Question about Sony KP-57WS520 57" Rear Projection HDTV-Ready Television
Sony-kp57ws520 g- board,found the diodes,but how do i find the right value or part # of the diodes?Any Schematics?thank you
Disconnect everything that plugs into the g-board, carefully uninstall the old board and reinstall the new board, plug in everything that was disconnected. Then turn the t.v. back on.
Posted on May 11, 2010
U dont u just cut it out. then install the
G board and turn it on
Posted on Jul 28, 2009
I need a D board for a sony projection tv model KP-51WS520. Can I buy this anywhere or does it need repaired? Thanks in advance!
you probably will not find one available and they usually are repaired at com
SONY D BOARD 10 BLINKS REPAIR KIT KP51WS520 , KP57WS520 , KP46WT520
ponent level . but here is a link to the parts to do that with from EBAY
Oct 20, 2014 | Sony Televison & Video
Sony DAV-S400 PSU C916 value? Note that you found the answer & there are 3 values dependant country. What is value for UK model?
Service manual does not have schematics or part list for PSU board of DAV-S400, however, it does have part number of complete power supply board that I can provide you if that helps.
Thanks.
May 24, 2011 | Audio Players & Recorders
I have a laptop motherboard (da0at3mb8f0) which will not power on. I see a small charred area on the motherboard right on the power input circuit. I want to replace these diodes/resistors but I cant tell...
Even if you would find the parts, it's impossible to repair it - the multilayer board on which they are soldered is shorted and that cannot be fixed.
Mar 23, 2010 | Computers & Internet
Need part number for D6109
Model number KP57WS520?
Part number for D6109 is: 8-719-510-02----generic number for this diode is: D1NS4
If this helps you, rate this solution as I do this here for free.
SD TECH
Nov 05, 2009 | Sony KP-57WS520 57" Rear Projection...
Sony 9 blink problem
9 blinks shows problem in power supply (G Board) and service manual suggest to check D6116 or D6301 that could be open on G Board.
Thanks.
Sep 01, 2009 | Sony KP-57WS520 57" Rear Projection...
TY,found scematics,ordered parts,mine only blinks 4 times though!Is this a different problem,am i wasting my time with the diodes?.Can hear aclick like a relay,when I try to turn on,standby blinks 4...
According to the self diagnostic system 4 thimes LED blinking,
The fault is in vertical section, Vertical deflection is stopped, 15V not supplied (D Board), IC 5101 could be faulty(D Board).
Therefore check the above mention area it will help you.
Thanks for using fixya.
Jun 28, 2009 | Sony KP-57WS520 57" Rear Projection...
I have a sony kp57ws520. The set wont turn on and the lite blinks 9 times. I was told at one time to solder two specific diodes on the g-board and that worked for a period of time. Now the problem is back....
Resoldering those parts is known as a temporary "fix". Those parts need to be replaced. I believe that they are D616 and D6301. Both are on the "G" board. I don't have a listing for your specific model, but most of thr 57s are similar.
Keep us posted.
Dan
Aug 25, 2008 | Televison & Video
Sony vpl cx5 no voltage to lamp
I downloaded the schematics and drawings for $US9.00 and found what I thought may have been a thermistor turned out to be a fuse. Obtained one from Sony spares and it is now OK. If it is possible would you guys know the value of the fuse [amp/milliamps??] If you are familar it is fuse 2P connected to C board, it looks like a small lump of plastic or diode block. The cost of the fuse is outragous from Sony. I hope I do not have to replace it again. However, if I do I would love the valua and I could see if I could get one from Radio shack or someplace similar. If I was not retired I would buy one and put it on a step tranny and watch the ampmeter for the blow current. But, thats life when you decide to retire. I believe the voltage value is 3volts??
Would appreciate any feed-back on the value of the fuse.
And I hope this may help others
Thanks and Good-day
Leckie
Feb 06, 2008 | Sony VPL CX5 Multimedia Projector
Sony KP-57WS520 57" Rear Projection HDTV-Ready Television Logo
2,072 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
