Question about Optoma H30 Multimedia Projector
No power I have my h30 pluged in to power supply and it does not turn on. What can I do?
  • Stulpas Nov 16, 2007
    Same problem.After replacing bulb,no power.Put the old bulb back (I was replacing it before it failed) ,no LED's blinking,wont power on.
  • Linna Jan 29, 2008
    I have no power, one day went to turn it on, and nothing... Help
I had to replace the internal fuse after my light bulb burst. You can remove the case by removing the screws on the sides and the carefully slide it off. The fuse is under a plastic cover by the power plug location. I'm not sure if this will fix your problem totally though. I just installed my replacement bulb and I get the solid orange light for 30 seconds and it goes into standby mode again.
Posted on Mar 28, 2008
Optoma EP781
if all lamp are red, and no light on, It is power supply issue,
you need to replace power supply, it will be ok.
you can send me your old power supply photos, perhaps i have same parts,
Jul 06, 2014 | Optoma H30 Multimedia Projector
Optoma H30 -- When turning on projector the green light on power button blinks and the projector sounds like it is going through a cycle....after the cycle the lamp light comes on and nothing comes on the...
If the lamp light is orange then the lamp ballast circuit or power to it is no good.
I presume the lamp is not on at all, and it's not the hide function that is stopping the light coming out.
Mar 10, 2011 | Optoma H30 Multimedia Projector
Hello, I have a phillips 1080p LCD HD 47
Replaced the backlight video board,u hear a click light on.The power board work.
Dec 10, 2009 | Philips 47 in. LCD HDTV
I have an optima EP 739 projector and I just replaced a bulb in it but it does not come on just green light whats up Any input would be appreciated
if the fans come on and the lamp doesn't, it's the ballast or the colorwheel. if no fans either, it's the power supply. also, did you reset the lamp timer?
Dec 07, 2009 | Optoma H30 Multimedia Projector
When power supply pluged in the wolfer makes loud noise
Try turning the volume down on your computer or on the woofer itself.
Nov 26, 2009 | Altec Lansing AVS 500 Computer Speakers
Panasonic pt-l780u projector lamp warning light comes on and lamp goes out. smell somthing burning. this is with three lamps. i am sure it's not the lamp.
the burning could be the dust on the inside burning off. blow the dust out with canned air. then check to see if the fans are spinning. after that, it's the ballast/power supply.
Nov 11, 2009 | Optoma H30 Multimedia Projector
Optima H30 warning
OK, found the solution on the net, you have to use the buttons on the projector instead of the remote to access the menu item.
Aug 25, 2008 | Optoma H30 Multimedia Projector
Sharp Lcd Projector XV-H30U
check to see if you got the covers for the filters in the back and the side? if you dont have the cover for either of these it will not power up it only turns on for about 2 seconds and then it dies. it has a switch that must be pressed in when the covers are on. without the covers it only powers only slightly. you can jimmy rig it if you dont have the covers. try puting in something that is nonmetallic to depress the switch if your missing either th back or the side cover.
Feb 20, 2008 | Sharp (RLMPF0014CEZZ) Projector Lamp for...
Optoma H30 Multimedia Projector Logo
199 people viewed this question
Top Optoma Office Equipment & Supplies Experts
color wheel light...
Are you an Optoma Office Equipment and Supply Expert? Answer questions, earn points and help others
