Question about Teledyne Laars Laars Lite 2 Pool Heater 250,000 Btu / Natural Gas
I was given a Laars pool heater, model R0096400, and I can not get the pilot switch to push down to lite it. Is there some kind of pressure release or step that I am missing. Or is the switch just broken?
  • propofthesta Jun 28, 2009
    The switch reads off, pilot, on. Pilot being the word closest to the panel opening.
I have the same issue , i can't get the pilot switch move from off to pilot. I asked a pool service guy come to fix, he could not move it too, and told me that i need a new valve. any workaround solution or do i have to order a new one, it cost $340 online.
Posted on Jul 08, 2009
    Problem Solver:
  • 9 Answers
Is the word "pilot" aligned with the post on the valve body?
Posted on Jun 28, 2009
  • fixem2 Jun 28, 2009
    P.S. : ...with the arrow on the beige(?) knob pointing to the word "Pilot", you should be able to press the knob down to manually start the flow of gas to the pilot assembly; if you can't push the knob down, do not use this valve!
Laars Pool Heater, pressure valve or something else,
bad pressure switch or incorrectly set should have no continuity when off it should when running put on 2000 for ohms should have 500 millivolts when off then turn on and it will start counting down at about 200 should light make sure all connections are good and all safety circuit is good
Jun 24, 2015 | Teledyne Laars Laars Lite 2 Pool Heater...
Laars Lite 2 Heater will not go on
make sure little pump is moving if not check syphon tube going to pressure switch if ok check pressure switch
Jun 29, 2013 | Teledyne Laars Laars Lite 2 Pool Heater...
Laars lite 2 pilot
make sure gas pressure is correct if ok see if the silver tube has a cobweb also make sure all connections are good
Sep 04, 2012 | Teledyne Laars Laars Lite 2 Pool Heater...
My pilot light is lit but the heater won't turn on.
GET A NEW PRESSURE SWITCH.. CALL AND ASK FOR A PRESSURE SWITCH FOR SAY A HAYWARD POOL HEATER .. LOOKS LIKE THIS ..EBAY Pressure Switch Hayward generic pool heaters also H100
May 20, 2010 | Teledyne Laars Laars Lite 2 Pool Heater...
I have a Laars pool heater, model R0096400, and I can not get the pilot switch to push down to lite it. I asked a pool service guy come to fix, he could not move it either , and told me that i need a new...
Sometimes the spring inside the valve can be jammed. If it will not go down and by chance you are unable to force it down, then chances are it won't stay up either. So in all...You will have to get new valve.
Jul 08, 2009 | Teledyne Laars Laars Lite 2 Pool Heater...
I have a Laars pool heater, model R0096400, and I can not get the pilot switch to push down to lite it. asked a pool service guy come to fix, he could not move it too, and told me that i need a new valve....
your pool guy may be right but before spending any hard earned cash,remove phillips head screw in middle of on/off/pilot knob and remove.make sure there is no debris under knob.squirt spray lubricant along stem wait 10 minutes and lube again.replace knob turn to pilot position work it by pushing down several times.it may stick in down position so gently pry up.my success rate is about 70/30 for this technique
Lighting the pool heater
You will need to buy a new thermo couple 8.00 part from ace it is the little copper line close to piolet flame,it sences the piolet and allows the gas to open and feed,it is wore out,burned out,replace.
Mar 30, 2009 | Teledyne Laars Laars Lite 2 Pool Heater...
Teledyne Laars Laars Lite 2 Pool Heater 250,000 Btu / Natural Gas  Logo
164 people viewed this question
Top Teledyne Laars Pool & Spa Experts
Paul Carew
Craig Butler
Craig Butler
Jay Finke
Jay Finke
Are you a Teledyne Laars Pool and Spa Expert? Answer questions, earn points and help others
