Question about Kenmore 63942 Dryer
Dryer is not giving out heat, but it is spinning
Where is the fuse located in the dryer and how do you take it out
  • 72 Answers
The thermo fuse is on the top of housing that holds element take back off to get to it you can jump it to test
Posted on Jul 01, 2009
Where are fuses located in Frigidaire front loading dryer?
No fuses. Probably Heating element or one of the thermal switches. Electric dryer I am assuming
May 24, 2015 | Frigidaire Dryers
Dryer is not giving off any heat. Drum spins
Most likely it is a thermal fuse. Go to this website and enter name and model of dryer. Look for video explaining thermal fuse location.
About $15 at most appliance parts stores. Easy installation.
appliancerepairpros.com
Feb 18, 2015 | Whirlpool Dryers
FLD r10
Hello Rick, this is Z. Thank you for your post!
I understand your gas dryer spins but it is not heating. It sounds like your dryer may possibly have faulty fuse(s), gas supply or ingitor. Generally speaking, the fuses are located on the heater housing and the other near the blower housing. Typically, both thermal fuses are closed circuits. One will prevent the dryer from coming on and the other will prevent the motor from turning. However, regrettably, this is not a simple DIY job. Generally, qualified technicians often perform these complicated parts replacements. I would personally suggest reaching out to a professional to accurately assist with the repair of the part(s).
Mar 07, 2014 | Frigidaire GLEQ2152ES Electric Dryer
Duet sport electric dryer won't heat or spin, minute counter counts down
You will need to replace the "thermal fuse" located on the back of the dryer. Here is the part to order.
Nov 22, 2012 | Dryers
How do I find the thermal fuse to a Kenmore Dryer? It comes on and spins but no heat.
for kenmore dryer the thermo fuse, most often they are on the air duct. or located on the heating element can. The can is located on the bottom right in the dryer and holds the heating element..hope this helps pls do let me know
Jan 12, 2010 | Kenmore Dryers
Heat doesn't work ..dryer spins but no heat is produced
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Aug 01, 2009 | Dryers
I have a MAYTAG MDE5500AYW drier that spins but doesn't heat up. Any recomendations?
Jul 28, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Fridgidare dryer spins but no heat.
If the dryer runs but doesn’t heat, don’t even think it’s the thermal fuse. If the thermal fuse was the problem, the dryer wouldn’t run at all.
First thing to do is verify your source voltage for the dryer; for those of you in Manhattan, this means to use your multi-meter to measure the voltage at the dryer outlet to make sure you have 240v. Y’see, Slick, the dryer motor only needs 120v supplied by one of the lines to run. But the heating elements, on the other hand, need 240v supplied by both lines to get hot.
If the source voltage is ok, then the most likely bad parts are listed below. As always, you should use your meter and the tech sheet supplied with your dryer (and cleverly hidden inside the control panel) to verify:
1. Even Heat Board
2. Heater Relay
3. Thermostat
4. Sensor
May 02, 2009 | Dryers
DRYER SPINS BUT DONT HEAT UP
Right on the back of the machine. It is the size and shape of a 1/2 dollar coin held in place by 2 screws.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Mar 19, 2009 | Kenmore 98702 Stacked Washer/Dryer
Gas dryer lgr4634eqo GAS
check the thermal fuse located at the back of the dryer for continuity and let me know how you make out
Sep 13, 2007 | Whirlpool LGV4634JQ Gas Dryer
Kenmore 63942 Dryer Logo
103 people viewed this question
Top Kenmore Dryers Experts
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
