Question about Orbit Sprinkler System Power Source Transformer #57040
Sticking impulse sprinkler
Plenty of water pressure, I have a couple of sprinklers that are stuck,, I have wd 40ed them, any help with making these work again, I have about 10 altogether
Thanks,
James
  • 4 Answers
Wd 40 is the worst thing, oil based prod break down internal parts. best is to dig up take apart wash with water and reassymble. if not better only choice s to buy new
Posted on Aug 06, 2009
2 Suggested Answers
  • 583 Answers
SOURCE: Impulse sprinklers stick after cloclwise rotation; no return
i wouldbet it is a pressure related problem , can you isolate them so you are only running 1 at atime? at least reduce the number of sprinklers running at the same time just to test them, drop the number by1or2 and i`m sure your problem will be fixed youdoit
Posted on Jul 27, 2009
Melnor sprikler not ocillating
Do you have hard water? They operate via a water pressure powered mechanism, either the mechanism is stuck and needs a push, there is insufficient water pressure, or it is clogged with sediment.
Jul 10, 2016 | Melnor Oscillating Sprinkler
My sprinkler head is stuck spaying in one spot and I can't figure out how to adjust the range and distance of it.
Sounds like you have a bucket impact sprinkler. These are problematic as they tend to beat themselves into non-operation from the moving parts involved and the impacts. They stop turning for a number of reasons, low water pressure, dirt and debris filling the bucket impeding rotation, plants covering the sprinkler etc. If no debris is found and others continue to work on same zone the water pressure is probably unchanged it may just be tired. I suggest replacing it using a pop-up rotor preferably a Hunter PGP-ADJ or PGJ-ADJ Rotor as rotors have only 1 moving part a gear which is sealed inside the sprinkler making them very dependable.
May 14, 2014 | Orbit Sprinkler System Super-jet 3-inch...
Our raintrain has worked for years....but now it is leaking out of the bottom causing it to get stuck often......please help us!!!!
I think your valve is shot. There is a button underneath that is pushed up by the ramp. It then closes the valve. The valve is leaking and lowering your water pressure causing your sprinkler to get stuck.
You could replace the valve but that requires disassembly of the gear box. The gears inside may be worn too so, I am suggesting that you just replace the gear box. Replacing the gear box will give you all new moving (and sealing) parts. This web site has a box for about 1/2 to 1/4 the price of a new sprinkler.
http://www.sprinklersupplies4less.com/traveling-sprinklers-nelson-1865-replacement-parts-c-384_627.html
Jul 08, 2011 | Nelson Sprinkler: Traveling Tractor
My tractor sprinkler was running fine and then suddenly stopped. What should I look for as the problem?
My sprinkler did (something like) this a couple of times (very infrequently) - the arms seemed "seized" (cannot rotate clockwise or counter clockwise) but, I was able to get them moving again by picking up the sprinkler (a couple of inches) by the sprinkler arm T-pipe. Picking it up this way, vertically, seemed to "un-stick" the arms.
Of course, if your sprinkler is very old (12 years?) the gear box may be worn, it would cost about a quarter to a third as much as a brand new sprinkler to replace. You can find the parts you need by reading the question about where to get parts at FixYa.
Jul 02, 2011 | Nelson Sprinkler: Traveling Tractor
I have an aquamate pump and when i connect it to a continuous sprinkler it stops and starts contiuously
The pump is putting out too much water for the sprinkler.
You can raise the pump shut off pressure at the switch until it is higher than the pressure that the pump runs at with the sprinkler operating. You should have a surge tank connected to the system to give the pump time to balance with the sprinkler.
You can use more water with the sprinkler. This could mean adding another sprinkler or increasing the nozzle size of the existing sprinkler.
Dec 05, 2010 | Garden
I need assistance with properly setting the water flow, range, and rotation of the 993hps Gilmour Impulse sprinkler and the 967hzs Impulse Spike Base Sprinkler. There were not directions with the products...
For some simple instructions check out the "additional information" section at http://www.gilmour.com/Watering/Hose-End/Sprinklers/Large-Coverage/Metal-Head-Impulse-.aspx. If your sprinkler doesn't rotate, ensure that you haven't lowered the water pressure by opening another faucet elsewhere. My sprinkler doesn't rotate as freely as it did when it was new, but it probably just needs to be taken apart and cleaned and greased.
Aug 04, 2010 | Gilmour Mfg Metal Impulse Yard Sprayer...
I have low water pressure on my rainbird sprinkler system. how can i adjust it?
There are several ways to adjust water pressure on sprinkler systems. First you have to determine if there is a problem with the sprinkler system itself. Things to look for:
1.) make sure that all valves including the main are all the way open.
2.) Inspect the sprinkler heads for clogging. Sediment and debris can also clog your sprinkler heads. Some debris removal may be required.
3.) You make have too many sprinklers operating by one valve. You may need to divide a zone and add another valve to increase water pressure.
4.) If all else fails. You can install a breather intake cap to allow air into your sprinkler system thus increasing GPM (gallon per minute)flow.
5.) one of the biggest mistakes that peopel make is that they undersize the water pipe size to save money. Typically you want to use 3/4" PVC pipe for your main runs and tee into 1/2" PVC for your sprinkler heads.
Good luck. I hope this helps.
Jul 20, 2010 | Rain Bird Hardware & Accessories
Why do my faucets leak when I turn my sprinklers on?
THERE TWO CAUSES THAT I KNOW OF: 1. YOUR FAUCETS ARE PRESSURE SEALING MEANING: THEY NEED A MINIMUM PRESSURE TO SEAL MOST LIKELY 25psi, YOUR SPRINKLER SYSTEM IS STARVING THE ENTIRE SYSTEM OF PRESSURE WHICH ALLOWS YOUR FAUCETS TO LOOSE THEIR SEAL. SOLUTION:REPLACE FAUCETS WITH SPRING SEAT SEALING FAUCETS. 2. YOU HAVE A WATER LEAK IN YOUR MAIN WATER LINE AND THE FAUCETS ARE LEAKING AIR BACK INTO THE MAIN LINE WHEN THE SPRINKLERS ARE OFF AND WATER INTO THE SINK WHEN THE SPRINKLERS ARE ON... THIS SCENARIO IS UNLIKELY AND YOU WOULD HAVE OTHER PROBLEMS SUCH AS AIR IN THE LINES AND THE FAUCETS WOULD LEAK WHEN YOU TURNED ON THE SHOWER AS WELL AS THE SPRINKLER SYSTEM.
Oct 16, 2009 | Moen 87530 Touch Control Single Handle...
Jul 22, 2009 | Orbit Sprinkler System Power Source...
Brass Champion Sprinkler Valve
The lowest sprinkler head usually leaks until all the water is out of the system. The valve that controls the sprinkler system has a vaccum breaker valve on it. When there is no pressure from the water main the vaccum valve opens allowing the sprinklers to leak water so the house water won't get contaminated from the grass and dirt in your yard.
Jul 27, 2008 | Electrical Supplies
Orbit Sprinkler System Power Source Transformer #57040 Logo
1,170 people viewed this question
Top Orbit Hardware & Accessories Experts
Craig Butler
Craig Butler
Hippy_dd
Are you an Orbit Hardware and Accessory Expert? Answer questions, earn points and help others
