T
TOM SULLIVAN Posted on Jun 26, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
CD TRAY ON GX-700 WON'T OPEN - Yamaha Audio Players & Recorders
Level 3:
Top Expert:
  • Yamaha Master 76,851 Answers
  • Posted on Jun 26, 2014
Yamaha Master
Level 3:
Top Expert:
Answers
76851
Questions
30
Helped
14986810
Points
237762
CD loader mechanism fault. Either its loading belt, or any gear wheel damage, can cause this. To repair it, you have to take out the loader mechanism. It is a skilled work. It will be better to contact any experienced service technician, or the authorized service center for Yamaha.
If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Pull up older posts. Surf the site with patience. Do a search by type in the brand name of your device at its search box and press "Enter".
2answers
Cd tray won’t open
In the good old days, a CD drive would always have a small hole in the front. To open the tray, you would straighten a paper clip and press a button about 1/2" inside the hole. This releases the latch and starts the tray coming out where you can grab it.
This video shows you how:
3helpful
Dell cd drive door won't open
CD/DVD Drive Tray problems
There are two ways to open the CD/DVD drive door if the button just below the drive tray does not work.
Go to My Computer and right click on the drive and click on Eject.
If this does not work then you can manually open the CD/DVD drive tray by -
Straighten a paper clip and gently insert it into a tiny hole below the drive tray next to the Eject button. Push the paper clip gently until the drive tray pops out, then pull the tray until it is fully out, then you can remove the CD/DVD disc.
If you still having problem opening with the Eject button, then the CD/DVD drive is faulty and needs replacing.
The cd door won't open on the tower
CD Drive Tray problems
There are two ways to open the CD drive door if the button just below the drive tray does not work.
If this does not work then you can manually open the CD drive tray by -
Straighten a paper clip and gently insert it into a tiny hole below the drive tray next to the Eject button. Push the paper clip gently until the drive tray pops out, then pull the tray until it is fully out, then you can remove the CD disc.
If you still having problem opening with the Eject button, then the CD drive is faulty and needs replacing.
CD changer won't open. Mechanical Error on display
There is a small hole just above the door on most CD changers. Unwind a small paper clip and GENTLY push it into the hole. This should release the door, and let you look inside. Don't force it because you could damage it more than it is already.
1helpful
CD DOOR WON'T OPEN
Just below the CD/DVD tray there is a tiny hole. Insert a straighten paper clip in this hole and gently push the paper clip until the CD/DVD tray pops out. You can now pull the tray out until it is in the fully opened position to remove the disc.
Try pushing the eject button to see if the tray closes, then push the eject button to see if the tray opens.
If this foes not work then the CD/DVD drive is faulty and it needs to be replaced.
2helpful
Tray for cd won't open and it says "mechaical error." Unlike in the past there seems to be nothing stuck or askew inside. I left unit on overnight and tray was apparently open because I saw it...
you need to open the cover of your component and have access to the mechanical system of the CD. The timing gears might got dislocated and you need to manually adjust them.check also if there are belts that are broken replace them.
2answers
Cd tray stuck closed
open the cabinet and remove the magnetic lock placed on the top of the mechanism then u can remove the cd
2answers
Tascam CD-RW2000
THE CARRIAGE UNIT (CD TRAY) is damaged, replace the tray
or the drive
or u can use it as is until its dead
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Paul Bade
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
