Question about Intex Automatic Salt Water System for Above Ground Saltwater Pool
I have an intex chlorinator and an intex 24' x 48" round pool. I added only 250 lbs of salt, but the table said 290 lbs. I never got a "low salt" reading. When the water level got low I added water and forgot about it, so it over flowed. I still didn't get a low salt reading. Now my water is GREEN. I added 50 lbs of salt, ph down and super shock. It clerared up for a day then turned green again. The test strip says the ph and alkalinity is ok, but the free chlorine is off the chart. It's a dark sage green.
  • Anonymous Mar 30, 2014
    Chloromatic screen is showing 2 green LEDs but is in standby mode with no digital display. Pool has no chlorine detected on a test strip
    Choromatic ESR 200 displays 2 x green LEDs & 2 x red standby LEDs. There are no numbers displayed which is not normal & the test strips used show no chlorine in water
  • 297 Answers
High chlorine can cause problems too it will give false readings for your ph and alkalinity.
The most important thing to remeber is that there is a sequence to follow.
First buy a test kit for salt about 11 bucks for 10 tests. you need to have the ppm's at 3000
if it is to high drain 20% water re-fill and filter/curculate for 6 hours then test again. once at 3000 then go for your chlorine it should be between 1.0 and 1.5 with a test kit now with those 2 in line go for ph adjustment ph should be as close 2 7.6 as possible. Ph will cause more problems like cloudy water or algea more than anything else.
another thing you need to realize is that the intex salt system sucks. Once you set it for the # of hours to chlorinate you are basically guessing as to what is needed. Yes there is a guidence chart as to hours to run but it is over kill and lets too much chlorine be generated start with 3-4 hours of generating but remember also that at 4 hours generating that is nowhere near enough filtering
you will need to shut power off get it out of sleep mode and continue to filter
on avberage a pool should be turned over 3 times a day my pool 7000gl and the 2000gph all in one intex salt pump needs run at least 10 hours a day alone without the chlorinator
my pool only 18' so with your total gallons it will be longer
one last thing to consider is that when in chlorine generating mode the filter slows down because of all the electronics. You can not hear it happen but if you put your hand in front of the discharge you can tell
Posted on Jul 09, 2009
How much salt do you put in a 22,000gal. pool?
WOW... You have a huge above ground pool! Are you planning to use the Intex chlorinator to chlorinate your 22,000 gallon pool??? If you are, take a look at the max gallon rating and how long you may need to run... Here's a chart that should help you determine how much salt to add... After adding the salt, run the pump for 24 hrs without the chlorinator to properly dissolve the salt... Don't be surprised if you need to add above 500 lbs!!!
Good luck and hope this works for you...
Aug 22, 2011 | Intex Automatic Salt Water System for ...
My water is cloudy and says low salt. I added 120 lbs and it still beeps low salt. I have a CS8111 saltwater system & filter combo. It is on an above ground pool 24' X 52".
Check the electrolytic cell!!! You will get a low salt alarm if cell has calcium or sodium build up.. If it does, soak, flush and clean with vinegar.. Also, make sure you run the pump only, no chlorinator for 24 hrs to properly disolve the salt you just put in....
Aug 05, 2011 | Intex Automatic Salt Water System for ...
My pool is cloudy and I added clarifier and it still won't clear. I checked the salt count and it's reading 1100 ppm. We have a 15 foot round 48 inch deep pool. I also shock the pool weekly...
1st... Your salt count should be at 3000 ppm... For your size pool, the start-up salt needed should be about 95 to 110 lbs..
2nd... Run your pump for 24 hrs without the chlorinator after you have reached the 3000 ppm to properly disolve the salt and use only "pool salt"
3rd... Set your pump at 12 hrs and your chlorinator at 10 to 11 of those hrs until you have reached the desired chlorine level.
4th.. After your pool water has cleared, within 2 to 3 days...clean your chlorinator electrolytic cell and adjust your time down to maintain the proper chlorine level..
Hope this helps and if it does, please rate and comment....
Good Luck!!!
Jul 31, 2011 | Intex Automatic Salt Water System for ...
Once a week I've been adding salt (80 lbs) to my pool and again get low salt code (91)....it has been very unusually hot (HTX 110) is this causing the problem and I need to add more?
1st... Check your salt level consentration.. If okay... 2nd, Check you electrolytic cell, may be plugged with white flaky calcium stuff. The white calcium build-up on the cells will cause a low salt alam.
Jul 21, 2011 | Intex Automatic Salt Water System for ...
We have a Krystal Clear Saltwater System Model CS8110. We are first time pool buyers. We set up the pool last week and despite several "boosts" the chlorine level is very low. The pool store...
You should always follow the instructions on the manual .. I have a 18X33X4 oval and had to start with over 350 lbs of salt and ran the pump without the chlorinator for 24 hours to properly disolve the salt. Then, I started with 12 hrs pump cycle with 10 hrs of chlorination in between the 12 hrs. Keep checking the chlorine level and adjust time from there. Currently at temperatures of 85 to 100, I run the system at 10 hrs pump with 8 hrs chrlorinator and water is Crystal Clear... In the 2 years with the intex system, I have not added any chemicals to my pool. I once had an issue when the water level went low while I was on vacation, when I came back, the chrolinator had turned off due to low flow and my pool water was green.. As soon as I re-started the cycle, a few days later, Crystal Clear again... NO CHEMICALS OR SHOCK added.... Hope this helps....
Jul 15, 2011 | Intex Automatic Salt Water System for ...
We have a 15' by 48 " pool with an Intex saltwater chlorinator.About two weeks ago the low salt light started flashing .We ended up adding way too much salt (160 lbs)because the low salt light kept...
First of all green water can arrise from a lot of different situation.
Low chlorine is one of them coupled with the crappy filter that comes with the intex pools it does not filter enough.
Start with getting your salt level to 3000ppm
any lower than 2700 and you will not generate enough chlorine and any higher than 3500 and you could go cloudy or trigger high salt alarms
you need to get the salt test kit that reads in #'s not color the color ones has to much of a variance
once your salt is at 3000 clean your cell then filter filter filter
I run my filter 24/7 if it is not generating chlorine I am filtering.
Clean your cartridge every few days
I have had the same 2 cartridges for this being my 4th season and have never been green or replaced the filters.
Also I reccomend a non foaming algecide
Just follow directions on bottle
Aug 29, 2010 | Intex Automatic Salt Water System for ...
Just added an Intex salt water Gernerator to my existing above ground pool. Water is green, can I add chlorine shock to speed up the process. And Ph is low. Can i add PH increaser or should I just wait and...
Yes, you can add chlorine. Liquid chlorine will raise the ph a bit. Don't know what kind of shock you are adding, but wait a day, recheck ph level, than adjust.
Apr 18, 2010 | Intex Automatic Salt Water System for ...
No chlorine reading
Salt is sodium chloride, you can only measure salt levels now as your CL (cloride) is bound to a NA (sodium). Table salt =NACL, Your Intex system will tell you if your salt level is too high or too low but your old test equipment for free chlorine will continue to tell you no chlorine as it can't react with the chloride any longer as it is bound to the salt. That is why they tell you you never have to add more because the salt stabilizes it. Your chlorine is there it's bound to the salt. Use the pool it's fine and it makes your water feel really soft! Just keep the salt level right and your fine> It's confusing as they call the unit a chlorine generator! I had the same issue, called Intex and they told me the above.
Jun 01, 2009 | Intex Automatic Salt Water System for ...
Intex Automatic Salt Water System for  Above Ground Saltwater Pool Logo
805 people viewed this question
Top Intex Pool & Spa Experts
avionik99
Level 1 Expert
Jay Finke
Jay Finke
Mike
Are you an Intex Pool and Spa Expert? Answer questions, earn points and help others
