FixYa.com
Tags:
Kitchen Ranges
Generic problem for all Kitchen Ranges
Error code (by 3 users)
posted by imgoofy on Nov 06, 2007
I was cleaning my ge range when an error code appeared, F7 dc. I pressed off, then turned the breaker off to the oven. When I turned the power back on the error code reappeared. What can I do next?
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
2 Other Users Have The Same Problem
Comment by daughtkom, posted on Jan 12, 2008
I Have a GE JSP42SKSS (stainless) and am getting "F7 E6" as the error code. It looks like I'm going to have to replace the key pad?
Comment by roe roe, posted on Dec 09, 2007
I turned my oven on to preheat and the F7 code came on...the only way to stop it was to turn the breaker off...what do you think the problem is?
Best Solution
posted on Nov 06, 2007
FixYa! (100)
jsrock516
Rank:Guru Guru
Rating: 94%, 1646 votes
All the information I could find on GE ranges indicate that an F-7 error indicates a problem with either the Electronic Range Control (ERC) keypad having a stuck key, or the ERC itself being defective. You can unplug the ribbon cable on the ERC and wait at least 32 seconds before plugging it back in to see if the problem clears. If the problem persists you will have to replace the ERC. Make sure you UNPLUG the range and/or turn off the main breaker to it BEFORE servicing. Remove the back panel of the range to access the ERC. If you cannot get the fault to clear and wish to replace the ERC, post back with comments as to your model number (usually located on the frame of oven door opening or lower drawer opening) and I will research to find a part number for you. Keep in mind, most ERCs do not come with the overlay (plastic piece with the number and keypad displays). I would advise you to replace both if you decide to repair the range. i hope this info helps you.
Was this solution helpful? Show your Appreciation by rating it:
This Problem Also Relates To: GE Spectra JBP78 Electric Kitchen Range GE JGBP26 Gas Kitchen Range GE JBP81SKSS Stainless Steel Electric Kitchen Range GE JBP72SKSS Stainless Steel Electric Kitchen Range GE JBP64 CleanDesign Electric Kitchen Range GE JBP66 Electric Kitchen Range GE JBP15 Electric Kitchen Range
Can you Help with these Kitchen Ranges problems?
Jenn-Air JDR8895AAS Dual Fuel (Electric and...
Jenn-Air Oven Door Lock...
My husband stopped the cleaning... Answer This...
Jenn-Air SVE47100 Slide-In Electric Kitchen...
Spacer for back of Range
Does Jenn Air make a spacer for... Answer This...
Kitchen Ranges
oven stop working when code
oven stop working when code f1... Answer This...
Kitchen Ranges
User Manual for Belling...
I have inherited a Free... Answer This...
Kitchen Ranges
F1 diplay on dropin range
F1 diplay on dropin range Answer This...
Repair Service
Find Kitchen Range Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
