Question about ASUS P5VD2-MX SE Motherboard
Computer starts and after 10 seconds or something goes off
I tried to rename a password over the one existing that belonged to the former owner so worked on the jumper,moved some cables and when I started the computer back, it went off in seconds. I tried once and again but as long as I restart , it shuts down more quickly. Can you help me, please?
Ed. Thank you.
  • 1 more comment
  • esasu Nov 11, 2007
    Hey, I cannot rate anything for nothing was sent
  • bara05 Nov 23, 2007
    when i play music using Windows media player or winamp,the sreen goes blue followed by 0*0000000 s and it reboots i suspect that on my device manager pci driver settigs there is a question mark,pliz help.My email address is bara@justice.com
  • Anonymous Nov 26, 2007
    thanks
  • 87 Answers
R u talking about the bios or da windows login n password? if windows re-install windows da simple solution for it!
Posted on Nov 18, 2007
To unlock my blackberry smart phone. I have put the wrong password on my phone 10 times, now it is blocked,
Assuming the phone does in fact belong to its owner, and not stolen!! it will need wiping and starting a fresh...
Nov 14, 2017 | Blackberry Cell Phones
I forgot a password and i cant access a catalyst 2960 24-port 10/10
You can only reset password this way:
1.
Attach a terminal or PC with terminal emulation (for example, Hyper Terminal) to the console port of the switch.
Use the following terminal settings:
  • Bits per second (baud): 9600
  • Data bits: 8
  • Parity: None
  • Stop bits: 1
  • Flow Control: Xon/Xoff
2.Unplug the power cable.
3. Hold down the mode button located on the left side of the front panel, while you reconnect the power cable to the switch
4. Release the Mode button when the SYST LED blinks amber and then turns solid green. When you release the Mode button, the SYST LED blinks green.
5. switch: flash_init
6. switch: load_helper
7. switch: dir flash:
8. switch: rename flash:config.text flash:config.old
Rename config.text to config.old. In that file the password is stored.
9. switch: boot
10. Enter "n" at the prompt to abort the initial configuration dialog
11. Type en to enable
12. Switch#rename flash:config.old flash:config.text
13. Switch#copy flash:config.text system:running-config
14. Overwrite the current passwords:
conf term
enable secret <new pass>
enable password <new pass>
line vty 0 15
password <new pass>
login
line con 0
password <new pass>
15. write memory
16. copy run start
Sep 25, 2013 | Cisco Catalyst Computers & Internet
Where do the number belongs to +250784156023
The Rwanda Utilities Regulatory Agency introduced a new telephone numbering plan in February 2009. To call in Rwanda, the following format is now used:
  • 250 5XX XXX Land-line Calls (formerly 5XX XXX)
  • 255 5XX XXX Land-line Calls (formerly 5XX XXX)
  • 783 XXX XXX Mobile Calls (formerly 03 XXX XXX)
  • 788 XXX XXX Mobile Calls (formerly 08 XXX XXX)
  • 75X XXX XXX Mobile Calls (CDMA)
Mar 04, 2011 | Cell Phones
It ash for a user name and a password
This could be a Windows password or a system password or both. If you don't have the Windows password and the former owner can't tell you what it is, you might have to erase the disk, reinstall Windows and thus solve the problem. A System password is a theft protection that can only be changed if you know the password. It is embedded in the laptop hardware. Ask the former owner what the password is, otherwise there is no solution but to ask Dell Service.
Sep 30, 2010 | Dell Latitude D510 Notebook
When i turn on computer power on password comes on
This could be a Windows password or a system password or both. If you don't have the Windows password and the former owner can't tell you what it is, you might have to erase the disk, reinstall Windows and thus solve the problem. A System password is a theft protection that can only be changed if you know the password. It is embedded in the laptop hardware. Ask the former owner what the password is, otherwise there is no solution but to ask Compaq Service.
Sep 30, 2010 | Compaq Evo N600c Notebook
I am having so much trounle gerring my password---i am now on day 2 trying to resolve this issue
This could be a Windows password or a system password or both. If you don't have the Windows password and the former owner can't tell you what it is, you might have to erase the disk, reinstall Windows and thus solve the problem. On the other hand, a System password is a theft protection that can only be changed if you know the password. It is embedded in the laptop hardware. Ask the former owner what the password is, otherwise there is no solution but to ask HP Support.
Sep 29, 2010 | HP Computers & Internet
Put disc in hit reset button and heard a vibrating noise and the disc would/was not turning
There is a power switch on the back of the console, turn it off, wait 10 seconds turn it on.
Eject the disc.
Close the tray (if exists)
let the machine start up into the menu or sometimes called Dashboard.
Open the tray / insert the cd again.
If the disc doesn't start spinning there might be something in the drive that doesn't belong there, or there might be a mechanical problem with the drive that would require the console and the drive to be taken apart to solve the issue.
Feb 28, 2010 | Sony PlayStation 2 Slimline Console
Can´t restore XP
Yes - it will have (or should have) been set by the former owner.
Allan
Dec 09, 2009 | Dell OPTIPLEX 745 PC Desktop
After making film, can't open the file *ppp again
Did I understand properly if I say : After 2 weeks yu cannot find your film in your camera and the Power Producer says that some files properly does not exist ??
If yes then :
1. :check that you not have renamed the files (ex. record 1015 to my child 1). some cameras cannot understand that you rename the files inside the camera, you need to copy them out and then rename them. If you have done that then you can use explere to search inside your cameras hard disc and find the renamed film files.
2. :Another thing could bee that you have too many USB connected to the computer ( the computer can only have a x nummer of USB connected to the pc at the same time), try to disconnect some of the other USB connected.
3.: The USB place (port) you use for the camera is not working properly, try to use anither USB connection
4. The film files are corrupted( there can bee different reason for that ex you just disconnect the vire connected to the pc and camera without first disable the USB connection) OR the camera do record over the the old film when there is no more space or after a certain time.
For this thin you can try to recover the file with Recuva, here is the link :
http://www.recuva.com/
5. The battery in your camera is nearly empty, for this recharce/ by new ones (it depend if you use Rechargeable batteries)
Hope that helps, if not return here
Please rate my answer
Sep 04, 2009 | CyberLink PowerProducer 2 for PC
I had forgotten the password of my Cisco Catalyst 3550 Switch
password recovery procedure 3550 catalyst cisco switch
1>Attach a terminal or PC with terminal emulation (for example, Hyper Terminal) to the console port of the switch. Use the following terminal settings: ¨ Bits per second (baud): 9600 ¨ Data bits: 8 ¨ Parity: None ¨ Stop bits: 1 2>Unplug the power cable. 3>Power the switch and bring it to the switch: prompt 4>Issue the flash_init command 5>Issue the load_helper command. switch: load_helper switch: 6>Issue the dir flash: command. Note: Make sure to type a colon ":" after the dir flash.
7>Type rename flash:config.text flash:config.old to rename the configuration file. 8>Issue the boot command to boot the system. switch: boot Loading "flash:c3500xl−c3h2s−mz.120−5.WC7.bin"...############################### ################################################################################ ###################################################################### 9>Enter "n" at the prompt to abort the initial configuration dialog. −−− System Configuration Dialog −−− At any point you may enter a question mark '?' for help. Use ctrl−c to abort configuration dialog at any prompt. Default settings are in square brackets '[]'. Continue with configuration dialog? [yes/no]: n !−−− Type "n" for no. Press RETURN to get started. !−−− Press Return or Enter. Switch> !−−− The Switch> prompt is displayed. 10>At the switch prompt, type en to enter enable mode. Switch>en Switch# 11>Type rename flash:config.old flash:config.text to rename the configuration file with its original name. Switch#rename flash:config.old flash:config.text Destination filename [config.text] !−−− Press Return or Enter. Switch# 11. Copy the configuration file into memory. Switch#Type rename flash:config.old flash:config.text to rename the configuration file with its original name. Switch#rename flash:config.old flash:config.text Destination filename [config.text] !−−− Press Return or Enter. Switch# 11. Copy the configuration file into memory. Switch#copy flash:config.text system:running−config Destination filename [running−config]? !−−− Press Return or Enter. 1131 bytes copied in 0.760 secs Sw1# The configuration file is now reloaded.
Destination filename [running−config]? !−−− Press Return or Enter. 1131 bytes copied in 0.760 secs Sw1# The configuration file is now reloaded. 12>Overwrite the current passwords that you do not know. Choose a strong password with at least one capital letter, one number, and one special character. Note: Overwrite the passwords which are necessary. You need not overwrite all of the mentioned passwords. Sw1# conf t !−−− To overwrite existing secret password Sw1(config)#enable secret <new_secret_password> 13>!−−− To overwrite existing enable password Sw1(config)#enable password <new_enable_password> !−−− To overwrite existing vty password Sw1(config)#line vty 0 15 Sw1(config−line)#password <new_vty_password> Sw1(config−line)#login !−−− To overwrite existing console password Sw1(config−line)#line con 0 Sw1(config−line)#password <new_console_password> Write the running configuration to the configuration file with the write memory command. Sw1#write memory Building configuration... [OK]
Mar 24, 2009 | Cisco Catalyst 3550-24 24-Port Ethernet...
ASUS P5VD2-MX SE Motherboard Logo
49 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
