Blowing warm air. Noticed that electric bill the month it stopped working was triple. I assume it was working hard to produce cool air
  • Robotinner May 11, 2010
    need make and model of outside unit.
    Sergeant:
    Champion:
  • 235 Answers
Yes, the compressor was working extra hard to try and keep the place cool. Freon must be escaping from somewhere. Hopefully, it is just from the schraeder valve stem. If evaporator is iced up, run it on fan to thaw out the ice before applying freon to unit .
Posted on Jun 30, 2009
Refrigerator not cooling what is stopping it?
Does it have power? (does the light come on when you open door)
If it has power is it blowing air inside?
My fridge stopped working a few months ago. It had power but was blowing warm air. After taking the cover off the rear bottom I found the compressor was not turning on. The 'Overload Relay Switch' was burned out... I ordered/replaced (Lowes).. It cost me about $50 and took about 10min to install.. It has been working great since.
Dec 04, 2013 | Haier Convertible Bottom Drawer French...
Bought the cavalier had no ac/ but has great fan blowing it's just hot, defrost everything runs normal mulitiple speed////recharged w r134 blew ice cold almost 3 months went out again slowly. Stopped at...
I,t sounds like you had a leak, and pulled air into the system. This calls for professional servicing. Whenever there's a leak in a refrigeration system, air and sometimes other noncondensables get pulled into the system. They don't belong there. They cause heat and high pressure in the condenser, and will eventually destroy the compressor. The system needs dehydration and evacuation before charging. That's after all leaks have been repaired.
Aug 26, 2013 | Heating & Cooling
The hot air won't circulate to upperstairs
2 possible causes. 1 there is a blockage in the ventilation system (possible collasped ductwork) or 2 the fan motor is going out. The motor could be going out due to the winding swelling as the motor is run heating the winding causing the windings to swell slowing the motors rpms.
Dave
Feb 22, 2010 | Bryant 463AAC005BA Air Conditioner
Heater is blowing cold air. Could it be that my
Had similar problem. The actuator that opens & closes the air blend door quit working. This is easy to see if you remove glove box. The actuator will move when you adjust the temp selector (do this while the heater is running).
Dec 28, 2009 | 2001 Ford Taurus
What does energy saver do ?
Hello there
Energy saver alows you to minimize the amount of energy used to run the appliance efficently thru different settings on the appliance
To use the Energy Saver option:
  • Press the control to On to save energy when the environment is less humid.
  • Press the control to Off when the environment is warm and more humid, or if moisture is noticed on the hinged seal.
  • I hope that this has been very helpful for you
  • Best regards michael
Nov 06, 2009 | Roper RS25AEXLQ Side by Side Refrigerator
2006 Passat Air Conditioning Problem
There is an electrical relay that is malfuctioning. I had the same problem on my 2000 VW Passat. I just got it fixed, part cost 48 dollars and labor will be about an hour.
Jun 30, 2009 | 2006 Volkswagen Passat
A/c stopped working,the clutch still engages, fan blows warm, found no fluid leaks
the air blend door inside the heating / cooling unit that sits under the dash is probably not moving. there is an electric motor and control unit that moves the air blend door (assuming you have the electric dial or push button digital controls. some of these vehicles have a valve that shuts off the antifreeze from cycling through the heater and if it remains open then you would get "not hot" but just warm air.
Apr 26, 2009 | 1999 Infiniti.5 QX4
Furnace runs constantly since blower motor was replaced
Sounds like they wired it direct to line voltage , it should run through a sequencer or fan relay to cycle on and off , your seq./relay could be stuck closed to but unlikely being it was just repaired , call the service company back before you do anything they are responsible.
Apr 11, 2009 | Carrier XHB123D X/Y Series Heat/Cool Air...
UNIT NOT BLOWING WARM AIR-OR REACHING DESIRED TEMP
I assume this is a heat pump. The outside unit may be icing up. It should have a defrost cycle with electronic control that sometimes fails or sensor associated with the electronic determination of when to defrost may have failed or may not be sensing because its out of position. You can check for a defrost problem. If frost is blocking the outside unit air will not pass through it after the frost builds up and you may be able to see the white frost as well. If all this is true you need to get a service manual and use its procedures to find out why the unit is not defrosting.
Jan 12, 2009 | Weather King 12AJA4801AH Air Conditioner
Will not cool properly.
You have either a faulty thermostat, dirty condenser and evaporator or a faulty run capacitor. Need to service soon before the compressor is damaged. Sea Breeze
Jul 31, 2008 | Kenmore 75101 Wall/Window Air Conditioner
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
