Question about NetGear WGR614 Wireless Router
How do i hook up 2nd computer to router wireless ''g'' wgr614
  • David Mcintosh
    David Mcintosh May 11, 2010
    Do you want to connect the second computer wirelessly or via a second LAN cable?
  • 854 Answers
A. Checking the Wireless Settings of the Router
Note: You need to use a computer hardwired to the router to check the wireless settings.
1. Open any web browser like Internet Explorer or Netscape Navigator.
2. Connect to the router by typing http://routerlogin.com/basicsetting.htm or http://192.168.1.1 in the address field and click Enter or Return key.
3. A window will prompt for a user name and password. The default username is "admin" and the default password is "password".
Note: If it does not take password as the password, you might have changed it when you ran the NETGEAR Setup CD so please try other passwords. If you cannot remember the password, you need to reset the router and run the Setup CD to reconfigure it.
4. When the setup page opens, click on the Wireless Settings under Setup and take note of the SSID.
5. You may also change the wireless channel here. We suggest channels 1, 6 and 11.
6. At the bottom of the page, look for the Security Options. If in case that the security is set to WEP or WPA-PSK, we have to enter the same wireless security on all wireless PCs. To make sure of the key, we can try modifying the security. Please refer to the following:
For WEP: Select Key 1 and enter 10 hexadecimal digits (0-9 and A-F) on the empty box beside it. Then, click on Apply.
For WPA-PSK: Enter an alphanumeric key (minimum of 8 characters) on the Passphrase box and click on Apply.
Note: The Key and Passphrase are case-sensitive.
7. On the left pane, please scroll down and click on Wireless Settings under Advanced. Please make sure that the boxes for Enable Wireless Router Radio and Enable SSID Broadcast are checked.
8. Click on the Setup Access List button and uncheck the box Turn Access Control On.
9. Click the Apply button.
B. Connecting to the Wireless Network
For Windows XP Service Pack 1:
1. Please right click on the Wireless icon on the right lower end portion of your computer. Then click on View Available Wireless Networks.
2. Click on the Advanced tab.
3. Please delete all the preferred networks then click on OK.
4. Right click on the Wireless icon again and click on View Available Wireless Networks.
5. Please select your network and click on Connect. If you have Wired Equivalent Privacy (WEP) or Wi-fi Protected Access (WPA) enabled on the router, it will ask you for the network key. Please type in the Network Key and then confirm it.
6. Make sure not to enable IEEE and then click on Connect.
For Windows XP Service Pack 2:
2. Click on the Change Advanced Settings.
3. Click on the Wireless Networks tab remove all the preferred networks then click on OK.
4. Right click on the Wireless icon then click on View Available Wireless Networks.
5. Select your network and click on Connect.
6. If you have Wired Equivalent Privacy (WEP) or Wi-Fi Protected Access (WPA) enabled on the router, it will ask you for the network key. Type in the network key and confirm it. Then click on Connect.
For Windows Vista:
1. Click Start then select Connect To.
2. Connect to a network window will show up.
3. Select your wireless network and click Connect.
4. It will ask you for a network key. Type in the network key and confirm it. Then click on Connect.
Note: You may use the wireless utility of your wireless adapter in connecting to the wireless network but you need to clear "Use Windows to configure my wireless networks" on the Wireless Networks tab.
However, if this does not resolve the issue we will need to get some additional details from you to be able to assist you further. I have summarized my questions below:
1. Can your computer go online when it is hardwired to the router?
2. What wireless adapter are you using?
3. What is the operating system of your computer?
Connecting to a Wireless Network on Mac OS:
a. Click the AirPort icon and select Open Internet Connect.
b. When the Internet Connect screen appears, click AirPort.
c. Look for Network and select your wireless network’s name or SSID.
d. Enter your wireless network key on the field provided then click OK.
Connecting to a Wireless Network on Windows Vista:
a. Click Start then select Connect To.
b. Connect to a network window will show up.
c. Select your wireless network's name or SSID and click Connect.
d. It will ask you for a network key. Type in your wireless network key on the field provided. Then, click on Connect.
onnecting Through Wireless Zero Configuration (Windows XP SP1 and SP2)
1. Please right click on the Wireless icon on the right lower end portion of your computer. Then, click on View Available Wireless Networks.
Posted on Jul 11, 2009
  • 1,272 Answers
Hi, if this computer is going to be wired then just connect it to the router using a ethernet cable and can access internet.
For wireless, follow the steps below to check security key:
Please follow the steps on a computer connected to the router so as to check the network key:
1. Open the browser(Internet Explorer or Mozilla Firefox).
2. Access the router usually http://192.168.1.1 else try http://www.routerlogin.com
3. Login to the router (User Name = admin Password = password unless you have changed it).
4. Click on Wireless Settings'(under Setup) from the left menu.
5. Check if 'WEP (Wired Equivalent Privacy)' or 'WPA-PSK (Wi-Fi Protected Access Pre-Shared Key)' is selected under 'Security Options'.
6. If WPA-PSK is selected, copy the code entered in the passphrase.
7. If WEP is selected, copy the code entered in the Key that has a black dot before it.
This is the code required for connecting the wireless computer to the routers' wireless network.
In some cases, for security reasons the passphrase might show as asterisks. In this case type a new password and click apply. You will then have to use the same password for all the wireless devices connecting to the network.
Scan for the wieless network on the concerned computer and connect to the network.
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. If you cannot rate this post with the highest rating, then please comment to this post and I will try to help you further.
Posted on Jul 04, 2009
Cant hook up my ps3 to my netgear wgr614 n150
need to get ps3 component cable that can hook directly to the router,if it is a wireless router goto ps3 setup menu,then turn on network discovery on ps3,then will ask for password from router fill password in,it will hook up.
Dec 21, 2012 | NetGear WGR614 Wireless Router
I need to disconnect the 2nd computer to the wireless connection on my computer. Please can you help me
Click on the wireless icon in the system information box on the 2nd computer to open - click disconnect from this network.
Mar 03, 2011 | NetGear WGR614 Wireless Router
I just installed netgear wireless-g router WGR614 on my main pc modem with i have internet service with Clear. HOW DO I GET INTERNET SERVICE ON MY OTHER COMPUTER WHICH ALSO IS A DESKTOP? i CONNECTED A CORD...
Are you trying to set up the router.
You can do it manually without the CD.
Make sure that your computer is able to go online
through the modem.
If your computer is able to go online through the
modem
Then you need to connect the computer to the
router and the modem to the router.
open the set up page of the router and change the
settings of the router according to the ISP.
Click Here for step by step by instructions
Feb 11, 2010 | NetGear WGR614 Wireless Router
Could not make router to work, Netgear modem adding router.
i suppose you have to connect modem to router's "source" socket and modem to socket "in wall" then reset and reconfig router and you should be ok
Nov 10, 2009 | NetGear WGR614 Wireless Router
2nd Computer in basement cannot access Internet
if your signal is low in there the best work around would be to lay a cat-5 cable up to the router, the wired connection would be faster and more reliable then a wireless, or buy another wireless router and put it closer to the basement than the first and wire the 2 routers togher with cat5 using the second router as a fancy switch.
Jul 02, 2009 | NetGear WGR614 Wireless Router
Can't get wireless connection
try locating the wireless switch of your new Acer. It might be accidentally turned off thats why no available wireless network found in range
Jun 11, 2009 | NetGear WIRELESS-G WGR614 802.11G WIRELESS...
Wireless adapter on 2nd computer is not connecting to my router
you put in the usb port then install the driver then you find it the wireless icon will came in the task bar right hand side in bottom then you right click on it then you got the option view viable networks click on it then you got the your ssid name just connect it then surf it
May 13, 2009 | NetGear WGR614 Router
Laptop wireless computer on 2nd floor. Modem and
To test it whether the signal is too weak or not, take your laptop closer to where the router is and try to connect that way. If it does connect then the wireless signal from the router is too weak in which case get a range expander or purchase a router with extended range.
Mar 23, 2009 | NetGear WGR614 Wireless Router
Bright house modem and desktop computer, trying to hook up wireless net gear router for 2nd desktop to get internet? How do I configure the cables?
Connect the lan cable from the dsl modem into the first port on your netgear router ..
make sure your dsl modem is on PPPoE mode so that it autoconnects..
Now just connect to your wireless router via your pc interface..
*Do add a network key to your wireless network to avoid unwanted access
Jan 19, 2009 | NetGear WGR614 Wireless Router
Hooking up a 2nd computer upstairs with the router downstairs.
In order to setup a second computer with your router you need to first make certain that you have the following:
The second PC must have a wireless adapter. Determine if you have security setup for your network. Meaning determine if you have a wep, wpa, etc. setup. This is a security Hexidecimal encryption that allows only the administrator (you) of the network the ability to place other devices onto your network. You then need to access the web-based tool that allows you to setup and or change settings. Any more questions please feel free to ask I could walk you through it step by step.
Nov 25, 2007 | NetGear WGR614 Wireless Router
NetGear WGR614 Wireless Router Logo
378 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
