Question about Porter Cable Porter-Cable 309 3.8 Amp Laminate Trimmer
How can i 45 degree champher 1 mm laminate with laminate trimmer
    Problem Solver:
  • 6 Answers
Use a 45 degree 1/4'' shank router bit with bearing and adjust cut depth to desired depth. you may want to do a test cut on a scrap piece to make adjustments before you make the intended cut.
Posted on Jul 04, 2009
Kawasaki zzr1100c what is the valve clearence
hi there,
this table will help you. I used to own one.. beautiful bikes easy to work on too!
Valves:
Valve clearance: Inlet 0.13 0.19 mm
Exhaust 0.18 0.24 mm
Valve head thickness: Inlet 0.5mm 0.25 mm
Exhaust 0.8mm 0.5mm
Valve stem bend 0.05 mm TIR
Valve stem diameter: Inlet 4.975 4.990 mm 4.96 mm
Exhaust 4.955 4.970 mm 4.94 mm
Valve guide inside diameter 5.000 5.01 2 mm 5.08 mm
Valve/valve guide clearance
(wobble method): Inlet 0.02 0.07 mm 0.18 mm
Exhaust 0.06 0.11 mm 0.21 mm
Valve seating surface:
Outside diameter: Inlet 30.8 31.0 mm
Exhaust 26.3 26.5 mm
Width 0.5 1.0 mm
Valve spring free length: Inner 35.5 mm 33.6 mm
Outer 40.5 mm 38.6 mm
Valve seat cutting angle 32 degrees, 45 degrees, 60 degrees
Hope it helps.. Ken
Aug 18, 2014 | kawasaki ZZR 1100 Motorcycles
Looking for compound miter chart, 45 degree angles and 22.5 degree angles
Check out amazon.com at this webaddress: http://www.amazon.com/Compound-Miter-Chart-Tables-Laminated/dp/B0002TY06O to buy charts and tables. Also, you can see a free chart at this site: http://www.woodcraftplans.com/compound_miter.htm
Hope this helps.
Handie Andie, woodworker by night
Mar 27, 2011 | Garden
Porter cable Laminate trimmer maual
The motor is part # 3092 and the base is model 3091. When you put the two together it becomes a model 309. A parts list is here. http://www.ereplacementparts.com/porter-cable-3092-type-laminate-trimmer-parts-c-129_1861_1865.html
May 01, 2010 | Porter Cable Porter-Cable 309 Factory...
How to divide 12 11/16 inches into 71 3/8 inches?
you will need 5 full planks = 68 1/4 inches and the last board will need to be 3 7/16 inches wide.
Nov 15, 2009 | Freud FT750T Laminate Trimmer
Need to find new base screws sstripped on tightening of old base. Where can I buy replasement.
Go to FREUDTOOLS.com buy from them I have several times good folks 1 800 334 4107. don't try a substitute until you talk with them.
good luck!
Oct 04, 2009 | Freud FT1000EK Plunge Router/Laminate...
Collet chuck for Ryobi router R150 was broken
Ryobi - Sydney phoned and they had the part available so proceeded, thanks
Allan Japp
Dec 16, 2008 | Ryobi Laminate Trimmer Kit
Will a Porter Cable 7312 offset base laminate trimmer also work on Model 7301 HD POWER UNIT
I think it's meant to fit the 7310 trimmer, as the series numbers are in sequence. But when I look at the parts list for the 7301 & 7310, they seem to have the same motor housing part number, which indicates they are more or less the same size, no?
Check at the following website, http://www.dewaltservicenet.com/SearchResults.aspx?q=laminate%20trimmer
They also provide the means to ask them a question, if you're not sure you want to risk returning an order, in which case you want to link:
http://support.dewalt.com/cgi-bin/dewalt.cfg/php/enduser/ask.php?p_sid=tZeaxJtj&p_accessibility=0&p_redirect=&p_sp=cF9zcmNoPSZwX3NvcnRfYnk9JnBfZ3JpZHNvcnQ9JnBfcm93X2NudD0xNzM4LDE3MzgmcF9wcm9kcz0mcF9jYXRzPSZwX3B2PSZwX2N2PSZwX3NlYXJjaF90eXBlPWFuc3dlcnMuc2VhcmNoX25sJnBfcGFnZT0x
I hope this info allows you to sort it out.
Sep 01, 2008 | Porter Cable Porter-Cable 7311 Offset...
Laminate specifications
A typical laminate trimmer is equipped with a 1/4-inch collet. The motor runs in the 20,000-30,000 rpm range – faster than most routers to compensate for the fact that the bits are smaller in diameter.
Aug 27, 2008 | AMANA TOOL 3400 DOUBLE EDGE LAMINATE...
Laminate Trimmers question
Router-neck cavities, pickup cavities; Laminate trimmer- saddle slots, smaller cavities, expanding existing pickup cavities on a finished instrument; Dremel- inlay inlay inlay.
Aug 27, 2008 | Freud FT750T Laminate Trimmer
Laminate Trimmers Troubleshooting
Changing Bits: 1. Unplug the tool. 2. Turn the knobs on either side of the tool to loosen the base. 3. Remove the base. 4. Press the spindle guide to lock down the shaft. 5. Use a wrench to loosen the collet. 6. Remove the bit and collet. You may have to tap on the collet to loosen; careful not to tap on the cutting edges of the bit. 7. Insert the new bit and collet. 8. Use a wrench to tighten the collet into place. 9. Replace the base.
Aug 27, 2008 | Porter Cable Porter-Cable 309 Factory...
Porter Cable Porter-Cable 309 3.8 Amp Laminate Trimmer Logo
191 people viewed this question
Top Porter Cable Tools & Hardware - Others Experts
John Trevino
Jim Parker
Jim Parker
T bone 1963
Are you a Porter Cable Tool and Hardware - Other Expert? Answer questions, earn points and help others
