Question about Dishwashers
My McClary dishwasher does not drain properly - the outflow is much reduced. My guess is that hose/pump is clogged with debris. What parts in the pumps and drain assembly do Check?
    President:
  • 3,085 Answers
It could be the small black FLAPPER in the pump motor has broken off and is blocking the pump outlet.
Posted on Jun 28, 2009
My dishwasher will not drain
It can bequite common for a dishwasher to not drain because either the drain hose or theair gap (if the unit has one) is clogged up. Drain hose clogs commonly occurwhere the hose is attached to the main household drain line, or where the hoseconnects with the garbage disposer. Turn mainswater off and disconnect mains power Tryremoving the drain hose to unclog any debris. Don't forget to reattach the hosebefore you start your dishwasher again.The drainpump is blocked or restricted by debrisPossibly something stuck/jammed in the wash or drainpropeller, remove filter mesh at the bottom of the dishwasher. Carefully remove any excess water and debris jammed near the propeller caution there may be glassor debris near or where the water drains-out.Removeand clean the spray arms, they may have food debris jammed, rinse in hotrunning waterMaintainerWash Runa wash with a tablespoon of powder, without any dishes on the hottest settinge.g. intensive, 65C, if you have a 70C this will be more effective.
Apr 07, 2012 | Maytag 24 in. MDB5600A Jetclean II...
Whirlpool gu1200xtls2 wont drain just stopped
Hello
your Whirlpool dishwasher stopped draining mid-cycle, check your circuit breaker or fuses. The cycle won't complete if the power is interrupted. Reset the circuit breaker if tripped, or change out any blown fuses. Fully close the dishwasher door, and restart the cycle if you opened up the door. If you have not used the dishwasher in a while, the motor may be stuck. Open up the main housing, and rotate the motor until it turns freely. You must replace the motor if it's corroded or won't move since it's unlikely that you can fix it.
Pump
The pump is located underneath the lower rack and spray arm. This component is responsible for pumping water out of the dishwasher once the cycle is complete. If the pump isn't working, verify that it is not clogged with debris. Use a toothpick or plastic utensil to remove food particles from it. Check the pump impeller. If a section of it is broken, get a new pump since the impeller is difficult to fix.
Clogs
Clogs in the air gap or drainage hose prevent water from leaving the tub. Clean these components and the water inlet filters, if dirty. Examine the drainage hose, and straighten it if it's kinked. If the hose is badly crushed, you must replace it. Unscrew the drainage hose from the dishwasher to clean it, but reattach it before you restart the cycle. Run the food waste disposer if it's connected to your Whirlpool dishwasher. Remove the knockout plug from the disposer if you have just installed the disposer or dishwasher.
Drain Valve/High Drain Loop
Whirlpool dishwashers have drain valves with an internal solenoid. This valve opens and closes to drain water out of the tub. If the drain valve is stuck, lubricate the lever, and remove any debris clogging the valve. Remove any objects that are preventing the drain valve from freely opening and closing. If the valve is not working properly, you must replace it. Always install a high drain loop to prevent water from the sink entering your dishwasher. Create a loop of the drainage hose that is at least 18 inches high. Attach this hose beneath a section of cabinetry.
Sep 28, 2011 | Whirlpool Dishwashers
Hi I have an Bosch SGs43c02gb/35 and it does not drain all of the water out when it has finished the cycle, I have cleaned the filters out which were relatively clean and run it with a dish washer cleaner...
Hello
It is quite common for a dishwasher to not drain because either the drain hose or the air gap (if the unit has one) is clogged up. Drain hose clogs commonly occur where the hose is attached to the main household drain line, or where the hose connects with the garbage disposer. Try removing the drain hose to unclog any debris. Don't forget to reattach the hose before you start your dishwasher again.
The pump assembly is comprised of a pump, wash impeller, and drain impeller. The pump ejects the water from the unit, the wash impeller pushes water through the spray arm, and the drain impeller directs the water towards the drain port. Examine your dishwasher's pump assembly. Clean out any debris that may be blocking it. Replace the pump assembly if any of its parts appear to be worn or defective.
It isn't very common, but sometimes a dishwasher's pump assembly is driven by a belt. If that belt becomes worn and defective, then it cannot properly run the pump that drains your dishwasher's tub. If your dishwasher uses a drive belt, examine it now. If it shows signs of wear, replace it.
A defective timer could interfere with a dishwasher's ability to drain properly. Test your dishwasher's timer mechanism. If it is faulty, replace it. Keep in mind that you can replace either the entire timer assembly or just the timer's motor.
The motor plays a key role in a dishwasher's ability to drain water. If your dishwasher's motor is not functioning properly, it will negatively affect the draining capability of your machine. Test your dishwasher's motor for continuity. If it fails the test, replace the motor.
In some models, a valve has to open in order for the water to drain out of the dishwasher. This valve is controlled by a solenoid, but it is the timer that decides when the valve should open. If your timer is working fine, check the drain valve and its solenoid. If need be, replace them.
Aug 20, 2011 | Bosch 24 in. SGS43C12 Classixx...
Dishwasher will not drain
Hello, Following things should be checked properly to see what actually the matter is.
1)Drain Hose It is quite common for a dishwasher to not drain because either the drain hose or the air gap (if the unit has one) is clogged up. Drain hose clogs commonly occur where the hose is attached to the main household drain line, or where the hose connects with the garbage disposer. Try removing the drain hose to unclog any debris. Don't forget to reattach the hose before you start your dishwasher again. 2)Pump Assembly The pump assembly is comprised of a pump, wash impeller, and drain impeller. The pump ejects the water from the unit, the wash impeller pushes water through the spray arm, and the drain impeller directs the water towards the drain port. Examine your dishwasher's pump assembly. Clean out any debris that may be blocking it. Replace the pump assembly if any of its parts appear to be worn or defective. Belt It isn't very common, but sometimes a dishwasher's pump assembly is driven by a belt. If that belt becomes worn and defective, then it cannot properly run the pump that drains your dishwasher's tub. If your dishwasher uses a drive belt, examine it now. If it shows signs of wear, replace it. 3)Timer A defective timer could interfere with a dishwasher's ability to drain properly. Test your dishwasher's timer mechanism. If it is faulty, replace it. Keep in mind that you can replace either the entire timer assembly or just the timer's motor. 4)Motor The motor plays a key role in a dishwasher's ability to drain water. If your dishwasher's motor is not functioning properly, it will negatively affect the draining capability of your machine. Test your dishwasher's motor for continuity. If it fails the test, replace the motor. 5)Drain Valve and/or Solenoid
In some models, a valve has to open in order for the water to drain out of the dishwasher. This valve is controlled by a solenoid, but it is the timer that decides when the valve should open. If your timer is working fine, check the drain valve and its solenoid. If need be, replace them. Thanks
Jun 17, 2011 | Maytag Dishwashers
I have a LG LD 2140WH diswasher, it only works for 2 min then give a OE error code. what can be wrong
The possible reasons could be
1. If the drain hose is kinked, water will not drain properly. Kinks will also catch food debris as it passes, clogging drain hose. Straighten any kinks or bends in the hose. Make certain that drain hose does not exceed 10 feet for proper drainage.
2. Check the drain air gap anytime the dishwasher is not draining properly. if the air gap is clogged the unit will not drain. The air gap is not part of the dishwasher. It is located on the sink and attached through the drain hose and garbage disposal. Not all homes are required to have an air gap installed.
3. Food residue or particles can prevent proper draining of dishwasher. Remove bottom rack and check unit for food debris or items that may have fallen into the bottom of the unit. Remove any items or food debris that may be preventing proper drainage.
4. If the unit is not leveled properly, OE Error may occur. Use a level to check sides and top of unit. if the unit is not level, adjust the leveling legs in the front and back (use leveling kit). Also check the mounting brackets. If one is tightened more than the other, it will offset the cabinet.
* Note: To adjust leveling legs on the front, use a 1/4" square drive wrench. Turn clockwise as needed to adjust level. To adjust rear legs, use a standard Phillips head screw driver. On the left side rear, turn the screw counterclockwise to lower the leg and raise the rear. To adjust right side rear, turn the adjusting screw clockwise to lower the leg and raise the rear of dishwasher. Using a level while adjusting the legs will help aid in proper leveling.
May 27, 2011 | LG Dishwashers
After starting the dishwasher with time 56 min, the time goes down to 55 min and after that time remains 55 min. After few min there it showed 0E in the display bar and it stopped working. Is that...
May 02, 2011 | LG Dishwashers
Water is clogged in the bottm of the unit. how do I clear the drain?
The drain filter is clearly visible at the bottom of the wash compartment but there are several possibilities as to why there is still water in the bottom of your washer:
1. Blocked drain filter
At the bottom of the wash compartment, there is a fine mesh grille and a plastic cylinder which protrudes from it. Grip the plastic cylinder, twist anti-clockwise and pull it upwards. To clean it, remove any debris from the cylinder, rinse then replace in reverse order of the above.
2. Blocked/kinked waste hose
Check the waste outflow hose at the back of the washer for any kinks or other damage. Also remove the hose where it attaches to your sink (or waste outlet) and check for any blockages.
3. Blocked waste disposal / sink trap / waste outflow
Make sure your sink is draining efficiently. Clean as necessary
4. Faulty waste pump
If all of the above check out, you may have a faulty pump. Please post back for further advice regarding this after completing the above checks.
Regards,
BElectric
Nov 11, 2010 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
WATER DOES NOT DRAIN COMPLETELY
Your dishwasher's drain pump is not designed to work until the water is completely drained but rather in sync with the timer. The motor will stop when the timer stops no matter how much water is left inside the machine.
In your case, either of the following is causing the trouble:
  1. There's a part clogging in the drain line.
  2. A debris is caught in the drain pump impeller.
  3. Drain valve is not opening completely.
  4. Worn belt if your washer uses a belt to drive the pump.
Here's the remedy to each of them:
  1. Remove the drain line to clear any debris from the hose or hose connection at the household drain line connection. Reattach the hose before starting the dishwasher again.
  2. The drain pump is usually mounted directly to the motor and attached to the bottom of the dishwasher. Remove the lower rack, the spray arm, and the spray arm support to reach the pump from inside the dishwasher. Look for the wash impeller, which forces the water through the spray arm. Beneath it is the drain impeller, which is similar in size and shape to the wash impeller. Clear the drain impeller from any debris that prevent it from pumping out water properly.
  3. Sometimes the drain valve solenoid or the diverting lever sticks and prevents the dishwasher from draining properly. Lubricate the lever to free it up. Replace it otherwise.
  4. If your machine uses a belt to drive the pump, the belt may have been worn and cannot drive the pump properly. Replace the belt if that is the case.
Feel free to give updates.
Dec 01, 2009 | Maytag Dishwashers
MY SON'S DISHWASHER WON't drain
Hello there:
Please try these things below my post and click on the links that are available for you ok
I hope that tthis is very helpful for you
best regards michael
Water will not drain from my dishwasher. Investigate these six areas if water will not drain from your dishwasher :
dishwasher_drain-hose.jpg Drain Hose
dishwasher_pump-repair-kit.jpg Pump Assembly
dishwasher_belt.jpg Belt
dishwasher_timer.jpg Timer
dishwasher_motor.jpg Motor
dishwasher_drain-solenoid.jpg Drain Valve and/or Solenoid
Nov 14, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
Main sink and d/w did not drain. Used plunger heavily. Did not work. Had main line jetted out. Now sink drains but d/w still does not. Older model Kenmore #1661590 Thank you
Hello playultimate,
I am assuming that your dishwasher drains either directly into your sink or through a garbage disposal as part of your sink. Regardless of which method is used, you need to verify that your dishwasher drain system is funcioning properly so.. make sure your dishwasher drain filter is free from debris.. if you are still having a problem ..it could be the pump is defective or clogged with food byproducts, the lines into and out of that pupm are clogged of the drain hose itself is clogged or pinched.. Once you have cleaned your drain screen inside the dishwasher, .. try cycling it withour dishes to see if you get a reasonable drain flow .. The key is to identify if its a clog/restriction or a bad pump... Hope some of these ideas will help solve your problem.. Get back to me if you are still struggling..
Regards,
Rick
Dec 06, 2008 | Dishwashers
Dishwashers Logo
275 people viewed this question
Top Dishwashers Experts
