Question about Bernina Bernette Deco 600
How to fix the timing on a Burnett Deco 500 Embroidery machine?
  • nappiecleo Jun 28, 2009
    I recently got this machine out of the box it had been stored in. When I put it away before storing it, everything was working fine. My first attempt at embroidering I was able to use Polyester thread and spell out JERSEY and then the bobbin was out so I couldn't continue sewing until winding a new bobbin. I chose the one of the silver metal bobbins that I purchased from my dealer a couple years ago. The dealer said they would work with this machine. I wound regular polyester thread in the bobbin and maybe that is what started this problem...I'm not sure. I've tried using the paper type bobbins and still no luck. At the first sign of trouble the needle was hitting too far down in the bobbin case (racer), and it made an awful sound and stopped the machine. I've worked on this all day and could probably fix it if I only had access to a repair manual. I'm not sure what position to set the bobbin racer in when setting the adjustment from the top right inside the machine where the rod turns. Now, the needle isn't scraping the casing, it is tangling up the threads in the bobbin case. Any idea where I can see an online schematic for this Deco 500?
  • Denise Peters
    Denise Peters Jul 30, 2016
    my machine is doing exactly the shame. I had it in storage for a long time. took it out it worked fine until I have to replace the bobbin after re-threading it???
  • 208 Answers
Not a simple solution. What makes you think that it is out of time?
Posted on Jun 27, 2009
  • Paul Howell
    Paul Howell Jun 30, 2009
    Unthread the machine and take the needle plate off and bobbin case out. Insert a new needle, ensuring that it is all of the way up to the stop. With the needle in the highest position, turn the machine on and select straight stitch center needle position.
    Turn the handwheel slowly towards you and observe the needle as it descends into the hook area.
    When the needle gets to its lowest position and raises 2.5 mm, the point of the hook should be directly behind the needle. If it is, reassemble, rethread and retry. If the needle and hook are not in sync, you will need to take it to a dealer. Timing issues require specific steps and tools.
  • Denise Peters
    Thanks
Will the PED card reader work with the Deco 600
contact bernina customer service about the ped card
Apr 15, 2014 | Bernina Bernette Deco 600
Deco scanner card
Sorry but you need to contact the manufacturer for this question .
Dec 30, 2017 | Sewing Machines
Need for deco magic box for a Bernina Deco 600
You can not connect the Deco 600 to a computer. Buy the Brother PED-Basic software rather than the Magic Box, Brother makes the Bernina Deco...
Jul 25, 2012 | Bernina Bernette Deco 600
Need a manual for bernina bernette deco 600 and more information on the machine.
Yes, I need a manual for the Bernia Bernette Deco 600. Following the death of my daughter, My grand daughter said she did not want any of her mom's sewing equipment. I kept them for her and now she feels she would like to have the embroidery machine. However, we were unable to locate the manual for the deco 600. I am unable to locate one on line...only good reason...due to my inexperience at the computer I am unable to locate a manual for her. Any assistance you can give me will be greatly appreciated.
Sincerely Nana Helen
Apr 17, 2010 | Bernina Bernette Deco 600
Bernina deco 500 the carriage doesn't move
Mechanical, what do you mean by thrill ?
Aug 20, 2009 | Bernina Bernette Deco 600
Top color thread showing on bottom of embroidery on a Bernina Deco 330 embroidery machine
Upper tension is too loose or lower tension is too tight.This might be a good thing. It depends upon how much it is pulling the thread under. A perfect tension on embroidery is about 2/3's lower thread and 1/3 upper thread showing on the bottom.
sewman7
Jul 09, 2008 | Bernina Bernette Deco 600
Bernina Bernette 600 Deco embroidery machine
It could be that there is a loose piece of thread, or some fluff which is obstructing the tension gauge. Try blowing around the theading area (or even run the hoover pipe near it to see if you can **** it out). I cleared mine by folding a piece of non fluffy material and rubbing gently between the tension dial and machine.
Good luck
May 19, 2008 | Bernina Bernette Deco 600
Sewing Machines Logo
642 people viewed this question
Top Bernina Sewing Machines Experts
Tally Girl
Tally Girl
jnissen
Level 1 Expert
silly01
Level 1 Expert
Are you a Bernina Sewing Machine Expert? Answer questions, earn points and help others
