Question about JVC TV-13142 13 in. TV/VCR Combo
Would like to switch tv mode to cable mode
I have no remote control so I would like to get cable channels manually. How can I do it without the remote control.
  • GJMLD Dec 07, 2007
    Same problem with a Combo TV-VCR 13140
    I have tried to change the settings with an all purpose remote control (Sony RM V310), having also lost the original. Unfortunately I cannot locate the button which allows one to select cable. I get the menu, but cannot do a thing with it...
    My other problem, does this TV set have a limited number of possible channels, like around 12 ?
    Thanks for helping me out
  • cgoodwin Jan 13, 2009
    Our remote quit working for on and off but we could still change the channels with it. Then when I had by room painted the man disconnected my cable and when it was reconnected I just get static like the cable isn't connected. It is a 13 year old Toshiba TV
  • 93 Answers
Go to the menu button,press it, in menu service you to choice either air or cable. then select the cable
Posted on Nov 07, 2007
  • like2survey
    like2survey Feb 14, 2012
    I wish it was that simple with mine. I can get to the setting options to try to do that, but for whatever reason, can't get the remote to switch to catv. Only goes up and down, not side to side under the "Setting". So odd cause it never did that before. I can go side to side under the "options" tab, but not under any other one now. So frustrating cause all I need to get it to do is go to catv. I'm destined to only have 16 channels unless somehow this fixes itself or a miracle happens I guess. Out of the blue just won't go side to side now. :(
How can I switch channel from Ant. Over to TV with no remote on a 2006 Sansai tv set
Every TV has buttons that can do all a remote does, check the user manual or google the make and model. user manual for instructions,
Nov 10, 2016 | Televison & Video
Sanyo tv ds25030 how to program chanals 48-96
Your TV must be set in cable mode for channels higher than 69, and your cable provider must allow those channels to be received without a cable box. Menu, Channels, switch air to cable, run auto scan. If it receiving those channels unencrypted, it will find those channels.
Mar 10, 2015 | Sanyo Televison & Video
While moving my parent's Curtis Mathes Cm19001 TV produced in 1999, I touched the channel button which took the TV off of channel 3. We've tried to use the channel buttons to return to channel 3,...
I have one of this tv model too.Just used a RCA component cables like Y,R,W hook one side to the tv Video IN INPUT holes and the VCR the other end of the cable to VCR Video OUT INPUT holes.Now just pushes a channel manual button up or down a couples for the tv go into VIDEO Mode.Play the dvd player it will work.Or try Remotes.com to buy a tv original remote.Return the universal remote.
Jun 18, 2011 | Curtis-Mathis CM19011 TV
No remote tv stuck in cable mode no channel 3
See if you can get a manual for the set at web site or try a google search.
Sep 07, 2017 | Televison & Video
How can I Program this to comcast digital cable.
Most universal remotes work the same. Try this. Just keep in mind when you select your item select cable.
Here you go. This will work with most all universal remote controls. If you don't have the code do the following:
Automatic Programming
With automatic programming, the remote control tests all the codes available on the Code List and assigns the correct code for the selected device. Although this method can be more time-consuming, it eliminates the need to look up codes and enter them manually.
1. Turn off the device with which you want to use the remote control.
2. Press and hold the corresponding button on the remote control
(TV, VCR, SAT, DVD, CAB or AUD) until POWER INDICATOR illuminates. It should take a couple of seconds for the light to remain solid. The remote control is in programming mode.
3. Press and release power button. The POWER INDICATOR flashes once and stays on indicating the unit is in Power Scan mode.
4. Press CHANNEL up or CHANNEL down repeatedly until the device turns on.
5. When the device turns on, press OK to store the code.
Note:
• To exit without storing the code, press BACK.
• T he unit will search for the next code or the previous code if you press
CHANNEL up or CHANNEL down after the device turns on. (go slow you need to press OK when the TV turns on) if you mess up turn TV off and start over.
6. Press any other button. If the device responds, the remote control has been programmed. If the device does not respond, repeat steps 2-5.
Fill free to ask me questions about anything..........................
Sep 25, 2009 | Brookstone 538744 Remote Control
How to get TV/video mode without remote
some tv do that changing the channels.
in the control panels in the tv where r the buttons for change channel there must be video button, push it and there you go.
Good Luck
Jan 12, 2009 | Toshiba 14AF44 14" TV
No remote and cannot change to video mode!
Go to radio shack and get an universal remote control that has a tv/vcr input button. the one i got is a Phillips Universal to switch channels myself.
Sep 13, 2008 | Symphonic ST420FF 20" TV
Help with Game Mode/Channel Switch Please!
Go to Radio Shack and get an universal remote control, i have a Phillips Universal for mine. it has a tv/vcr button that also is an "input" button to switch channels to do this.
Aug 26, 2008 | Symphonic ST420FF 20" TV
Can't get the tv to move from the cable mode
Wondering if this is what your asking about, I cant find reference to Cable only mode...
- Line 7 : “CHANNEL BLOCKED”
Indicates that all channels are locked except the selected channel.
The following complaints may be generated due to locked channels:
- TV cannot be switched on from standby with the local keyboard buttons.
- “CH+” and “CH-“ buttons on local keyboard do not function.
To disable the LOCK feature:
Select ”FEATURE” menu (with the Remote Control).
Select “LOCK” (with the Remote Control).
Set to “OFF”
Aug 18, 2008 | Philips Magnavox 51MP392H Rear Projection...
Toshiba 24AF44
You need the original remote controller to be able to switch input modes.Universal ones usually don't work. If you don't have the original remote and can't find it ever or if it is too expensive you can buy an rf modulator ( very cheap) and connect your dvd player, game console etc) to the modulator then connect the modulator to your antenna with a coax cable. This worked for me. It placed the connection to channel 4 and other cable channels are still working,
You can buy the RF Modulator from: http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=180299245670
Mar 16, 2008 | Toshiba 24AF45 24" TV
JVC TV-13142 13 in. TV/VCR Combo Logo
637 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
