panel: one line-out connector and one line-in/microphone connector
  • Network Adapter: one RJ45 connector
  • Serial: one 9-pin connector; 16550 C compatible
  • USB 3.0: Back Panel - 2
  • Video: 15-pin VGA connector
  • 20-pin DisplayPort connectors - 2
I don't recommend any USB to Firewire convertors but if you can find a Firewire Convertor PCI Express Card you can try installing it but remember the USFF has only one Mini PCI Express 52-pin connector, I've highlighted a possible product. It allows for Firewire 800 speeds. The included optional internal Molex power connection is only required if your Firewire device doesn't have its own power adapter
May 07, 2014 | Dell Optiplex 7010 500gb Usff Ultra Small...
Firewire usff 7010
May 07, 2014 | Dell KIT OPTI 7010 USFF I5-3470 3.2G 2GB...
Dont seem to have enough front panel pins for all my case wires
Hi Greeneyedbj,
What kind of I/O connectors are you looking for *********** board sir?
The image above has the following for your I/O connectors.
1. Three usb headers up to 6 additional devices, most casing can support 2-4 pins. 2. Front Audio Connector. 3. Front Panel Connector. Power Sw, Reset Sw, Powed Led, HDD Led
Branded casing has the following I/O connectors.
1. Esata 2. Firewire (Dont use the USB headers, firewire use a different pin-layout) 3. Chassis Intrusion Alarm Header.
Hopefully this information helps.
You can ask for more help.
Thank you for using FixYa.
Sep 23, 2011 | Foxconn A74ML-K Motherboard AMD Socket...
Hello, My laptop does not have a firewire port. What do I have to do to transfer video to my laptop from my GL2?
What brand and model is your laptop?
Since we don't know the laptop model I have to cover a little more info here.
Most laptops have at least 1 expansion ports available on the side and you can use that to add additional ports or features if needed such as Firewire, USB2.0, or Ethernet, etc
Older laptops came with 1 or 2 full size PCMCIA ports. Those are rarely used anymore.
Newer laptops usually have an ExpressCard port.
These newer cards come with either 54 or 34 pins so you'd need to get the right one for your laptop.
For example, view the main ExpressCard info here
http://en.wikipedia.org/wiki/ExpressCard
Be aware that Firewire is officially known as the "IEEE1394" protocol. So some sites may refer to it with that name and it's the same thing. Apple calls it Firewire and Sony calls it iLink.
There are several different pin configurations for firewire.
Original 400Mbps speed Firewire from 1995 has a mini 4 pin or a full size 6 pin cable.
Newer Firewire 800 has 800Mbps speed and is called 1394b.
That has it's own cable connector as well and is not very common. It's much faster than USB (even Firewire 400 is ) but it didn't get used a lot.
The firewire connector s are visible here:
http://en.wikipedia.org/wiki/IEEE_1394_interface
The Canon GL2 uses the original 400Mbps 1394 protocol but the connector might be proprietary since it appears to have 5 pins.
It's visible here from the user manual.
There are 6-pin sockets and smaller (non-powered) 4 pin sockets and they are both still "firewire" but the small one has less options since it has no power connections with it. So the small connections can send data but can't run a portable hard drive or anything that needs power.
The small connectors are used for laptop ports and camcorders while full size desktops usually have the full size 6 pin ports. So to connect the 2 they make adapter cables with one of each type on each end.
Such as this one:
http://www.amazon.com/Phoenix-IEEE-1394-4-Pin-FireWire-Meters/dp/B000165AS0
That fits most applications but I think the Canon cable is proprietary, so hopefully you have the original cable.
So,
You probably need a laptop 1393 DV expansion card, DV editing software and the right cable. The socket on the GL2 doesn't look like a typical IEEE connector in the user manual so that may be Canon specific. If you still have the original cable that came with it then you're all set.
You can find a laptop expansion card online such as doing a search on Amazon.com with the words expresscard + 1394 and you will see many ExpressCard adapters to pick from.
Get the laptop 1394 expansion card that matches your Canon Cable and that can plug into your laptop on the other end (choose the right 54 or 34 pin type) that matches your laptop.
Jul 25, 2010 | Canon GL2 Mini DV Digital Camcorder
What external power does SmartDisk FireLite FWFL120-N take?
Many USB power supplies will have the right plug. I picked one up by buying a cheap USB hub, What you want to look for (most likely on the bottom of the power supply) is VOLTAGE Output: 5.0 VDC, POWER Output: 1.0 amp or (1000ma) and the center hole is the positive side. I have even seen some BluTooth earpiece charges that supply what you need.
Hope that this will help.
AAirwolf
Jul 05, 2010 | SmartDisk FireLite FWFL120 120 GB FireWire...
Need power supply for UMAX Astra e5420 acanner
From a quick search I found this power supply, from Umax.com,
http://umax.com/scanners/index.jsp?cate=Scanners%3A+Accessories&skunum=68300055-0000
Jun 03, 2009 | Umax Astra 3450 Flatbed Scanner
1394 Header pin-out
http://ritmotech.com.au/onlineshop/product_info.php?cPath=21_25&products_id=57&osCsid=aeefcbb79e7dab18e3439d5d6c64cb0f
Ritmo PCI to USB + 1394 (CC-C15)
PPA USB2.0 + 1394 Combo PCI Card Model 1509
http://www.ppa-usa.com/products/usb/usb_pci/1578.htm
click on get pinouts for pdf file of card
Pinouts:
USB board is slikscreened with numbers but for reference
pin 1 ground is at top edge of board
and pin 5 plus 5v is towards gold connector edge
1. case Gnd (thick black)
2. D- (green)
3. D+ (white)
4. no connection
5. +5v (red)
Firewire: (8 pin header on board)
this board uses the 4pin firewire connection standard
NOT THE 6/9 PIN!!!! you only need to connect 4 pins
and if you have a thick case ground cable you can use it
pin 7 is towards bracket towards top edge of card
pin 8 is towards bracked towards gold edge connector
card header
5 TPB- Orange
6 TPB+ Blue
7 TPA- Red
8 TPB+ Green
3 Case Gnd Thick Black (not thin black) if you have one
(white 30vdc) and (thin black, signal Gnd)
wires are not used
pins 1 and 2 are also unused for firewire connections
please note that this card has +12v on pin 2 instead of the
30v dc that a normal firewire 6 pin connection has
Sep 01, 2008 | Televison & Video
Canon MV800 - FireWire connection
firewire is also called 1394 or dv port-card can always be added to older computer to support-cables are 4 pin to 4 pin or 4-6 pin-cam is always 4 pin -mac and most towers 6 pin-laptops are 4 pin-look for a port that looks like usb but has a trapezoid shape end
May 22, 2008 | Canon MV800i Mini DV Digital Camcorder
FireWire i.Link which cable?
teedoff1980,
You can buy the FireWire kit at your local electronics store or department. Some kits come with a FireWire cable with USB connectors, as well as "ends" for that cable that come in both 4 and 6-pin configurations. Make sure you ask the store rep and read the package to ensure you have the right ends. You can also buy cables that are already appropriately "ended".
Most cables are 6 pin and connect to the 4 pin port (with a 4 pin end)
Hope this helps :)
Jan 06, 2008 | Sony Handycam DCR-HC21 Mini DV Digital...
Open Questions:
Umax PowerLook 1100 Flatbed Scanner Logo
235 people viewed this question
Top Umax Office Equipment & Supplies Experts
Ricky Ostrom
Ricky Ostrom
Are you an Umax Office Equipment and Supply Expert? Answer questions, earn points and help others
