Question about Sony CDP-C545 CD Player
How do I open manually as a cd is stuck? - Sony CDP-C545 CD Player
  • 34 Answers
Get a large paper clip and straighten it out. Then look on either side of the drawer, right above it or below and you will see a very small hole. Insert the paper clip into it and you will fel it push up against a manual switch. Slowly push and the drawer will unlock and you can pull it open.
Please rate this if it helps you. Thanks and have a great day
Posted on Jun 27, 2009
  • jdaniher
    jdaniher Jun 27, 2009
    OOps, wrong model Sorry. Here are the instructions.
    Without turning the unit upside down, look at the bottom of the player. You should see a small round hole toward the front of the unit, with a white plastic part inside with a slot. Take a screwdriver and turn this gear manually with the power off. You should be able to unload the discs by rotating this gear. Be careful not to tilt the unit, as the discs will fall out of the tray, and you'll have to open it to retrieve them.
CD IS STUCK IN MY 2004 MERCURY MARQUIS. HOW DO I REMOVE CD?
You might try resetting the CD player by removing all power, BUT this requires disconnecting the battery! If you're not familiar w/that process, take it to a shop.
NOTE YOU WILL LOSE YOUR Presets on the radio and you may need to also reconnect your keyless remote fobs. Read up in the Owner's Manual about how to do that.
If that doesn't work, you'll need to remove the CD Player from the car and manually try to open/retrieve the stuck CD.
Good luck
TD
Nov 28, 2017 | Mercury Cars & Trucks
How do i fix a multiple cd player kenwood, when a cd is stucked and not playing?
We have one of these and had to open it up and manually remove the excess, stuck CD's from the inside manually. After that it is playing normally.
Nov 26, 2014 | Televison & Video
I have an AKAI DVD RECORDER DVDRW 120... 3565-1546/ My problem is that the tray is stuck and will not open. I do not want to pry it open and am hoping that you have a solution that can help me.I have...
This is a common problem. There might be a cd stuck inside (they ussually get stuck on top spindle) plug out and open cover and manually release cd
May 12, 2011 | Akai DVDRW120 DVD Recorder
I have a 1996 ford explorer and the 6 disc cd changer is stuck and will not eject, I can hear it trying when I press eject button, any ideas???
good day. well if some kinda stuck you should open it manually. you can find a little hole on the cd changer just use a paperclip then insert it to the hole it will be open manually. and hope that it will not trip right after you put the cds again. hope this helps
Feb 04, 2010 | Car Audio & Video
Cant open my new ASUS desktop CD case. NO manual?? Help
There is a small hole in the front of all CD players in computers. If the slide is stuck/jammed insert a paper clip into the hole to manually open the CD slide. You may also go to My Computer, right click on the CD drive and select EJECT.
Aug 10, 2009 | ASUS Desktop bare bone with P4S800-MX MB...
CD is stuck in my bose lifestyle system, the message displays as "opening" but does not open
Not familiar with this model but all cd tray's have a manual release mechanism, its usually a small hole on the front of the tray. I've found a paper clip unwound usually works fine. Push it in the small hole, you will feel it stop against something, push a little harder and the tray should open enough for you to manually pull it open.
Jan 24, 2009 | Audio Players & Recorders
Disc Drawers will not open
There maybe a CD stuck in the mechanism or it may need to be mechanically reset. Not much you can do except take for repairs.
Jan 05, 2008 | Sharp CD-ES9 CD Shelf System
Cd player stuck
Hi..
It will have to have the coverr taken off and the drawer belt replaced.
Find a stereo repair place.
Nov 23, 2007 | Yamaha CDC-585 5-Disc CD Changer
The cd is stuck
Some CD/DVD units have a manual opening mechanism, it looks like a small hole on the front of the unit, try using a needle or a metal rod that fits by inserting it into the hole and pushing it should open the unit in case it got stuck somehow. If afterwards it continues to work then all's good else you'll have to bring it to a workshop.
Sep 30, 2005 | Pioneer AVXP7000CD Car Video Player
Sony CDP-C545 CD Player Logo
191 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
