SOURCE: Display a decimal point
Turn the calculator off, then press and hold down the .(decimal key) while you press the on button. Doing so again sets the calculator to use the original digit separators in the display
SOURCE: 12C Calculator
Press "f" then 2. The number you press after "f" sets the number of digits to the right of the decimel point.
SOURCE: HP 12c cALCULATOR
It is not calculating because your decimal point and the digit separator (that's the comma which automatically displays for every group of 3 digits) got messed up. To clear, turn the calculator OFF, then press and hold down the dot (that is the decimal point symbol) key while you press the ON key..
t
SOURCE: I have an HP 12C calculator and I cannot find the
Check this HP FAQ:
Setting a Fixed Decimal Place
You can download the manual and user guides for your calculator from here:
http://h10025.www1.hp.com/ewfrf/wc/manualCategory?lc=en&dlc=en&cc=us&product=81575&lang=en&
For more information, Faqs & how-Tosgo the HP support homepage for your calculator:
http://h10025.www1.hp.com/ewfrf/wc/product?lc=en&dlc=en&cc=us&lang=en&product=81575&
Introduction
This document describes how to set the desired number of decimal places on the HP 12c calculator in standard format. It also covers how to enter a number in scientific notation.
Instructions for standard format
The display will show the specified number of decimal places. The answer will be rounded to the number of digits selected.
Example (standard format)
If the number in the display is 14.87456320, the display will be changed as follows:
Keystroke
Display
14.8746
14.9
15
14.87456320
Instructions for scientific notation
Use scientific notation for very large or very small numbers. Type in the mantissa. After pressing, the next numbers keyed in are exponents of 10. Press . If during an operation a result has more than 10 digits, the calculator automatically displays the number in scientific notation
Introduction
Keystroke
Display
14.8746
14.9
15
14.87456320
One adjustment is important before we get started. By default the 12C displays only two decimal places. This is not enough. Personally, I like to see five decimal places, but you may prefer some other number. To change the display, press "F" and then the number of decimal places you wish to display. I would press "F 5 " to display 5 decimal places. That's it, the calculator is ready to go.
