Question about Water Heaters
There was a bird nest in the blower outlet pipe causing my Rheem Power Vent 2 to stop working. I cleaned out the nest but now it won't restart. I have tried turning it off then back on. The indicator light is flashing in sequence of four rapid flashes. Any ideas on how to solve this?
  • 332 Answers
You will need to take the vent off and blow it out to make sure noe of the nest is still in also look inside the blower and make sure there are no dead birds, or debris in the blower, it is vary hot air and would not be the first time an animal got freid inside the vent,,,,
Posted on Jun 28, 2009
What is the minimum vertical vent distant from top of water heater to top of cap. Water heater is stand alone outside furnishing water for military force provider showers unit.
Generally 40 feet for ordinary atmospheric-vented household water heater...
Straight run to roof.
Atmospheric means no power vent... just hot air drafting upwards
Google search: gas vent height code
Atmospheric venting code depends on 4 basic factors:
Diameter of vent--- bigger vent, more draft
How many water heaters are connected to same vent
BTU per hour rating of water heater-- the more gas that is burned per hour, the bigger the vent needs to be
How straight the pipe is -- are there any horizontal or lateral runs
http://www.ameri-vent.com/files/assets/files/1366372183_Sizing26ApplicationGuide1.pdf
http://waterheatertimer.org/pdf/Bosch_Checking_the_draft.pdf
http://waterheatertimer.org/pdf/checking-the-draft2.pdf
Other factors can include
-wind conditions... higher wind across top of vent pipe on roof can reduce draft, and cause downdraft that blows deadly CO into same room as water heater
-vent termination near high walls, trees, high roof peak etc will reduce draft or cause downdraft
-amount of incoming air supply... if water heater is inside a closed room, then there is no air to draft up the pipe, burner will shut down or burn lazy yellow instead of clear blue
-stuff piled up around water heater that obstructs air intake
-dirty air intake screen that reduces air intake
-vent fans inside same room as water heater that pull air down the vent and cause reduction in water heater draft
-generally elbows reduce draft by 10%
-vent cannot terminate near any window door or air intake for another gas appliance
-bird build nest on top of vent pipe after vent termination falls off
-highly acidic gas by-product causes large amount of condensation inside pipe that burns hole in pipe or drips down and damages combustion parts...blower and inline condensate trap and drain might be required
-multiple water heaters installed on same vent line.
Gene
Water Heater Timers Save Money
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Mar 27, 2015 | Water Water Heaters
Why is there waterl leaking from my power vent unit
http://waterheatertimer.org/Leaking-water-heater.html
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#vent
Bad vent?
Improper vent? Undersized vent?
Vent termination cap located on roof has come off?
Bird nest in vent pipe?
Gene
Oct 17, 2014 | Fasco Bradford White Water Hot Heater...
Have 75 gallon gas water heater. Can I run 90 PVC off top power vent without vertical PVC first? Have Richmond unit.
1) I believe you can immediately elbow the PVC pipe.
There is a limit for how many elbows can be used between blower and termination, and limit is determined by diameter of PVC pipe.
2) Copy following link for venting resources and typical Rheem and Richmond power vent manuals, and diameter-elbow pdf from Bradford White.
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#venting
3) Richmond is Rheem. Product manual will show specifications for venting.
Product warranty is voided if installation does not follow specifications shown in manual.
Feb 20, 2013 | Rheem Richmond 75 Gal Natural Gas 6 Year...
Rheem model 41vrp40n flashes twice and stops working
Error code means that you have electronic gas control valve.
Copy following link to identify gas control valve, read error code meanings for each, and download service manual relevant to each gas control, but not specifically Rheem since rheem does not post service manuals.
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#intellivent
The fact that water heater restarts, means that water heater is getting gas, getting sufficient air for combustion, thermister is ok, gas pressure is good, etc.
The fact that you unplug and replug water heater and it works, shows that you have power vent model.
Since water heater worked correctly before, 2 flashes with Rheem power vent model could mean that pressure switch has failed.
Jul 29, 2012 | Water Heaters
Richmond water heater goes into lockout condition, ignition failure and I have to turn the blower switch off then on to get the water heater to work. Its getting to be a everyday thing. Also would like to...
Start-point is to inspect and clean burner parts and combustion chamber, clean air intake, bleed air out of gas line, test gas pressure, test electronic gas control valve, check for venting issues.
As general rule, gas water heater manuals recommend professional service once a year that would cover most items listed above.
To see images, and for more reading and resources, look at your product manual and open following link:
http://waterheatertimer.org/How-to-install-gas-water-heater.html#clean
Richmond/Rheem sells power vent blower assembly that cost about $300.
Your product manual shows part numbers.
http://www.monstermarketplace.com/heating-supplies/rheem-sp12562-blower-assembly-powervent-2
Replacement gas control valve costs $300
Aug 16, 2011 | Audiovox Richmond 6G40-36F 6-Year Tall Gas...
I have a 30 gallen Rheem gas water heater. The water is coming out of the exhaust. Is there a way to fix this or do I just need to buy a new one?
I am uncertain from your description exactly where water is coming from.
I want you to protect yourself first.
Read following page to help identify source of leak:
If your vent pipe is spitting water back on top of water heater, then the problem is not the water heater. Problem could be poor venting.
Water heater is putting odorless CO gas into home, and will kill you. Give you headaches, make you feel sick until you go outside and get fresh air.
Call a plumber please if flue pipe is problem.
Here's how to check if flue pipe is drafting properly:
When water heater burner is off, light a match, blow match flame out, put match under vent hood on top of water heater.
Does smoke from match immediately draft up flue pipe?
If smoke does not draft up strong, then water heater is putting CO gas into home.
The vent on all gas appliances has to be working properly.
Look for missing top of vent pipe located on roof.
If cover is missing, a bird might built a nest on end of pipe, or leaves have fallen into pipe which is a fire hazard.
If flue pipe goes into chimney, you should call a plumber.
A plumber is cheaper than potential health problems with improper flue.
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Feb 13, 2011 | Rheem 30 Gallon FVR NATGAS Water Heater...
Rheem 50 gallon water tank. can not burn. CO senser is alarming
sounds like the flue is plugged up. or the venting at the bottom is plugged
CO is deadly, do not use if your CO sensor is going off.
you need to clean out the vents at the bottom of the heater, especially if this is a newer model water heater. if the vents are plugged the flame will light for a minute, but get really big and yellow, and then flame will go out.... not getting enough air
be sure to check the flue pipe, birds like to make nests, and will cause the flue gas to escape into the house instead of outside.
if you have problems, please call a pro, CO is deadly!
Jul 01, 2010 | Rheem 50 Gallon FVR NATGAS Water Heater...
I have a Rheem direct vent gas water heater. When
If you are not seeing a spark at the pilot assembly where the pilot flame lights, then it is probably not sparking in the right place. You may have a short in the wire or a cracked porcelain ignitor, causing it to spark elsewhere. If you can remove the access panel, you may have to relight the pilot manually with a butane lighter. To resolve the issue of the flame blowing out, make sure your vent outside has a cap on it and that the vent is not partially blocked with a bird nests, etc. Hope this helps. Douglas
Jun 27, 2010 | Rheem 50 Gallon FVR NATGAS Water Heater...
Loud blower on my new Rheem Power Vent 2 water heater
find out if it does the same noise with the venting disconnected
Nov 01, 2009 | Fasco Bradford White Hot Water Heater...
Water Heaters Logo
109 people viewed this question
Top Water Heaters Experts
Paul Carew
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
