Question about Craftsman 20 hp 42 in. Deck Yard Tractor
Starting Craftsman model 917.270430 riding mower.
I have a Craftsman model 917.270430 riding mower. While mowing the other day I stood up off the seat for a sec and it died and now won't start or try to start.
    Genius:
  • 1,114 Answers
There's a safety shut-off switch below the seat, so when you're seated the switch is engaged. If you were to fall off the mower, the engine and Blades stop (safety feature).
Check the switch to see if it's operational.
Beyond that, mower may need a tune up or servicing, if it is not starting.
Posted on Jun 27, 2009
LT1000 cranks but won't start
check to see if you lost spark if not spray starting fluid and see if it fires that will tell you if it's a fuel prblem
May 21, 2012 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Husqvarna Riding Lawn Mower 46 Cut model #454140010G MOWER will not ingadge
I can not say this enough, check the safety switches. There should be one on the seat, the clutch /brake pedal and /or the equipment pto switch. Also, check the wires running to these switches. They tend to move and vibrate as you mow and a worn spot in the wires can cause a short, resulting in the mower not starting.
Good Luck!!!
Jul 17, 2011 | Husqvarna Riding Lawn Mower 46 Cut Kohler...
My lawn tractor just quit running, battery fully charged, won't do anything when switch is turned on. Can the ignition switch be bad?
When you say it quit running, did it stop while you were mowing? Or did it just not start one day. Could be the ignition switch, but not likely. There are several safety switches on your mower. First is the operator present (switch in the seat) then there is the switch on the clutch that requires you to hold the clutch in when you start. Then there is a switch on the PTO for the deck that must be off to start. Without an exact model number, I can't look at the exact wiring schematic, but this is generally how they work. If you have a tester, and know how to use it start at the battery, look for 12 V. Then test from ground to one side of ignition swithch. Then to the other while the key is in start. Then find wires to seat switch. This switch should keep the mower from starting and keeps the pto engaged usually. then find the switch for the clutch/brake. test both sides of that. Finally test the small terminal on the starter solonoid. If you're getting 12V to the solonoid, and you have a good ground on your battery and it still won't start, could be the solonoid. If it actually quit while you were mowing, I'd check the seat switch and pto switch.
Jul 12, 2010 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
WILL NOT START craftman LT1000 YR.2000
most likely the blades are still in the on position,but you have a seat switch, parking brake switch, and the blade switch, also the mow in reverse key switch. if mower dies once you let out the clutch in reverse with blades on and key wrong.
Apr 22, 2010 | Craftsman 20 Hp 42" Deck Lawn Tractor
My mower dies when I put it into gear when I am trying to mow. It works fine for my husband. How can I change the level of sensitivity on the seat safety switch? We have a Craftsman DLS 3500 lawn tractor.
The seat is adjustable. Move the seat forward to fit you better. There is no adjustment on the switch itself. You just need to put more weight in the seat.
Nov 23, 2009 | Craftsman Garden
Craftsman riding lawn mower steering shaft fell. Mower will not steer. I just started mowing, and the mower quit steering. Looked underneath, and it appears the shaft came loose that is used to steer. Any...
Look under the seat of your tractor and note the complete Model number.
(usually begins with 917. _ _ _ _ _ _ )
Next, go to THIS PAGE and use the Model Number to find an exploded view of the steering components and how they assemble.
Hope this helps,
Dolf-
Oct 15, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Mower shuts off while mowing grass
Check the switch that is located under your seat. If you are not on the mower while it is running the switch tells the mower to shut off. hope this helps
Jul 12, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Craftsman riding mower blades will not engage
maybe the safty switch under seat might be starting to go out if that switch doesn't work the blades wont come on at all for safety
Jun 27, 2009 | Craftsman 20 hp 42 in. Deck Yard Tractor
Craftsman 20 hp 42 in. Deck Yard Tractor Logo
516 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
