Question about Garden
Husquarna petrol hedge trimmer starting problem
My 2 stroke petrol hedge trimmer wont start at all it has spark and the fuel is geting through. Tried using easy start but made no difference still wont start. It aint even trying to start.
  • 28 Answers
It could be extremely flooded with way to much fuel. in the motor.take out the sparkplug turn the ignition switch OFF and pull the starter rope...if there is a lot of fuel blowing out of the cylinder...thats your problem.....buy a new sparkplug and try starting it with no choke and full throttle with the new sparkplug fitted....see how you go.....or its warn out and has no compression to fire up the fuel.....in this case ..its time to upgrade
Posted on Aug 06, 2009
Fuel Ratio What is the fuel Ratio for the Homelite HT -17 Hedge trimmer?
2 stroke tools generally run at 50:1
100ml of oil in 5L of petrol
Oct 29, 2015 | Homelite Garden
Echo hedge trimmer replaced carburator still wont start getting spark
Hi, There are 3 things that you need for the motor to start.
1) Fuel 2) Air 3) Spark. Check all 3 and it should run. Good luck.
Jul 27, 2015 | Echo Garden
My RST210 2 stroke petrol strimmer won start it has a spark at the plug also the plug is flooding so fuel is getting through but non start ? Great full for any ideas
Often it's the easiest thing that stump us. Try changing the spark plug first. Sometimes a spark plug just won't fire under load, i.e., while it's in the cylinder but will spark if you have it removed. There are checkers for this, but it's a lot less expensive to just replace the spark plug. Do that first and let me know.
Sep 28, 2014 | Makita RST210 2 Stroke Petrol Line Trimmer...
How do I mix two stroke engine fuel
Put oil in your petrol can add the exact amount of petrol put the cap on shake well use and store out of sunlight
Jul 17, 2014 | Trueshopping NEW 2 STROKE OIL FUEL PETROL...
Any special procedures to starting an old ST-175 homelite weed trimmer that has not been run on over 8 years.
the carb and fuel lines will most likely need repair, i would mix a little extra 2 stroke oil in the gas on the first run, and a few drops 2 stroke oil in the cylinder is a good idea..oh and you might want to check the spark arrester on the muffler .. jay
Dec 31, 2011 | Homelite Garden
Homelite 21" hedge trimmer. Won't start. Has spark, compression, fuel (used a little starter fluid), checker spark arrestor and muffler (clear). I haven't torn it down to check the Woodruff key but it ran...
Abell, put a little drop of petrol in the plug hole, replace plug and give it a pull. If it fires up for a moment, it is a fuel starvation problem. Check the carb, clean and make sure the nedel valve in the bottom of the carb is not sticking. Good luck!
Aug 06, 2010 | Homelite Factory Reconditioned 26cc...
My petrol weedeater/trimmer wont start
a few easy steps does it spark if not change the plug
if it doesnt spark now it could be a split in the HT lead so change that
Make sure u have clean petrol/oil mix
If still no luck check the on/off switch for rust or water
if damaged clean
Jul 28, 2010 | Ryobi Three Trimmer Combo
What mix of 2 stroke oil do I use for a Stihl hedge trimmer, in other words how much 2 stroke oil do I put into 5 litres of petrol. Thanks.
if using top quality 2 stroke oil
you put 100 mils of oil into 5 litre container and add 5 litres of fuel only that is 50:1 petrol oil ratio
cheers pauly46
May 29, 2010 | Garden
Garden Logo
932 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
