Question about Intermec EasyCoder 4420 Thermal Label Printer
Ink wont transfer to sticker on a 4420 intermec
Tried the roll of carbon on both sides and the yellow light is still on. ink wont stick on the sticker of a intermec 4420
how do i clean the printer head
  • 31 Answers
Make sure the "carbon" is down so that it gets transfer to the top of the label. I can check this by just scratching it with your fingernail and it should rub off. If you are sure you have the media loaded correctly and the ribbon and label are a compatible match then you might just need to increase the heat or darkness setting on the printer. Some ribbons require a higher heat setting to transfer the carbon.
Posted on Jun 30, 2009
I have two identical 4420 printers. suddenly one prints much slower than the other. What mechanism needs replacing? I don't have any manuals or anything
I think parallel port issues. Assuming your fastest printer connected to onboard parallel port. connect slow printer on pci2parallel port.
Sep 18, 2014 | Intermec 4420e Easycoder Thermal Transfer...
Yellow light is lit (Empty/Pause) but there is paper in printer.
I've found that if the ribbon core is slipping on the TTR supply hub, it causes the ribbon sensor to think the ribbon is not moving. This, in turn, causes the yellow light to come on. Take off the ribbon and replace hub core locking bracket (p/n: 065375-003). I have also found you can bend the bracket enough to work if you don't have any on hand. I hope this helps with your problem.
May 03, 2011 | Intermec 3400E Thermal Label Printer
We have 2 Intermec 4420 printers. We printed the same label out on both printers. Our scanner reads one but won't read the label from other printter. Why do you think this is happening?
if you use the same resolution, and the same print speed, check the temperature use to perform the transfer. The barcodes are not correctly printed on one of your printer.
Feb 10, 2011 | Intermec EasyCoder 4420 Thermal Label...
Does my SHARP UX-266 take ink? if so WHAT TYPE?
In a sense, it does use ink.
In the form of a film, like carbon paper. you can get replacement rolls here, or just type in your model number and film in to a search engine.
http://www.officeworld.com/supplies-finder/Sharp--UX-P200--thermal-fax?gclid=CMuQvazhhaUCFYdc2goddDh1NQ
Good luck.
Nov 03, 2010 | Sharp UX P200 Plain Paper Thermal transfer...
Good day, I need the Intermec 4420 service manual, could you help me?
Contact Intermec Support at
Intermec Repair Center
13509 Southpoint Blvd. Suite 100
Charlotte, NC United States
28273-6759
Telephone: 800-755-5505
Intermec doesn't put service manuals on their website. You may run into issues if you are not Intermec service certified.
Cheers
Billy Barcode
1-866-306-7226
May 01, 2009 | Computers & Internet
Ricoh Aficio CL3500N is now printing all documents with lines/streaks all down the left margin of the page. What do I clean or replace to get rid of these unsightly lines printing on every page?
you can try printing a page in black only, then one page each in the 3 other SINGLE colors: Cyan, Magenta, and Yellow. this will eliminate/ confirm one of these causing problem.
the replacement of Transfer Belt Cleaner or Cleaner Assembly is another to try after the above separate-color thing. see if there's a status page of life remaining on replaceable items, including the Transfer belt assy.
i'll assume you didn't scan the job- - this isn't a multifunction scanner/printer type machine?
ok, next in line is to check the Fuser unit, the part on the upper left side/top of printer. if the same streaks appear on the Main fuser rollers, these fuser units cost about 350 bucks. there is also a Fuser Kit, which costs much less, but its job is to add Fuser Oil to the fuser unit and keep paper and ink from sticking.
a guy could suffer sticker shock from the costs of running one of these, considering you could drop a grand buying all 4 drum units, a fuser unit, and a transfer belt assy. . . .
Feb 16, 2009 | Ricoh Office Equipment & Supplies
Changed roll of labels, now it won't print...
Warren
one side of the paper will be sensitive to heat and the other side won't be. If it is thermal paper run a pen without the actual ink part sticking out of the pen or use a key from your key ring in your pocket over the paper the friction should leave marks on the thermal side of the paper.
you may have the paper in with the non thermal side facing the heat printing part of the paper. Or you have the wrong paper.
http://www.microtrade.com.au/zebra-printer-ribbon-suits-tlp2824-plus-label-printer/?gclid=Cj0KEQiAuonGBRCaotXoycysvIMBEiQAcxV0nOLqC5Do2fiZih4Z19jw389fNmbkQXNwgUfYVzkqdSgaAhbc8P8HAQ
ld4028-10a or ld21084 may be the label ? not sure its 40 mm wide not 55 mm or 2.2 inch
Mar 10, 2017 | Zebra LP 2824 (clp2)
I have a solid ink 8560 that has an error 09,037.45:5047, Yellow ink error. How can I resolve?
That is a yellow stick count fault.
1, If you happened to put 2424 ink sticks in it, they have a different bottom and wont actuate the sensor. A stick is either broken, or otherwise stuck in the slot.
That code is the yellow . You could have a bad ink loader, but very unlikely. Check the free movement of the sticks.
Apr 24, 2008 | Office Equipment & Supplies
Problem with Intermec 3400 ribbon supply
Just take the head of ink outside and clean it carfully and return it back it will work. use clean solution.
Apr 04, 2008 | Intermec EasyCoder 3400 Thermal Label...
Intermec EasyCoder 4420 Thermal Label Printer Logo
143 people viewed this question
Top Intermec Office Equipment & Supplies Experts
Paul Bade
Don  Farrell
Don Farrell
Arizona Information...
Are you an Intermec Office Equipment and Supply Expert? Answer questions, earn points and help others
