Question about Weber Genesis Silver B Grill
Very weak flame/slow cooking
I have no problem lighting the grill, but recently the cooking temp has gone way down and I can't get it higher. The grill is 10 years old, and has been great all these years.
Check the holes on the burners. There seems to be a yellow residue that collects and blocks the small holes. I use a toothpick every other season to clear them out.
Posted on Jul 24, 2009
How do I cook ribeye steak
on the grill! get yourself nice dryrub at your local food store and throw it the grill. i dont let my temp get higher then 300 i cook them low and slow!
Dec 08, 2014 | Grilling
My weber grill silver will not get hot over the test heat
Since I was not familiar with the term you used "will not get over the test heat." I took a look at the Owner's Manual for you model grill. The only reference I could find to temperature was in the section about preheating the grill to 550 degrees F. That being the case, I guess that's what you may have been referring too.
To solve this problem do the following, as I believe falme heights on the Highest settings are not what they should be.
First, check the gas line hose from the tank to the grill. Look for kinks or twisting that would restrict the flow of gas to the burners. If you find any, turn the gas tank valve OFF, disconnect the hose from the tank and straighten the hose, before reconnecting it to the tank. Then open the gas valve Very, Very Slowly, until it's fully open.
If you didn't find any kins ot twist, do the following:
1. Turn the gas tank valve OFF, Disconnect the hose from the tank and wait 5 minutes.
2. Turn on any pair of burners to High for io minute and then turn them OFF.
3. After 5 minutes has elapsed, reconnect the hose to the tank.
4. Open the tank valve VERY, VERY, SLOWLY (Slow motion, slow) until it's fully open.
5. Light the burner farthest from the tank first and turn it to HIGH. Does the flame height look
correct? If so, light the remaining burners the same way. Do all the flame heights look correct?
If so, you solved the problem!
6, Close the grill lid and allow 10 - 15 minutes for the grill to preheat to your desired temperature.
If the above didn't solve the problem. The problem, may in fact be a faulty Thermometer. To test it, invest $5.00 in an Oven Thermometer, like you use in a regular oven, that will sit on the oven rack. But, in this case will sit on the cooking grates.
Set the thermometer on the cooking grates, light all the burners, close the lid an allow the grill to preheat for 10 minutes. Then read the temp on the grill thermometer, open the lid an compare it to the Oven thermometer on the grill grates. I'm willing to bet, the oven thermometer will read higher. That's because, it's right down on the cooking grates and not reading the air temperature, like the grill thermometer is. That's why, I all ways use an oven thermometer on my own grill. It's more accurate.
Hope this helped you solve the problem. Please let me know and Happy Grilling.
Jun 19, 2011 | Weber Genesis Silver B Grill
Low Heat ? i have a brand new napoleon grills. paid a lot to get quality. I dont find it very performant. It seems there is heating problem. I read a lot about regulator reset. I tried it but im not...
Not sure what you're grilling, that would require 500 degrees or higher. Unless, you're really trying to char-broil and I do mean char. In any event, it may simply be the thermometer on the hood of your grill, reading incorrectly. Keep in mind, the thermometer is not reading the temp at the cooking grate surface, it's reading the air temperature when the hood is closed.
I do a lot of grilling, I do grill shows for local food stores and I love to grill. But, I have learned to never rely on what the grill thermometer says. I use an oven thermometer that sits off to the side, on top of my grill grates. When I compare the temp on the grill thermometer to the oven thermometer on the cooking grates, there will be a difference of 50 degrees. Now, certainly the temp will drop some, when the hood is opened after preheating. That's normal. But the heat loss, at cooking grate level, is not more than 10 degrees, depending on the outside ambient air temperature. Of course if it's the dead of Winter, the temperature will drop significantly. In that case, grill with the hood closed 90% of the time.
With all of the above said, what do the flames and flame heights look like on each burner? Do they respond as they should when you raise and lower the flames? If not, then you have a gas pressure problem. That can be resolved by turning OFF the tank valve, disconnect the hose from the tank and waiting 5 minutes. Then reconnect the hose to the tank and open the tank valve VERY, VERY, SLOWLY (slow motion, slow). Once the valve is fully open, light the burner farthest from the tank first and turn it to high. Do the flames look higher than they did previously? If so, light the remaining burners following the same procedure as the first burner. Do all the flame heights look correct. If so you solved the problem of low flame height.
I hope all of this has helped you troubleshoot and solve the problem, if there is one. Please let me know. Thanks and Happy Grilling!!
May 12, 2011 | Napoleon "Prestige I P450RBNSS" Gas Grill
I have a Cook by Number gas grill, model LG36C, that isn't cooking as hot as it should. I've disassembled all the gas lines and blew them out with compressed air. I cleaned the burner. I cleaned the...
Since your grill only has one main burner and it requires more gas to heat with than the side burner. I still suspect you have a grill regulator issue. But, if you've done your research, you know it's easy to solve. Turn the propane tank valve OFF. Disconnect the hose from the tank valve and wait at least 5 minutes before reconnecting it. Once it has been reconnected, turn the tank valve on VERY, VERY SLOWLY (slow motion, slow). Once the tank valve is fully open, turn your main burner on, light it and turn it to high. Do the flames appear to be higher than before? If so, light and turn ON the Side Burner. Now do all the burner flames appear to be higher than before? If so, you solved the problem. If not, either the grillhose/regulator assembly needs to be replaced or the Venturi Valve on the main burner needs some adjusting. As the air to gas ratio may be off sightly.
Hope this helps to solve your problem and Happy Grilling!
Mar 29, 2011 | Fire Stone LG36C Propane
Low temperature Only hitting 300 degrees Has gas It's warm outside as well
Two problems - Two Solutions: Turn the LP tank valve to OFF. Disconnect the grill hose from the tank and do not reinstall for 5 minutes. After the 5 minutes, reconnect the hose to the tank and turn the tak valve ON VERY, VERY SLOWLY (slow motion, slow). When the tank valve is fully open, light the burner farthest from the tank and turn the flame height to HIGH? Does the flame height look correct? If so, light the remaining burners the same way. If all the flame heights appear to be normal for the highest setting, you've solved the problem.
Second problem & solution: The grill thermometer may be incorrect (as they often are). If you don't have one, buy an inexpensive oven thermometer (that normally sits on the oven rack) and place it on the cooking grate of your grill, toward the front of the grill. Once in place, preheat your grill as you normally would with the hood closed and at about the 15 minute mark, compare the temperature on the two thermometers. If they're within a few degrees of each other, your grill thermometer is accurate. If the Oven thermometer reads higher (more than a few degrees), the grill's T-Stat is faulty.
Personally, I always use an oven thermometer on my grill when grilling or baking anything.
Hope this helped to solve your problem. Please let me know and Happy Grilling!
Mar 16, 2011 | Weber Genesis Silver B Grill
Takes a long time to heat up
It shouldn't if the grill is working properly. Have you had this problem since you got the grill, or just recently? Do the flames appear to be smaller than usual? A lot of people have the same issues. It could be a number of things. I tried to cover them all in my tips and tricks for gas grill lighting issues. Click on my username and scroll down my profile til you find it and see if that helps. Let us know if you need further assistance if problem still exists.
May 16, 2010 | Kenmore 882 sq. in. Cooking Area Gas Grill...
Weak flames - no pressure
make sure valve is open on the tank all the way
May 01, 2010 | Kenmore Elite 644 sq. in. Cooking Area Gas...
My kenmore elite grill has a ceramic cooking grid. it is 1 yr old.recently a problem developed. the ceramic grid lights as usual, but does not stay lit.once i let go of the knob the burner goes out. thanks...
check thermo coupling., its purpose is to keep heat at flame area-helps keep flame lit,like a pilot light... clean it with a finger nail file LIGHTLY- or use sand paper LIGHTLY, just to clean surface..
Nov 27, 2009 | Kenmore Elite 900 sq. in. Cooking Area Gas...
Weak Flames on Propane Grill
It is possible that your burners are clogged. Clean the burner ports with a paperclip (not a toothpick).
Jun 01, 2009 | Kenmore Elite 644 sq. in. Cooking Area Gas...
My Brinkmann Electric Smoke and Grill (Double) is cooking
I hope your turkey turned out OK. I read all of the smoking and grilling forums and it seemed to be a very common occurrence yesterday that turkeys cooked in far less time that the grill masters thought they would. Could be that most birds are pre-brined and the additional moisture causes the birds to cook faster. Could be that they are leaner than in the past and the fat renders sooner, causing internal temp to rise faster.
I would let it cook and just check the internal meat temperature at regular intervals starting about 15 minutes per pound.
At what temperature was your smoker running during your cook?
Pat
Nov 27, 2008 | Brinkmann Smoke' n Grill Electric Double...
Weber Genesis Silver B Grill Logo
411 people viewed this question
Top Weber Grilling Experts
Gary Kenady
Gary Kenady
Paul Carew
Are you a Weber Grilling Expert? Answer questions, earn points and help others
