Question about Pantech Matrix Cell Phone
I can't hear my ringtones unless I set them and back out and push the volume button. I also can't hear any music no noise unless it rings with someone calls
I had the same problem. The only way I was able to fix it was to do a "master reset." Go to menu, settings, reset, enter password, then master reset. Should start working again - you will just need to change your settings back to the way you want them.
Posted on Aug 25, 2009
I dont hear the ring when there is an incoming call despite the settings on volume is correct-It only vibrates.The alarm,Music,Video games,other media are ok-what could be the reason?
Please do check the Phone Ringtone
If the ringtone file is missing this may happen
Try change another ringtone (This option may be available under volume settings)
Jun 10, 2015 | Sony Xperia C1904 Android Smart Phone with...
My iPhone 5c won't ring
Does the phone plays music without any problem? If you play music to hear it on the loud speaker, and there is no sound, then you probably have a hardware failure, (bad speaker). But if you get to listen to the music, then try this next steps to see if it can be fix.
  • From the iPhone's home screen, tap the Settings app.
  • In Settings, tap Sounds in the third group of options.
  • In Sounds, swipe down to the Sounds and Vibration Patterns section. In that section, look forRingtone. That displays what you have set as your current iPhone ringtone. Tap it to change that.
  • This menu shows you the list of all the ringtones available on your iPhone.
    To get new ringtones, tap the Store button in the top right corner. This will take you to the ringtone section of the iTunes Store where you can stock up on new ringtones.
  • If you choose not to buy new ringtones, but instead use the ones loaded on your phone, the first set of options in the Ringtones section are ones that you bought from the iTunes Store or created using another app and have synced to your iPhone. The ones below the divider came pre-installed on the iPhone.
    Alert Tones, farther down the screen, aren't ringtones exactly. They're alert sounds normally used for alarms and other notifications, but they can be used as ringtones, too.
  • When you tap on a ringtone, it will play so you can preview it and decide if it's what you want. When you've chosen the ringtone you want to use as your default, make sure it has the checkmark next to it. Then tap the Sounds button in the top left corner or click the Home button to go back to the home screen. Your choice is saved automatically.
  • Now, whenever a call comes in, the ringtone you just selected will play (unless you've assigned individual ringtones to callers, that is. If you have, those ringtones take precedence). Just remember to listen for that sound, and not a ringing phone, so you don't miss any calls.
  • Mar 13, 2014 | Cell Phones
    Sound not working when ringing
    It could be that your volume is set to silent. The volume buttons should be on the left or right side just push the top part of the button you should hear your phone ring or beep or make some kind of noise when u do this.
    Jan 19, 2013 | Cell Phones
    SET A RINGTONE & PLAY MUSIC
    u need to change the phone sound ic or change the phone speaker.
    Feb 13, 2012 | Samsung B3310 Cell Phone
    Have a new v3c phone that will only vibrate..no ring tones and cannot get it to ring
    A couple of things could b set wrong. First, make sure you're volume is turned up. Flip phone open and push the top button on left to raise the volume. Second, open phone, go to menu, cursor to settings, sounds, call ringtone, single tone. Now cursor down thru the selections to pick a ringtone. Make sure the "no ring" selection is not selected. (The current selection will have a check mark on the right side.) Select the tone you want and push the center button to save it. You can then select all your other ring tones, such as message alerts the same way.
    Sep 15, 2009 | Motorola Mobility RAZR V3c Cellular Phone
    My headset is grounded
    pushing the jack hard may result in some connections pushed way off, and there is no contact to the speaker. Please see the nearest technician.
    Jun 12, 2009 | Cell Phones
    Raperi9@hotmail.com
    hi
    my new shine phone is on the highest settings for the volume but its very frustrating as i cannot hear it ring unless i see it vibrate and put it to my ear only then can i hear it
    i would be very grateful if you can help me
    kind regards
    nicky
    Jun 01, 2008 | LG Shine KE970 Cellular Phone
    No sound at all on my phone (not on silent)
    I've had my phone for close on 2 yrs now so I know it quite well. Simple (and obvious) way to test if the phone rings is to ring it from a land line and listen out for the ring tone. Maybe you are not clearly hearing the ring tone from all the other noise around you- try some other ring tones that have varying notes. I downloaded some of songs I like. I found that makes it easier to hear. Don't go for rap music- I found that was the most difficult to hear. I've managed to transfer an mp3 song from my computer onto my phone and use it as a ringtone.
    Another way to test the speakers is to play some music through the "entertainment" menu. That way you can test to see if the volume adjustment is working well. If you can only hear the music faintly (as well as all other sounds), then there is probably something wrong with the speaker.
    Yes, mine has a green light that flashes occasionally. I think that is the phone checking the signal.
    Jan 20, 2008 | Sony Ericsson K610i Cellular Phone
    Please help me. I need 2 know how 2 raise the volume of the ringer on my phone
    It is in the settings... under profile. Edit one of those and select 1-4 or loud to increase ring volume. Or try editing the ringtone on your PC to increase the decibals of the file.
    Nov 01, 2007 | Samsung Blackjack SGH-I607 Smartphone
    No sound when phone rings
    I called Verizon Wireless and the said, if you go to “My Sounds” or “My Ringtones” select the song that you want to hear and press the play button. While the ringtone is playing press the button on the side of the phone to raise the volume…you should be able to hear the ringtone. Hope this helps!
    Jul 29, 2007 | Motorola Mobility MOTOKRZR K1 Cellular...
    Pantech Matrix  Cell Phone Logo
    101 people viewed this question
    Top Pantech Cell Phones Experts
    Computer Repairing
    Computer Repairing
    Jax Planet
    Jax Planet
    Abdul Mannan
    Abdul Mannan
    Are you a Pantech Cell Phone Expert? Answer questions, earn points and help others
