Video how to do it o instructions many thanks
SOURCE: technics ho2 no play error
u need a new motor in yr dvd player i had same problem so had new motor fitted cost 50 pound works now
SOURCE: technics sc-dv250
did you buy your system in adifferent region and moved with it to another? I heared something like some DVD players are region-locked. I could be wrong but google about region-lock... try this among others: http://dvd-player-software-review.toptenreviews.com/what-is-dvd-region-lock.html
Pikles
SOURCE: Technics SC-DV290
Hi mkoles111,
I have a copy of what you need which I downloaded recently. It is in pdf format and is about 2.2mb. Let me know if you still need it and I will forward to you.
Regards
topgunner
SOURCE: Pdf Download for Technics SH-DV 290 Hi Fi Instructions Manual
The number of the system is actually SC-DV290 the number you gave is actually the reg number of one of the component parts. To download the full user manual, go here ........ http://www.panasonic.co.uk/html/en_GB/Support/Downloads/220239/index.html#anker_220239 .... In the box " Enter model number, if known", enter SC-DV290 and press "search". Agree to the terms and view / download the manual. Hope this helps.
SOURCE: FAILURE TO READ DISCS. TECHNICS SL-DV280 (SC-DV280)
if the disc starts to rotate when helped by hand then you definately have a weak spindle motor. dvds spin faster than cds which gives more wear & tear to the motor. i've repaired these faults numerous times. hope this helps?
