Short cycling air conditioner
My air conditioning unit is short cycling. I have had trouble with the unit since 2003 when I purchased the house. The refrigerant leaks out every year and has to be replaced. They have replaced the evaportor coil, the motor (both inside) and roters (I think) outside. All my neighbors have the same units and never have any trouble. I have about 20 service calls on my unit. I had to call the company back in January because some wires were left disconnected and the heating unit would not work. I have not had any trouble with the heating unit until then. I do not think the inital cause of the leaking refrigerant was ever fixed. Any help you might offer will be greatly appreciated.
  • 86 Answers
Depending onthe age of the unit it would be wise to have someone use a refrigerant leak detector to find the source of the problem. if it is over 15 years old i would probalby think about replacing the unit with a new 410A refrigerant unit due to the R-22 refrigerant getting phased out of production(the price is really going up) it sounds like the company you have might not know what they are doing i would look in the phone book and call another company and ask about doing a whole sytem leak search it might cost about $500 bucks to find the actual leak and repair it (have the guy physically show you where it is with his meter) but its a lot cheaper than adding refrigerant every year
Posted on Jun 27, 2009
I have a new Delonghi portable AC PAC N115EC (11,500BTU), is it normal for the compressor in this particular A/C to be cycling on/off every 2 to 3 minutes?
If the room is cool, it sounds like the unit is operating correctly. It could be short cycling because the unit is over sized for the room being conditioned. if you can, increase to size of the load by opening a door into another room. As long as the refrigerant pressures equalize from high to low side internally and the compressor doesn't start up under load, you should be fine
Sep 10, 2016 | DeLonghi Heating & Cooling
Rv a/c is off but every 5 min it turns on runs for 1 min then turns off. is this short cycling? the tstat is off. there is no call for a/c. ???
SOMTHING IS TELLING THE AC TO COME ON POSSIBLE SHORT ALSO YES IF UNIT IS COMING ON THEN SHUTTING OFF ITS SHORT CYCLEING (SHORT OF FREON)
Oct 07, 2013 | Dometic Rooftop RV Air Conditioner
My ducted roof top Dometic Briskair will run fine when first turned on for one complete cycle, then the next cycling is short cycling, 2-3minutes on and 30-60seconds off.
Sounds like a low freon issue. Even though its cooling well at first after its run a cycle the amount of freon is to low causing it to cut out probably from lack of freon pressure. Get it checked soon cycling will definitely shorten the life of your compressor. Hope this helps Chris
Jul 15, 2013 | Dometic Rooftop RV Air Conditioner
Hi, I have a question about anti-short cycle, can anyone explain what exactly 'anti-short cycle' is? If I am running the air conditioner's compressor with a soft-starter (1-phase and 3-phase), does...
Anti-Short-Cycle Timers - Airotronics
www.airotronics.com/products-antishortcycle.phpAnti-short-cycle timer prevents premature cycling of compressors in refrigeration, air conditioning and heat pumps, thereby reducing nuisance tripping of fuse or circuit breaker.
Feb 14, 2018 | York / Cam-stat Anti-short Cycle Timer...
Panasonic air con unit is not blowing cold air out.
This unit is use in motels etc. Check the ouside coil ( conderser) from the inside (discharge fan ) for dirt. Most of these units are floor level . This can cause a unit to short cycle ( cold air is at the floor) .
Jul 17, 2009 | Carrier 52PQ307 Wall/Window Air...
My outside air conditioning unit keeps starting for a few seconds, then stops, then starts again and then turns on. The house is cool but it keeps doing this all of the time.
Constant starting is going to run up your electric bill a lot. Have the unit checked out by a professional repairman. It could be as simple as a weak relay, or your outside coils could need cleaning. Definately check the inside coils, there are coil cleaning sprays that will clean them good.
May 08, 2009 | Heating & Cooling
CENTRAL HEAT AND AIR UNIT NOT COMING ON.
compressor short cycling,you need a new start capacitor
Mar 08, 2009 | Heating & Cooling
Air conditioner short cycling
Sounds like the thermostat probe is behind the filter,next to the coil,and not sensing good return air . just punch a hole through the filter so the bulb can sense return air! thank you-very-much!
Jul 21, 2008 | Dometic Rooftop RV Air Conditioner
Heating & Cooling Logo
514 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
