Question about GE Profile Arctica 25.4 Cubic Feet Side-By-Side Refrigerator With Dispenser PSS25MGMWW
Water flow in dispenser in door is slow. I've had this refrigerator for 5 years and have not had problems until now. I just change the filter, and that did not correct the problem. There doesn't appear to be a problem with the water line going into the refrigerator. How can I increase the water pressure again in the water dispenser?
    Sergeant:
  • 222 Answers
Probably calcium build-up in the water valve. If you can get to the valve, see if you can take the water line off and put a little Calcium/Lime/Rust (CLR or a similar product) in it. If you've got one of those syringes like you inject spices into meat and turkey, that would do the trick. You might also try an eye-dropper. BE SURE to flush the line throughly after you put the tubing back together. For safety's sake, flush it twice as long as you think you have to.
That should do the trick. If not, you may want to remove the valve and see if there is a calcium build up there. It's the 'bottleneck' of the water flow system, and I'm betting that's where the blockage that's slowing the water flow is. Worst case scenerio, buy a new water valve.
Posted on Jun 27, 2009
Water flows very slow out of the dispenser on my samsung refrigerator
Try replacing the filter again, If it works again then you might want to think about putting some sort of water softener system in your home
If you need further help, reach me via phone at https://www.6ya.com/expert/steven_a67ead41eb5fc62a
Dec 08, 2013 | Samsung 26.0 cu. ft. French-Door Bottom...
Samsung refrigirator water dispenser works without filter but does not work with filter
Not enough water pressure in supply line to get past filter?
Open valve feeding supply line more and see what happens.
Sep 06, 2017 | Samsung Refrigerators
Old filter in and water started to sputter, made clunky noises and flow very slow. Removed filter and used plug - water ran fine not filtered.- Replaced with new Maytag filter and water sputtered, flow...
Hello there, when new filters are fitted usually they are expected to spurt for a little bit before they normalize and begin to flow properly. Dispense water continuously for 10 minutes. This usually arises when the flow of water through the unit not being allowed through properly and usually takes the new filter a couple of minutes to get accustomed to the water flow and get water circulating through all its components hence the spurts. Alternatively you can check to ensure that the water supply is turned on full and the filter is properly fitted. If all of these are in place then the dispense mechanism might be faulty.
Hope this support has been helpful?
Thank you for visiting FixYa.
Sep 23, 2011 | Maytag MSD2756G Side by Side Refrigerator
Bought a new Maytag side by side. Will not put out water. Tried the 5 sec on and 5sec off to flush the air out, still didn't work. What next?
Hi and welcome to FixYa, I am Kelly.
First off you need to make sure the freezer door is CLOSED and water filter is properly installed in the filter housing. Without a model number I can not tell you the exact location of the filter. There is a water lock out function of the water filter housing that will prevent proper water flow until the filter is installed correctly or removed completely. Also... there is a water tank / reservoir that has to be filled completely with water before you will see any water at the spigot. Please pass your model number so I can better assist you or call the Maytag Sercive Center so they can walk you through the initial set up procedure of your refrigerator. (They will also need your model number) Go to http://www.maytag.com and register your appliance before making the call.
1 (800) 344-1274 U.S.
1 (800) 688-2002 Canada
Before making the call check out this information about troubleshooting:
http://maytag.custhelp.com/app/answers/detail/a_id/110/kw/Water/session/L3RpbWUvMTI5ODY4MTEyNi9zaWQvam9CYWV5bms%3D
- After connecting the refrigerator to water source or replacing the water filter, flush the water system. Use a sturdy container to depress and hold the water dispenser lever for 5 seconds, then release it for 5 seconds. Repeat until water begins to flow. Once water begins to flow, continue to press and release the dispenser bar (5 seconds on, 5 seconds off) until a total of 3 gal. (12 L) has been dispensed. This will flush air from the filter and water dispensing system, and prepare the water filter for use. Additional flushing may be required in some households. As air is cleared from the system water may spurt out of the dispenser.
- Make sure the dispenser is not locked. Some models have a lock feature that deactivates the dispenser levers and control buttons. The lock button is on the dispenser front cover. This feature controls unintentional dispensing during cleaning. Press the Unlock or Locked button to reactivate the dispenser levers and allow dispenser function. You may need to hold the button for 2 to 3 seconds.
- If there has been a recent power outage or the power supply has been off for more than one hour, the power outage indicator (on some models) will disable the dispenser function. The dispenser display will read "PF" to indicate power failure. To use the dispenser, press and hold the "Reset" button for 3 seconds until you hear the beeps.
-A clogged or incorrectly installed water filter will reduce the water flow to the water dispenser. Check for a problem with the filter by removing the filter and operating the dispenser. If water begins to flow, then the filter is either clogged or incorrectly installed. A clogged filter will need to be replaced.
If the filter is clogged and you are not able to immediately replace it, leave the filter out so the water system is in bypass mode. With the filter removed, the water system will continue to operate, bypassing the filter, and the clogged filter will not cause slow water dispensing. However, in order to have filtered water, you will need to install a new filter.
All Genuine Maytag Water Filters retain beneficial fluoride and are NSF Certified for drastically reducing chlorine taste and odor, particulates, lead, mercury and cysts.
To ensure glass after glass of clean, refreshing ice and water, change your filter yearly or whenever the system light indicates.
about the filter:
http://assets.whirlpool.com/files/usr/animations/ANM000085.htm
The information above should get your water working. If not please listen for a solenoid buzz as you actuate the water in door function. No buzz either the dispenser is locked off or.... you have a valid warranty claim.
Thanks for choosing FixYa,
Kelly
Feb 26, 2011 | Maytag Refrigerators
Whirpool Gold 21 Cu. Ft. Side by Side. Water dispenser will not dispense water. I hear the solenoid click. I think the line in must be frozen some where.
Do the following: Flush the water system. Use a sturdy container to depress and hold the water dispenser lever for 5 seconds, then release it for 5 seconds. Repeat until water begins to flow. Once water begins to flow, continue depressing and releasing the dispenser lever (5 seconds on, 5 seconds off) until a total of 3 gal. (12 L) has been dispensed. This will flush air from the filter and water dispensing system, and prepare the water filter for use.
Ensure that the freezer door is closed completely? Close the door firmly.
Ensure that the water shutoff valve is fully open.
Ensure that the water pressure is at least 30 psi (207 kPa)? The water pressure to the home determines the flow from the dispenser.
Check for any kinks in the home water source line? Straighten the water source line.
Check the water filter. The filter may be clogged or incorrectly installed.
if still there is problem of water flow then please take assistance of a technician to check the plumbing.
If the fridge is new and in the warranty period get in touch with the service center and ask for free service.
Feb 01, 2011 | Whirlpool Gold White-on-White 21.9 cu. ft....
Water dispenser dripping water all the time
First be sure the refrigerator is connected to a cold water supply. After connecting the refrigerator to a water source or replacing the water filter, flush the water system. Use a sturdy container to depress and hold the water dispenser lever for 5 seconds, and then release it for 5 seconds. Repeat until water begins to flow. Once water begins to flow, continue depressing and releasing the dispenser lever (5 seconds on, 5 seconds off) until a total of 12 L has been dispensed. This will flush air from the filter and water dispensing system, and prepare the water filter for use. Additional flushing may be required in some households. As air is cleared from the system, water may spurt out of the dispenser.
One or two drops of water immediately after dispensing is normal. It may be necessary to hold the container under the dispenser for 2 to 3 seconds after releasing the dispenser lever.
Hope this will be useful.
Thank you
Jan 04, 2011 | Whirlpool 25.4 Cu. Ft. Side-by-Side...
Want to know when and how to replace water filter on a ge side by side refrig
The water filter status light or indicator, present on some models, will help you know when to change your water filter. The light, or indicator, is located either on the temperature control panel in the refrigerator compartment or on the dispenser control panel on the freezer door.
The indicator will be one of two styles.
If the indicator is a light or series of lights, the light will change from green to yellow. This tells you that it is almost time to change the filter. It is recommended that you replace the filter when the status light changes to red or when water flow to your water dispenser or ice maker noticeably decreases.
If the indicator resembles a stack of bars, the bar height will decrease and the status display will change from "Good" to "Order." This tells you that it is almost time to change the filter. Replace the water filter cartridge when the water filter status display changes to "Replace" or when water flow to your water dispenser or ice maker noticeably decreases.
If a filter status light/indicator is not present, the filter should be changed at least once every 6 months. Your filter may need to be replaced more frequently depending on your usage and water quality.
If the water flow to the water dispenser or ice maker noticeably decreases before 6 months have passed, you may need to replace the water filter cartridge more often. Decreased water flow is a sign that the filter is clogged and needs to be replaced.
If the filter is clogged and you are not able to immediately replace it, remove the filter so the water system is in bypass mode. With the filter removed, the water system will continue to operate, bypassing the filter, and the clogged filter will not cause slow water dispensing or low ice production. However, in order to have filtered water, you will need to install a new filter.
The filter status display will help you know when to change your
water filter. When the display reads 10%, order a new filter. It is
recommended that you replace the filter when the display reads 10% OR when water flow to your water dispenser or ice maker decreases.
The filter should be replaced at least every 6 months depending on your water quality and usage.
Step 2
Press the eject button to release the filter from the base grille.
Step 3
Pull the filter straight out.
Step 4
Turn the cap counterclockwise to remove it from the filter. IMPORTANT: Do not discard the cap. It is part of your refrigerator. Keep the cap to use with the replacement filter.
Step 5
Align the ridge on the cap with the arrow on the new filter and
turn the cap until it snaps into place.
Step 6
Remove the protective covers from the O-rings. Be sure the O-rings are still in place after the covers are removed.
Step 7
Push the filter into the base grille. The eject button will pop back out when the filter is fully engaged.
Step 8
Flush the water system. Use a sturdy cup or glass. Depress and hold the
water dispenser lever for 5 seconds, then release it for 5 seconds. Repeat this process until water begins to flow. Once water begins to flow, continue depressing and releasing the dispenser lever. Hold down for 5 seconds and then release for 5 seconds. Do this on/off process for about 2 minutes. This will flush air from the filter and water dispensing
Hope this helpout in changing the water filter......
Aug 10, 2010 | GE Refrigerators
GE GSL25IGRE BS slow water dispenser
Sounds like your water valve may need changing, and has filled up with sediment, slowing the water flow.
Mar 29, 2010 | GE Profile Arctica Stainless Steel Top...
Purchased a GE Profile bottom freezer April 08. Has indoor water dispenser. Changed the water filter 60 days ago. Since then the amount of cold water dispensed has slowly decreased to a trickle. There...
Disconnect the water line where it comes out of the water inlet valve and see how the flow is when you try the dispenser. Disconntct the water line at the bottom of the freezer door where it goes into the door. If it flows good here it may be freezing in the door. Open the door till it thaws.
If it's good at the inlet valve and slow at the door, some models have a way to put a plug in and bypass the filter.
Aug 14, 2009 | GE Profile PFSF6PK Bottom Freezer French...
Low flow from water dispenser
hi, this can be because of the filter. when the water is flowing threw the filter, it is sent threw many channels inside the filter before it reaches the dispenser. this slows it down a bit. this is quite normal but, if it's slowed down to a dribble, i suspect a water valve malfunction or you may need to change the filter.
Mar 15, 2009 | GE GSH25JFR Side by Side Refrigerator
Refrigerators Logo
607 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
