Has new plug, cleaned carb, clean gas,
SOURCE: i already cleaned out the carb. the mower will
still sounds like not getting fuel ,did you soak the carb in something overnite,this is what I do ,sometimes just a spray out wont help.how old is mower?
SOURCE: I have a yard machine
Your carbs main jet is blocked. Using the primer supplements the fuel input and keeps the engine from becoming fuel starved.
You need to remove the main jet and run a strand of fine wire through the jet to clear it.
Hi, check your valve clearances,if they are to tight you will have low compression and the noted fuel blow back in your carby, regards Phil.
Tecumseh engine right? Pull the float bowl off the carb. I suspect some water contamination. while it is off clean the jet holes in the nut. They may have varnisized gas in them. contact me with any more questions.
