The new lamp doesn't fix as snug as the old lamp did. Same model part as old lamp but hearing electrical sounds now with new lamp when powered on but then goes right back off with red light coming back on.
I would venture to guess the bulb figment is your issue and the electrical sound is most likely arching (very bad). The cheap replacements won't last. I bought a sylvania build and matched the model number with the one from inside the old bulb housing. Changing out the bulb from the casing is really easy so just return the one you bought and buy the corresponding bul without the case.
I will try that thanks so much Travis..
Someone else might suggest hat you Chang out the ballast, but definitely go bulb first. I changed out my ballast at one point with a similar problem and the problem was the bulb. I went through a replacement before ordering just the sylvania bulb. I replaced my bulb about 8 months ago now with no issues.
SOURCE: Mitsubishi WD-65733 no picture, electrical buzzes in series
What it sound's like is that the lamp ballast is the problem. Buzzing sounds like when the power is first brought to the ballast it has to ramp up the voltage to get the lamp to light, then the voltage drops back down when the lamp is lit. Sounds like the lamp ballast isn't ramping up the voltage the way it should. May have to replace it. A good service shop would be able to do this for you.
Blessings,
A/V Media Guy
Testimonial: "very helpful. this was my first thought! thank you!"
SOURCE: WD-52525 Red lamp Indicator
usually with that model when you get a 34 eror code for lamp abnormality, its directly related to the capacitors on the Power Pwb. You can get the V26 Power PWB repair kit at the following link which repairs that issue. It contains the replacement High temp capacitors with the board location numbers and PWB identification as well as the service manual on CD. Heres the link its under their repair kit ctegory.
http://servicemanuals.vstore.ca/
SOURCE: wd 52525 red lamp light on but new lamp isn't
HI. the actual issue will be a failed ballast device. replacing this damaged power regulator will fix this issue. you can order your new ballast by clicking the link below.
Ballast(Click here to order)
SOURCE: Mitsubishi WD-73733 73 in. HDTV
Could be the ballast of your tv please check our web page so you can find it http://www.discount-merchant.com/
Said
SOURCE: WD-52631 Red Light-No Picture, still have Sound
I also unplugged from the wall, and did the reset procedure. That worked a few times and then it didn't work anymore. Thanks for the help, just wanted to warn it may only work temporarily.
