Question about HP Officejet 4315 All-in-One Printer
Label misalignment for 14 label per sheet
Label alignment for 14 label per sheet (Zerox/Avery) is off. Seems as though the printer doesn't feed immediately, hence the misalignment.
  • anngdip Jun 29, 2009
    Makes sense. I'm about to purchase the alcohol to test. Will then let you have the results.
    Thanks
    President:
  • 3,085 Answers
Open the rear door and clean all rubber rollers with alcohol
Posted on Jun 27, 2009
  • Leroy Elliott
    Leroy Elliott Jun 29, 2009
    Good Luck, Scrub Hard !
How to print labels
Use Avery Label sheet.
Set correct paper size on Word and the Operating system.
Use label from Sheet feed tray only.
According to the printer specifications for the Officejet 8600 Pro Plus, the following label sheet sizes are supported;
HP Officejet Pro 8600 All in One Printer series N911 Manuals
Mar 15, 2016 | HP Officejet Pro 8600 Plus e-All-in-One -...
How can I get my Avery 8876 business card sheets to feed through my printer?
Avery is a fairly good name in the business.Brother on the other hand seems to have ignored the reasons why folks don't buy brothers. It's these little annoying things that bigger company's have spent time and energy on. For one there's usually a lever you push to control how much pressure the two fusing rollers push; hot rollers, for years this perplexed the big guys because there all ready is a pretty small tolerance of melting the toner and not burning the paper; melting the toner(powered plastic) next was the ever annoying OHP overhead projector sheets. this is plastic toner on plastic"paper" nightmare! melt the toner but not the plastic its on.... Well enough of engineering issues, time and perseverance paid off. now comes a sticky label on a waxxy surface that is twice as thick as paper and yet has toner to be fixed on it and dried....Some company's like cannon tried a cold roller that seemed to work at first but when things went bad they really went bad.labels coming off all in the wrong places... Toshiba and Savin Ricoh decided to get with Avery and others and make one side harder to come off than the other; reduce the squeeze pressure and increase the opposite "static cling" voltage. Also the angle it hit the feed section// Bypass feed only/Lt-R. Following the printed directions in the individual label sheet seemed to reduce the issue to a minimum. Understanding all the changes the poor piece has to go go through in an 8second processes is half the battle. hope this helps a smidge~~~SC
Nov 08, 2014 | Office Equipment & Supplies
How to print only one sheet at a time not all sheets
This can be a little tricky. If you haven't used any of the labels yet, simply put the address in the first label and simply print. The printer will print the address on the first label and all you have to do is remove it and put it in place. Next time you need to make another label, set up the program that you are going to use to print the label and once the "Avery 8168 Inkjet" label is on your screen just move the cursor to the second label (With Corel WordPerfect just hold the ctrl key and hit the Enter key) and print your return label. Using this procedure you can use one sheet of labels without having to print all labels at once or using a new sheet.
Oct 15, 2014 | Avery 8168 Inkjet Labels Shipping...
Set up a mail merge for labels avery L7162, but the printer prints them a different size - Printer is HP M3035. It is something not set up on the printer
You will need to feed these through the manual tray and you should set the paper size and type to match this label. The avery site shows this as an A4 label sheet. If you are in North America the default on this printer is letter size not A4.You should also ensure that you have configured the print driver correctly when you go to print.
May 23, 2011 | HP LaserJet M3035xs MFP All-In-One Printer
How to print labels w/ 1320c
Using Microsoft Word:
  • Click on "Tools"
  • Click on Letters and Mailings
  • Select Envelopes and Labels
  • Select Labels Tab
  • Select Options to select Label Size
  • Select Dot Matrix or Laser / Ink Jet
  • Select "OK" to Continue, you will be prompted to manual feed Label sheet
Please note the 4 digits that precede the label size are Avery Label Numbers
You could also use OpenOffice
Mar 01, 2011 | Dell 1320c Laser Printer
How may I format 10 labels / page using Avery 8163
right click your printer. go properties. select printimg preferences. select features. find page selections & choose
Jul 25, 2010 | Computers & Internet
Lexmark T640 won't print on label sheet a SECOND time...
try changing feed rollers. For a quick fix, remove the rubber rollers and flip them inside out. It should work
Jan 28, 2009 | Lexmark T640 Laser Printer
Printer Jam - when i put a sheet of Avery labels, printer jams
When you say TOP TRAY, do you mean a paper drawer, or the BYPASS TRAY? If the labels won't feed into the bypass but bond paper does, check to see if your labels are made for inkjet printers. Go to www.avery.com and contact Avery customer support to see what product they recommend for your MFC. Labels made for plain paper printers sometimes do not work for inkjets, and vice-a-versa.
Aug 29, 2008 | Brother MFC-5840CN All-In-One InkJet...
Avery Ink Jet Magnetic Sheets - 3270
It worked fine for us on an Epson. We printed about 40 sheets fed one at a time. Do not stack the sheets in the feed hopper, they stick together because of the magnetism.
There is no template because the material is not die cut. It is just full 8.5x11" sheet size.
Feb 04, 2008 | Avery DesignPro Deluxe CD-ROM...
198 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
