then the ones not working r probably ran together pull out radio and check speaker wire connections,if that doesnt work run the back speaker off the other back speaker , then do same w front , or if that doesnt work maybe speakers r blown out ,
demo will not go off . I tried holding menu down and nothing. Was working fine, then I took the...
(More)
demo will not go off . I tried holding menu down and nothing. Was working fine, then I took the plate off when I put it back on nothing just Demo.
Had prior problems with unit going into demo mode and was able to fix the problem before, but not...
(More)
Had prior problems with unit going into demo mode and was able to fix the problem before, but not any more. Still I followed directions to push and hold menu button for 10 seconds to goto next option, But nothing I able to listen to CD's with no volume control? So I gave up and bought new radio today.(Tried cleaning contacts on detachable face too!)
i have a 97 saturn sl1 and an aiwa cdcx204 and cant wire the harnesses together properly can you...
(More)
i have a 97 saturn sl1 and an aiwa cdcx204 and cant wire the harnesses together properly can you help
