Question about Ryobi Garden
All the fuel lines are damaged, trying to figure out how to replace them correctly? On ryobi 725r model
  • 40 Answers
SOURCE: Ryobi 725R fuel filter; How is it re-mounted?
after you insert the fuel line through the tank and install the filter. take some WD-40 and spray the hose. now from the bottom of tank the pull on the hose. and just keep pulling on it till it comes through all the way. then slide the little white washer back over the hose and seat in place. this should do it for you. they are a royal pain in the **** to work on. numerous brands of string trimmers have these top mount tanks. a new tank with hoses already assembled is about 45 bucks with shipping. much cheaper to fix it yourself.
Posted on Mar 11, 2009
  • 57 Answers
SOURCE: I need to know how the fuel lines should be
The line from the fuel tank that has the filter on it goes directly to the carburetor below the primer bulb. One line comes from the carburetor to the primer bulb. The other line goes from the primer bulb to the fuel tank. Primer bulb can be pressed to determine which side is pulling fuel (line from carb) and which is pushing (line to fuel tank).
Posted on May 15, 2009
mitchjl_1692
  • 3 Answers
SOURCE: Need routing of fuel lines on Ryobi string trimmer Model 725R.
The larger fuel line goes from fuel filter to carbuerator.The smaller line is the return line from the purge bulb tofuel tank. mitchjl_1692
Posted on May 27, 2009
SOURCE: RYOBI 725R FUEL LINE DIAGRAM
I just rebuilt my 725r. I don't have a diagram but I can explain it. There are two lines coming out of the fuel tank. The line closest to the rear is the fuel feed and has the in-tank filter (these are available for replacement). This line goes through the lower case hole of the air filter housing and attaches to the bottom of the carburetor. The line toward the front of the tank attaches to the longer/lower fitting the primer bulb and is the return. The line coming off the shorter/upper fitting of the primer bulb goes through the upper hole of the air filter housing and attaches to the top of the carburetor.
FYI also, the forward carburetor screw is the low idle adjustment & the rear, the high-speed mixture. The original oil mixture spec called for 32:1
Posted on Jun 27, 2009
canbruce75
  • 1776 Answers
SOURCE: Fuel line routing for RYOBI Models 705r and 725r
Typical fuel line routing is:
One line (the one with the fuel filter in the end of it) comes out of the fuel tank and goes to the bottom fitting on the carburator. The second line comes out of the tank and goes to the bottom fitting on the primer bulb. The third section of line goes from the top fitting on primer bulb to top fitting on the carburator. Hope this helped and best wishes.
Posted on Sep 08, 2009
Replacing head bearing
Here is what a blow out drawing looks like but since you didn't give me a model number...:
http://www.searspartsdirect.com/partsdirect/part-model/Ryobi-Parts/Grass-line-trimmer-Parts/Model-725R/0909/1503820
Jan 13, 2013 | Ryobi Garden
Have a Ryobi weed wacker 725r 31cc click link Trimmer Plus. No more line-can't figure out how to remove bottom to replace the line or what kind of line to replace with. Deceased husband lost directions...
i also have a ryobi weed wacker. if it is the same. you don"t have to remove the button. line up the 2 arrows one on wheel with bumpy edges and one by the button. you should see 2 holes feed a 2-3 foot piece of line into the hole the line comes out of for cutting and it should come out of a curved holw on the bottom by the button .tuck the end into a small round hole . pull line tight (tug on the section that you cut with). wind the string by turn the ring around the button. til desired length. if this doesn't work. google you model # and look for a manual (manual for ryobi weed wacker model # ------------.)
Jun 09, 2010 | Garden
Ryobi 725r leaks gas from air filter and will cut out after starting up
This is a problem with most ryobi tools. From what i've read over time the gas lines shrink and need to be replaced. You'll need to replace both the lines coming from the carb to engine and the one connecting to your primer bulb. I hear there is a kit that contains both the primer bulb and fuel lines for this exact problem.
Apr 21, 2010 | Ryobi Garden
Putting fuel line on right on ryobi 725r 15'' 31cc weedeater
One line (the one with the fuel filter in the end of it) comes out of the fuel tank2.gif and goes to the bottom fitting on the carburator. The second line comes out of the tank and goes to the bottom fitting on the primer bulb. The third section of line goes from the top fitting on primer bulb to top fitting on the carburator. Hope this helped and best wishes.
Sep 08, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
How to remove drum connector off ryobi weedeater
I believe there are four phillips headed bolts around the outside edge of the housing
Jul 23, 2009 | Ryobi Garden
May 27, 2009 | Ryobi 15" Electric Factory Reconditioned...
Ryobi 2 cycle gas trimmer 705r/725r
The gas nipple that come out I have...whats goes in the other hole?
Aug 28, 2008 | Ryobi Garden
Ryobi 725r 31cc
Ryobi is Japanese for "Piece of ****" My suggestion is to throw it out!
My 767r has had fuel line and carb trouble from day one. I'll never buy another Ryobi or Craftsman tool again.
Jun 13, 2008 | Ryobi 15" Electric Factory Reconditioned...
Garden Logo
141 people viewed this question
Top Ryobi Garden Experts
Jim Parker
Jim Parker
Rexter1
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
