Question about Whirlpool LER5636P Electric Dryer
How do I get to the belt to change it?The motor is fine but it will not turn
    Sergeant:
  • 222 Answers
You have to remove, or at least loosen the front of the dryer to replace the belt. It's best if you have someone to help you with this, since the front of the dryer rests on friction pads located on the front of the dryer.
Remove the back panel to get access to the motor, tensioner, and the old belt (which has probably fallen into the bottom of the dryer). Loosen or remove the front (if you decide to remove, be sure to mark wires so you'll know EXACTLY where they go when you re-assemble and remove any grommets or retainers that may be holding the wiring harness).
My advice is to loosen it and get someone to hold the front up while you slide the belt over the drum. To do this, you have to also lift the top, which is held in place by two spring-loaded clips which you press in with a strong (and not sharp) knife or a thin-blade screwdriver. Raise the top, being sure that you don't put any strain on wires pulled through the back control panel.
Put the belt in place over the drum, reassemble the front, then lower the top (don't snap back in place yet. From the back, place the belt over the motor pulley and center the belt on the drum so that it aligns with the motor pully. Pull the spring-loaded tension arm back so the pulley rests on the OUTSIDE of the belt. Turn the drum to be sure there are no twists in the belt and that it turns freely. Also check the idler pulley to be sure it's not turning freely.
Snap the top back in place and you're done. Good luck. Hope this helps.
Posted on Jun 27, 2009
Treadmill proform model 831.29605.0 (proform xp 550e was working fine till I Changed the walk belt. After changing belt, display looked ok but treadmiil would non trurn on. Operated incline. incline
1) i recommend that you lube very well deck belt + rollers bearing
2) see the videos.
3) see the block
4) Try to RUN the software calibration, for troubleshooting.
5) measure the input voltage motor, if there are the motor need repair.
6) Measure the output voltage board, for input voltage board, if there are NOT, the board is faulty.
Jun 27, 2012 | Proform Treadmill Motor Controller 241697
Drum wont turn ,everything else works fine
This sounds very much like the belt is slipping or broken (or at worst the motor is malfunctioning). Belts are not expensive- sorry I do not know how much yours would cost- and are easy to be changed by a competent person:-
REMOVE POWER FROM THE MACHINE AND REMOVE THE BACK.
The motor support bolts should be loosened and the old belt removed. Often putting the new belt on is a bit of a struggle, even with the motor 'loose', because it is new and smaller!
Once on it should be tensioned by pulling the motor against the belt firmly- but not over tight- and the motor support bolts tightened.
ON NO ACCOUNT SHOULD ANY FORM OF LEVERAGE BE USED TO TENSION THE BELT. THAT COULD LEAD TO DAMAGE TO THE BELT, MOTOR AND BEARINGS- EXPENSIVE!
If it turns out to be the motor, it is false economy to just have the brushes changed. Experience of others is that the brushes may only last months unless, that is, the motor is totally refurbished.
Hope this is your problem solved.
Good luck,
John C
Feb 28, 2011 | Hotpoint Aquarius WD640 Front Load...
It washes fine but when it it time to do the final spin it sounds funny and wont spin out
This sounds very much like either the belt is slipping or the motor is malfunctioning. Following first are my standard machine guidance notes for a belt change, then notes for a motor change (which we hope is not required!)
Good luck,
John C
Feb 21, 2011 | Kenmore 46462 Front Load Washer
We changed the timming belt started motor everything was runnig fine. we turned motor off to check oil water and other things to finish the job. We went to start it again and it won't start. We have...
Recheck timing marks
When you replace belt you must turn engine over a couple of times by hand,before you start it,so you can recheck marks and belt tension.
Jan 04, 2010 | 2004 Toyota Tundra
My washer agitates but does not spin
You have given a brief expansion of your problem first of thanks for that ,you have seen that motor is running but it slips kindly remove the belt from motor to mechanism and try to rotate through hands if moves freely means you mechanism is fine otherwise you are suppose to change the mechanism
You have told that you have seen some smoking problem as well so check the motor individually then fix it. if you found motor is also problem kindly replace the motor
Dec 30, 2009 | Washing Machines
I have a used Kenmore Series 80 dryer & the drum stopped turning
Good day,
Not hard to do but check the 2 rear wheels that support the drum and change at the same time if needed. Inspect the belt tensioner as well.
Here's a good tutorial on the belt change.
http://www.wikihow.com/Replace-a-Dryer-Belt-on-Whirlpool-Models
Dec 15, 2009 | Dryers
Dryer heats but wont tumble/electric
Broken belt due to bad rollers or idler or simply rotten belt. GUIDE
Jun 30, 2009 | Kenmore 63942 Dryer
Motor is fine but drum won't turn. What could it be?
is there a belt to turn the drum - if so it may need to be changed.
Jan 04, 2009 | Kenmore 73952 Gas Dryer
Eureka 5197 self propelled bagless upright
Did you check the brush roll when you changed the belt? The smell of rubber would inducate a belt slipping. So if the brush roll (part #61308-2)isn't turning, the belt would get hot and would be slipping. If the motor sounds real loud, then you could have a bad motor(part #60775-4).
Feb 14, 2008 | Eureka 5197AT Upright Vacuum
Whirlpool LER5636P Electric Dryer Logo
130 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
