Question about 3M Scotch Disc Cleaner for CDs, CD-ROMs, DVDs and DVD-ROMs (av-100) CD / DVD Cleaning Disk
Hi - I have a scatched DVD Game & NO Directions to my 3M cleaner
Hi - I have a scatched DVD Game and the 3M/Scotch Disc Cleaner (with cleaner & cloths) but NO DIRECTIONS... can you help? V/r, Jerry
Lite on burner will write but cant read
Now I LIKE Liteon very much. THey never give me any trouble and as long as you keep the lense clean, they burn for years upon years to come. Okay, so it CAN write, but can't read? Very odd indeed. I would strongly suggest first buying a CD Lense Cleaner disc. Don't be cheap. Get Memorex or Scotch 3M. I would Suggest Memorex because the brushes on THAT disc are SPECIALLY-designed to clean the lense, but NOT to damage it. Next, try installing Nero Ultra Edition and do a Burn-in or a Read/Write test with a CLEAN CD or DVD and see if it will tell you the Read/write data rate. If the lense is just a BIT dirty, it WILL give you those kind of problems.
Mar 25, 2014 | Lite On Computers & Internet
Troubleshoot wireless hotspot connection
Have you tried buying a Memorex or Scotch 3-M Cd/Blu-Ray Player Cleaner disc? You are supposed to clean your CD/DVD/Blu-ray player every 10 hours of playing time or every 5 MOVIES!!!
Mar 22, 2014 | Computers & Internet
The dvd player will not read the disc
If it won't read any disc you put in, consider getting a new DVD player, the eye is most likely gone bad. If it is only one disc that you can't read i would suggest a Scotch DVD Cleaner kit. Cleans and Repairs discs, helps prevent skipping and mistracking, and repairs minor surface scratches improving disc audio and image quality.
Jul 28, 2011 | Cyberhome CH-LDV1010A Portable DVD Player
Unable to read disc
Try purchasing a disc head cleaner (http://www.amazon.com/Scotch-Cleaner-Players-CD-ROM-DVD-ROM/dp/B00006HZ2Z)
Do you have the same issue with every disc or just one?
Apr 16, 2011 | Nintendo Wii Console
What disc do i buy lazer disc cleaner dvd player or just a regular lazer disc cleaner
you need to purchase a lazer disc cleaner it looks and works just like a normal dvd disc but it has brushes on it that when put through the player brushes the dust of the laser lens this needs to be done on a regular bases to keep your lazer working to its optimum level and hense fixing your problem...
Dec 15, 2010 | Nintendo Wii Console
EZ Dupe CD/DVD Duplicator keeps giving the error message, 'Source Not ready" No matter how many different CDs I put in the top disc slot, it keeps detecting an error
Have you tried cleaning the lens?
3M makes a CD lens cleaner that is a playable CD with micro brushes sticking out of the surface of the CD.
You can find them at office supply stores, K-mart, etc. I don't remember where I bought mine, but it works great for a CD-recorder that I use in a high dust environment.
Here's a link to one that I just found by googling "3m cd lens cleaner"
I've never dealt with that vendor before, but it has a picture of the product so you can see what I'm talking about.
Feb 12, 2010 | Computers & Internet
The playstation got really sensitive with reading disks
Sounds like you need to clean the lens on your PS2. The best solution is to find a DVD player lens cleaner from a local electronics store (make sure it is a good quality one, don't buy the cheapest one) and put it into your PS2 disc tray. It will play the disc using the DVD player on the PS2. Make sure you follow the directions for the lens cleaner very carefully, as you don't want to accidentally scratch your lens.
That should help with the reading issues. Good luck!
Jan 31, 2010 | Sony PlayStation 2 (PS2) Console
The consul keeps stopping mid-game & the screen says 'disc unreadable' although disc is perfect
2 things to try here. The simplest is to put a disc drive cleaner into the dvd drive and run it a few times. If this doesn't solve your problem, consider installing the game to the harddrive. Sometimes this helps especially if the error occurs during loading or cutscenes.
Dec 23, 2009 | Microsoft Xbox 360 Console
My game wont read on my xbox 360
I believe you can use a DVD cleaner without voiding your warrenty. If you have a warrenty then call Xbox tech support to get it fixed. And if you don't buy an extended warrenty for $50 and then call them and tell them you need your Xbox fixed
steps to be followed.
  1. step 1 Purchase a DVD lens cleaning disc.
  2. Step 2 Turn on your television and Xbox just like you normally would to play a video game.
  3. Step 3 Open your Xbox's disc drive, placing the lens cleaning disc in the drive face-up. A lens cleaning disc works by sweeping small brushes over the laser lens surface. These brushes are located on the bottom of the disc; be careful not to touch the brushes---the microfiber brushes are delicate and can become damaged easily.
  4. Step 4 Close the Xbox and let the machine power up; make sure your television's volume is turned on. Your Xbox should automatically take you to the system's standard CD player menu. If this does not happen, select the menu manually using your Xbox controller.
  5. Step 5 Begin playing the first track of the cleaning disc. Listen carefully, because audio directions will play indicating the steps necessary for properly using your cleaning disc. Each brand of lens cleaning disc will have different steps, but they are typically very simple, involving tasks like skipping ahead to different tracks or briefly putting the CD in fast forward mode. If you cannot hear the audio directions, consult the written instructions packaged with the disc.
  6. Step 6 Remove the cleaning CD after you've followed the audio directions---a typical cleaning cycle only takes a few minutes, and the audio directions will tell you when cleaning is complete.
  7. Step 7 Carefully place the lens cleaning disc back in its case, avoiding damaging the brushes on the bottom. Lens cleaners can be used multiple times, so plan on using the cleaning disc regularly to help avoid future problems with your Xbox console.
Jun 13, 2009 | Microsoft Xbox 360 Console
Cant read DVD in my DVD Rom
you can try a laser lense disc cleaner , something similiar to
http://www.amazon.co.uk/Scotch%C2%AE-Laser-Lens-Cleaner-DVD/dp/B00006HZ2Z
I think there are better branded ones.
If that does not work then the laser lense for the dvd is not working / broken so will be easier to replace the dvd drive.
Apr 23, 2009 | HP (350208-001) CD-RW/DVD-ROM (Combo)...
3M Scotch Disc Cleaner for CDs, CD-ROMs, DVDs and DVD-ROMs (av-100) CD / DVD Cleaning Disk Logo
37 people viewed this question
Top 3M Electronics - Others Experts
Are you a 3M Electronics - Other Expert? Answer questions, earn points and help others
