Question about Sony Uncharted: Drake's Fortune
Which way do the statues face inward or outward
  • 105 Answers
There is a compass on the floor. Match the direction of the statue to what the journal says. The direction of each statue is written in the journal.
Posted on Jul 15, 2009
Yer i no you have to match it to the journal, i have done that , nothing hapens, how do i no i have done it right?
Posted on Jul 16, 2009
Cannot pick up the statue in the rotating room for Mystery of the Mummy..level 3. I can get into the next room and solve the water puzzle and get the chess board but I can't solve that puzzle because I...
I found this walkthrough for the DS version By: perseaphone@yahoo.comHopefully it will work for pc as wellTo help keep yourself oriented in here: there are a total of 4 statues. Two on eachside that face each other. On one side you will see that the statue closest to the door has a crooked staff in hand and the other statue has a spear. The opposite wall has the statue with the spear closest to the door and the other statue holding the crooked staff in the back. Click on the center of the room until you are facing two of the statues and can reach them. Click on each statue once. Turn and click on the center of the room until you are facing the other two statues and can reach them. Click on each of these statues once. A panel in the floor next to the door you came in should pop open if you did it right and you need to work your way back there and pick up the STATUE. Click on the center of the room until you are in the center again. Your objective is to now reach the door opposite the one you came in. *NOTE: I found that once I got to the center of the room and then clicking towards the statues OPPOSITE the door I really wanted to go to, I was able to get to the door I needed.
Mar 21, 2011 | DreamCatcher Interactive Sherlock Holmes...
Doe the relays on the board face inward or outward
Hi, the relay can be placed either way that it will fit. See the bottom of the following post for an explanation of why this is true: http://www.fixya.com/cars/r6022358-relay_check
Mar 12, 2011 | Chevrolet Camaro Cars & Trucks
I just need to know whether the filter is installed with the black side outward or inward facing.
The coarsest side of the filter should be facing the dirty side of the airstream. The dirt / air should pass through the coarse side of the filter before exiting the finer side of the filter.
Hope that helps.
Mar 05, 2011 | Vacuums
WHICH WAY SHOULD FANS BLOW INWARDS OR OUTWARDS?
Outwards, on a DLP, however on the Philips 2.0 chassis the front lamp fan blows inward and the rear lamp fan takes it out. They actually have 3 fans.
Dec 09, 2010 | Televison & Video
2000 Nissan Pathfinder struts. The Haynes manual says that the notch in the upper spring seat is supposed to face outwards. The notch on the strut I removed was facing inwards. Which way is correct?
I know, right. I had the same problem using the Haynes manual when I replaced mine on my '97 4WD Pathfinderl. With the notch facing away from the vehicle, it does not look right, because the angle of the upper seat does not match the coil spring winding angle. I didn't take note of the location of the notch prior to removal. I still installed the upper spring seat with the notch facing outward per the manual. I still wonder if this is correct. What have you found out?
Aug 21, 2010 | 2000 Nissan Pathfinder
I dont understand the 4 statues they're facing the right way when i come to that part am i doing something wrong ? an when i do get statues in the right place where do i go then? i have been stuck on this...
If you look on the floor you will see where north, east, south and west is facing. If you check your journal, each statue will need to face the correct direction. Just match what the journal says to the compass on the floor.
Jul 12, 2009 | Sony Uncharted: Drake's Fortune
4 statues
Jun 27, 2009 | Sony Uncharted: Drake's Fortune
Turning the 4 statues, which way do each face?
Hit "Select" to check the journal entry, then use that to line the statues up. Each statue corresponds to a Gospel - Matthew, Mark, Luke, and John. Figure out which statue is which, then use the compass painted on the floor to point them in the right direction. Each statue has to face a certain direction (north, south, east or west), and when they're all properly aligned a door will open.
I got this from gamefaq
I hope it helps
Dec 30, 2008 | Sony Uncharted: Drake's Fortune
The sanctuary
Hit "Select" to check the journal entry, then use that to line the statues up. Each statue corresponds to a a Gospel - Matthew, Mark, Luke, and John. Figure out which statue is which, then use the compass painted on the floor to point them in the right direction. Each statue has to face a certain direction (north, south, east or west), and when they're all properly aligned a door will open.
hope it helps
Dec 27, 2008 | Sony Uncharted: Drake's Fortune
Sony Uncharted: Drake's Fortune Logo
292 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
