I would start with a slow 250 oven for about 45 minutes. If the lasagna is thawed by then kick the oven up to 350 for another 30 to 45 minutes. Test temperature with a thermometer or knife blade to see if done.
Based on a 1200 watt microwave. Increase time for less wattage devices.
Place in a large casserole dish with lid and cover with water.
Heat on High (full power) for 15 minutes then 15 to 20 minutes per 450g at Medium power.
Allow to stand before serving as always.
1 Use the number buttons to set a cooking time. You can set a time from one second to 99 minutes, 99 seconds. To set a time over one minute, enter the seconds too. For example, to set 20 minutes, enter 2, 0, 0, 0 . 2 If you want to set the power level to something other than High, press the Power Level button, then use the number buttons to enter a power level. Power Levels: Level Cooking PL 1Warm10 2Low20 3 Defrost 30 4Medium Low40 5Medium50 6 Simmer 60 7 Medium High 70 8 Reheat 80 9 Saute 90 10 High Hi
Always use an oven bag is used to promote even cooking. Microwave on MEDIUM (50% power) for 7 to 9 minutes per pound rotating
dish every 15 minutes. Not recommended for turkey over 12 pounds
Use an instant-read thermometer after cooking. Turkey is done when
thermometer reads 180 degrees to 185 degrees F for whole turkey or 170
degrees to 175 degrees F for turkey breast. Insert thermometer through
**** in oven bag into inner thigh for whole turkey or into thickest
part of breast for turkey breast.
For easy slicing, let stand 10 minutes after removing from microwave
oven. To open, carefully cut or **** top of oven bag. NOTE Microwave
directions were tested in 600 to 700-watt microwaves. Higher or lower
wattage ovens may need adjustment in cooking times.
Sounds like a bad magnetron, i would replace the magnetron, Capacitor and Diode at the mag assembly, to be honest it will cost you more to fix than a new one.............
Normally the dials are the timer for cooking time plus cooking power level dial, for defrost, medium, high, etc.
It may also have a start button to start it cooking. If not, then you place the food inside, shut the door, then rotate the timer dial to however many minutes you want.
If this does not answer your question, maybe you can take a photo of the controller and post it.
We're happy to help and we appreciate your thoughtful rating of our answer.
