Question about Garden
Engine starts cuts out when trigger squeezed
Engine starts stalls out when trigger squeezed
  • 508 Answers
Plugged fuel filter or bad gas
Posted on Jun 27, 2009
No pressure once trigger is squeezed
We will have to just guess what this trigger is on :>)
AR Blue Clean - Spray Gun Trigger Squeezed, No Water Pressure
https://www.arblueclean.com/.../ar-blue-clean-spray-gun-trigger-squeezed-no-water-p...
When the spray gun trigger is squeezed, water comes out but there is no pressure. ... The RED color must stay in the window once the button is released.
pressure washer won't start unless trigger is depressed - Shop Your Way
https://www.shopyourway.com/questions/1151701 Jan 11, 2012 - pressure washer won't start unless trigger is depressed ... Thank you for your question on the pressure not starting unless you have the trigger pulled. ... After about 4 or 5 pulls the pump has built up enough pressure to make it ...
Pressure Washer Troubleshooting In-depth Beginner's Guide
pressurewashr.com/pressure-washer-troubleshooting/ Jul 5, 2017 - After holding the trigger to keep the water running through the machine ... (but not water supply) and release pressure by squeezing trigger gun.
Nov 21, 2017 | Garden
How do I get this tool apart to clean it.
Think you need to replace the motor brushes. As they wear they get shorter and the spring that pushes them up against the commutator is now at the end of its travel. Replace brushes or stretch the spring a tad.
Feb 14, 2016 | Saws
Erratic starting circular saw
Sounds to me like you have a bad cord. Clamp the saw to a workbench so that it can start and run safely without you having to hold it. Put tape or a wire tie around the trigger to hold it in. THEN plug it in. Then move the cord around, especially near where it enters the saw. If the saw starts and stops intermittently you have confirmed the bad cord. Good luck.
Mar 06, 2013 | Saws
I have a poulan pro chainsaw it runs fine when choked but when i squeeze the trigger it dies what is wronr with it
It is running too lean, start with the simple things first, replace the fuel filter in the tank, check all the fuel hoses for signs of damage or fuel leaks, replace as required, if all these things are ok, you need to richen up the mixture screws on the carb ( you may need special tools to do this if they are anti tamper screws ) unscrew 1/8 turn on each and try again.
Oct 17, 2012 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Turn on machine starts then cuts off
Does the unit turn back on after you squeeze the trigger on the wand? If so, your unit is equipped with a high pressure cut off switch.
Jul 01, 2011 | Karcher K 593 M Electric Pressure Washer
After you clean and rebuild a tillston carburetor where do you set the air mixture jets to start
Hi, Turn the L and H screws in gently until they just stop turning (no force at all) first. Then back them off 1.25 to 1.5 turns from closed. Set the L speed first unit running so that the unit does not stall when trigger is squeezed and then MAX throttle adjust the H screw until you get max speed. Recheck for stalls when trigger squeezed again and repeat above steps until you have no stalls / hesitation and max speed.
ADJUSTMENTS should not be much more than the width of a screwdriver blade on either screw before re-testing. Never more than 1/8 th turn per adjustment for sure.
Kelly
Jun 24, 2011 | Garden
Engine starts easily and then stalls, is hard to restart
If the engine dies shortly after start. Squeeze the spray wand trigger to release pressure on the unit. When restarting let the engine run for a few min(2-3 no more) to warm up, the unloader valve on the pump should keep pressure to a minimum. If the engine stalls or will not run you need to check your carburetor and clean it. BECAREFUL as FUEL is FLAMMABLE and there are small parts in the carb float bowl that like to get lost. A rebuild kit for most carbs is less than $8USD and a can of spray carb cleaner about$2-3. Install a fuel cut off valve($6) to keep the carb from gumming up again. Shut off the fuel when not in use or for periods of prolonged storage. Take a picture of the carb on the engine(my memory is bad) and during disassembly to assure you get it back together properly. The idle screw should be turned in(to the right)till it seats lightly then backed out 1&1/2 to 2&1/2 turns to start with. After starting the engine adjust for good idle and running buy turning in or out to attain the best idle. If this is helpful, Please leave Feedback. Thanks, SnugglePants
Oct 21, 2009 | Coleman Garden
Gas engine will not start without pulling trigger on wand to relieve pressure-engine dies when letting off trigger
I am afraid that is how they work even electric ones wont start unless you squeeze the trigger ,once they are running you should be ablr to release the trigger , and then squeeze it again whilst running . if yours dies when you release the trgger while motor is running -----good chance you are working at too high pressure. but to start you have to release all the internal pressure
Aug 22, 2009 | Campbell Hausfeld 2000 Psi Gas Pressure...
Pressure washer stalls out when wand nozzle is released
common for not starting unless trigger engaged as you are turning the pump as well as engine creating pressure,as for stalling pump has unloader valve which is probably in need of grease(use good silicone grease)this allows water to ciculate when trigger released.
Apr 19, 2009 | Campbell Hausfeld Garden
Garden Logo
171 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
