Question about Nikon COOLPIX S52c Digital Camera
When switched on camera gives message - memory card is write prot
When switched on Camera is saying 'memory card is write protected. I cannot then take any photographs. I have tried a new memory card and get the same message. I also have tried to format disc, however that option is not available to me (i.e. although I can see it in the menu, the camera will not allow me to select it.
  • kakima May 11, 2010
    SD cards have a slide switch along one edge. Slide it toward the contacts to enable write, away from the contacts to protect.
    Does that help?
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Nikon Master
  • 102,366 Answers
SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
Posted on Mar 09, 2010
Unlock memory cardcard write prot
SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Feb 08, 2014 | Canon EOS 600D Rebel T3i Digital Camera
Camera shows error message saying "Memory card is protected (reset switch on memory card). This message does not clear when I reset the switch. Any suggestions?
The switch internal to the camera may be gummed up. But it can be easily "jogged" back open without opening the camera. You might try the toothpick or the tape fix listed in the troubleshooting steps of this blog article.
Jul 24, 2011 | Kodak EasyShare M552 Digital Camera
When I want to take photo a message says: memory card is write protected.How can I solve this problem
Take the memory card out of your camera. SD and SDHC cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
Jan 14, 2011 | Nikon COOLPIX S200 Digital Camera
Message on camera says "memory card locked" What
Take the memory card out of the camera and look at it. SD and SDHC cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
If that doesn't work, try another card.
Jan 07, 2011 | Panasonic Lumix DMC-LS80 Digital Camera
Camera no longer working
Your memory card must have had the switch moved from locked to unlocked. To fix this, removed the SD card from your camera. Look on the side and you will find a little switch. One end of the switch says locked the other end says locked. Move the switch from locked to unlocked. Replace it in your camera and turn it back on. Try it and let me know if I can help more.
Feb 17, 2009 | Kodak EasyShare C330 Digital Camera
Locked Card
Change the memory card lock switch to the normal setting84b4934.jpg3c6d94b.jpg
Good luck....
Nov 18, 2008 | Canon PowerShot S51S Digital Camera
Turning on the camera
Please look at the memory card closely. If there is a write protect switch, it will give you this error. Please ensure that the write protect switch on the memory card is not in the lock, or protected position.
See more information about SD cards here.
Let me know if this helps!
Brian
Jan 08, 2008 | Nikon Coolpix 4600 Digital Camera
Locked Card
Take the memory card out of the camera. Look at it carefully and you will seea small tab. Move the tab from the locked position to the unlocked position. Re-install the memory card into the camera and then you're done.
EEee
Nov 03, 2007 | Canon PowerShot SD630 Digital ELPH / IXUS...
"Memory card is protected"
This error message indicates that the memory card is locked. The switch on the memory card is in the write-protect position. Reset the switch as shown on the camera screen.
Aug 29, 2005 | Kodak EasyShare C360 Digital Camera
Nikon COOLPIX S52c Digital Camera Logo
96 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
