Question about RCA P52960 52" Rear Projection Television
RCA chassis# PTK195Y06B projection tv convergance problems
While working on a convergence problem in my P520960 tv with chassis PTK195Y06B I came across a diode that was bad on the underside of the main circuit board. The board has markings of 1555947F on it, and I'm trying to find either what the diode is or schematics/parts lists so that I can fix the problem. The referance designator on the part is CR705, and it is a fairly small SMT diode on the back side of the board. Anyone know what this diode is or can anyone point me to where I can get the right schematic for this tv?
Thank you,
-Devon Johnson
2 Suggested Answers
localwonder
  • 6784 Answers
SOURCE: RCA chassis# PTK195Y06B projection tv part
DIODE RCA Part Number: 198589
Posted on May 24, 2009
My 52 inch RCA projection tv has a blue line around everything white
The convergence needs correction. If its not able to be cleared up by running the auto convergence feature in the setu menu then you will need to repair the convergence. You can get free technical assistance and parts foor your RCA at www.tvrepairworld.com they are RCA experts with that chassis
Feb 10, 2013 | RCA R52WM24 52" HDTV Projection Television
Rca d52w17 convergence off on 1080i signal only tv works fine with 480p signal.
you will need to adjust the geometry and convergence defaults for both the 1080 and 480 seperately then save. You can get the CD called the ITC222 chassis convergence and alignment CD which shows how to do that from www.tvrepairworld.com
May 26, 2010 | RCA D52W19 52" Rear Projection Television
Hello i have an rca tv the pic is bowed and the letters are double i think i need a convergence kitmodel #p61960 chassis#ptk195yo6t
STK730-010 regulator it will be on board up over chassis snaller board
Call Mats Electronics fpr Part 1-800-628-1118
Dec 29, 2009 | RCA Televison & Video
RCA R52WH77 ITC222A chassis convergence problem - FL231 changed!
did you hear an arch before it went if so , one of your crts is arching
and sorry they are not avail anymore
Sep 20, 2009 | RCA Televison & Video
Replacement STK numbers for convergence amps
This unit does not use the STK series convergence amps.The convergence power supply is what you need.I will provide that number for you after while.
Jan 19, 2009 | RCA P52960 52" Rear Projection Television
Convergence??
e-mail me at networks@q.com and get me the chassis number see in the back of your tv under model number maybe chassis number
Apr 17, 2008 | RCA HD52W59 HDTV Projection Television
Chasis number
this is same ctc169 check for separated power supply for convergence some times 2 wiress goin from main chassis to convergence board red and black are intermiten check for that but you mention that only show menu. select tv and check for tv signal or video imput if you dont have video you have convergence problem and some thing else
Apr 03, 2008 | RCA P52926 52" Rear Projection Television
Rca rear projection convergence problem
Convergence outputs reliable.Suspect power supply to control convergence bad.Small PCB mounted above two main PCB.Check STK730-010 & associated circuitry. If This info not helpful, please provide complete service # and chassis number.
Oct 07, 2007 | RCA P56830BL 56" Rear Projection...
RCA P52960 52" Rear Projection Television Logo
260 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
