Question about GE Monogram Refrigerator Built-In Side-By-Side 48" Non-Dispenser
Intermittent rattling noise in refrigerator
There is an intermittent rattling noise in my GE Monogram refrigerator that happens every 10-15 minutes. The rattling sound is like a woodpecker pecking, and lasts for 4 or 5 seconds, then stops. This intermittent rattle returns in 15 minutes or so.
    Sergeant:
  • 222 Answers
Do you have an ice maker? That noise could be the ice maker trying unsuccessfully to dump ice, usually caused by a defective heater to loosen the ice cubes prior to dumping them into the container.
Possibly even if your ice maker appears to be functioning normally, it may be attempting to dump ice several times before the ice is actually ejected and if you don't use a lot of ice, you'd never notice it.
Hope this helps.
Posted on Jun 27, 2009
GE Monogram side by side model z1s420nmc is making a ratlling noise once in a while
Just to give you an idea about what might make that noise check my video out. A list You will see how compressor mounted and check Your own fridge from where noise might come from.
Jan 04, 2012 | GE Monogram Side by Side Refrigerator
Bad humming noise for ge monogram ice maker zdis150wss. stopped working entirely.
pretty big job to replace compressor on this refrigerator. Thats video I made on one of my customers monogram. Hope That helps.
Apr 20, 2011 | GE Monogram ZDI15C Automatic Icemaker
36" SxS not cooling
unplug it for five minutes... if it dosent come back on the pc board must be replace....
Apr 09, 2010 | GE Monogram® ZISS420DMSS Side by Side...
My built in side by side is making a noise about every 30 minutes or so that sounds like a woodpecker pecking on it...about 10 times. It is driving me crazy! Have any idea what this might be?
I have the exact problem with my built0in side-by-side Monogram. 1 yr 3 months old, and it sounds m=like a woodpecker for 3 seconds approximately 1ce/hr. Does not appear related to ice maker. You can create the sound by changing the temp setting on the drawer at the bottom. As you command a lower temp, the sound happens a couple seconds. Actually sounds like a solenoid opening and closing at 60Hz frequency, as though a control board were feeding AC to a DC coil. Any ideas? Fortunately, this fridge has a 2 year warranty, but this should not happen to a $6K dual condenser fridge in just over a year!!
Jan 09, 2010 | GE Monogram® ZISS420DMSS Side by Side...
GE Monogram side by side compressor runs loud - sounds like rapid knocking. what can i do?
check if it is the fan make that noise and not the compressor but if it is the compressor then you might need a new starter unit to the compressor
Jan 01, 2010 | GE Monogram Side by Side Refrigerator
Ice/water dispenser panel dead on a GE monogram refer
there's a mother board on all the ge machines and everything runs through it part WR55X11130 i'm not saying this is your problem but it does power the dispenser board,here's a great site that shows you what the mother board does
https://www.scribd.com/document/243353634/GE-Electronic-Refrigerator-AC-Diagnostics-Manual
you can try this to run it diagnostics
http://www.msaworld.com/wp-content/uploads/sites/3/2014/05/GE-Monogram-Diagnostic-Mode.pdf
did you try killing the power for like 10 minutes to see if it resets,also there's a lock on the dispenser but i'm sure you checked that,that's it you either have a bad dispenser board,a bad mother board or a broken wire, this is what happens with all the computer boards added into these appliances,lol good luck at least you're not loosing any food
Nov 18, 2017 | GE Refrigerators
My GE 48 inch built in fridge began making a strange noise.
fan motor problem ge has the solucion replacement fan motor around $350 plus mine still makes the noise
Jun 19, 2009 | GE Monogram ZISS480DRSS Stainless Steel
Noise
Is the noise constant or sporadic?
Jan 20, 2018 | GE Monogram ZISx420DR 42-inch Side by Side...
Ge monogram refrigerator is shooting water/ice out.
The same thing has happened to us with the ice. We just unplugged the ice maker for a few seconds then plugged back in. that seemed to work. hasnt happened in a while.
Nov 27, 2008 | GE Monogram ZISS420NRSS 42" Built-In...
GE monogram side by side built in refrigerator: fan behin Climate control drawer makes noise when it starts
IS THE NOISE SOMETHING HITTING THE FAN BLADE?
CHECK THE FAN ASSEMBLY BY REMOVING THE BACK PANEL IN THE FREEZER COMPARTMENT.
NORMAL NOISES IN THE UNIT ARE A GURGLING NOISE OR THE SOUND OF RUNNING WATER OR HISSING. THIS IS DUE TO THE FREON BEING PUSHED THROUGH THE SYSTEM AS THE COMPRESSOR RUNS. POPPING OR SNAPPING CAN OCCUR WHEN THE COILS IN THE FREEZER MOVE DUE TO A CHANGE OF TEMPERATURE.
Apr 08, 2008 | GE Monogram ZISS420NRSS 42" Built-In...
GE Monogram Refrigerator Built-In Side-By-Side 48" Non-Dispenser Logo
2,338 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
