Motorola Mobility Photon 4G Android Sprint Logo
T
Tanya Posted on Jun 26, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Like how do i get safe mode off - Motorola Mobility Photon 4G Android Sprint
  • Official Brand Answer 3,100 Answers
  • Posted on Jul 10, 2014
Motorola Mobility
Level 0:
Answers
3100
Questions
Helped
684213
Points
13487
Reboot your phone with power button.
How I turn off safe mode?
make model helps, but we can guess I guess!
Safe mode is displayed on the screen of the Android TV
  1. To enter the Safe mode, follow the steps below. Power Reset or Restart of the TV. Power Reset. Note: Skip this step if your TV power cord is inaccessible. ...
  2. To exit from Safe mode: Press and hold the POWER button for at least five seconds to reset your TV.
Oct 6, 2023
Safe mode is displayed on the screen of the Android TV - Sony
1helpful
Hw to get safe mode off a Nextbook tablet
To get out of Safe Mode, please try the following.
1. Touch and Hold the "Power" key.
2. Tap "Power Off".
3. Once the tablet is off, Touch and Hold the "Power" key again to restart.
The tablet should now be out of "Safe Mode".
If the "Safe Mode" is still running after you restart your phone, I would then check to make sure your "Volume Down" button is not stuck. Check to see if it has anything stuck in it as well, dust, etc. Anything like this can cause the phone to go into, and get stuck in, "Safe Mode".
If that doesn't work try this...
Use the "Status Bar" to turn off "Safe Mode'. Pull down (swipe) the "Status Bar" of your phone. Now tap the "Safe Mode" button. This should turn "Safe Mode" off. Now your phone will automatically restart, so that it boots up out of "Safe Mode".
And lastly...
If you want to get rid of/disable "Safe Mode".
1. First turn off the tablet.
2. Next press and hold "Power" until you see the manufacturers logo on the screen, then release the power button.
3. "Quickly" press "Volume Down" and hold it for few seconds until you see the message "Safe Mode: OFF" or something similar.
4. If you wanted re-enable it, simply repeat the steps above, and you should see "Safe mode: ON" rather than off.
I’m happy to assist further over the phone at https://www.6ya.com/expert/latoya_8ed1bf3dc615c15d
My tablet has safe mode in left corner,hOW DO YOU SHUT IT OFF?
Get an Android Tablet out of safe mode - Support Home Page
acer--uk.custhelp.com/app/.../get-an-android-tablet-out-of-safe-mode
How do I get my Android tablet out of safe mode? Use the ... Restart your device by holding the power button, then tap Power off. ... Did this answer help you?
Samsung Galaxy Tab 3: Turn Safe Mode On or Off
www.technipages.com/samsung-galaxy-tab-3-turn-safe-mode-on-or-off
Mar 15, 2014 - Use the Safe Mode feature on the Samsung Galaxy Tab 3 to start the Android OS with the system default software. ... When the Galaxy Tab 3 logo appears on the screen, press and hold the "Volume Up" button. ... Once the device has completely powered off, you can press the "Power ...
Galaxy Tab 4: Enable or Disable Safe Mode - Technipages
www.technipages.com/galaxy-tab-4-safe-mode
Mar 4, 2015 - A tutorial about how to turn Safe Mode off or on for the Samsung GalaxyTab 4 tablet.
Power the Device Up in Safe Mode - Samsung Galaxy Tab 2 ...
Start up
SAFE MODE OPTIONS
1. Press the System or Menu Button in the lower left corner and navigate to Manage apps.
2. Find the most recent app you installed.
3. Force close it.
4. Disable it if possible.
5. Remove this app.
6. Reboot the boot to see if the Safe mode is gone.
If the Safe mode label is still present, the article suggests that it may be necessary to press several keys to achieve the removal of the Safe mode label and its effect of suspending the other apps. In essence, we now move to the second discussion of entry into Safe mode:
1. Safe mode can be entered by pressing buttons at start-up. .
2. It is not known exactly which buttons were pressed but it mostly likely was the System and Home (center big button) and maybe even the Escape/Back button on the right.
3. The right combination of buttons, which supposedly are the same to enter Safe Mode, are the same to exit Safe Mode.
4. If you are certain you entered Safe Mode by accident - meaning you know you did not recently or just now installed an app that force closed Android, then you just have to find the combo to exit it.
5. Try pressing the volume buttons might clear the Safe Mode on the first reboot after initial entry into Safe Mode.
6. If the Safe Mode label disappears after pressing the volume buttons, your phone is okay.
7. If the label is still present, try rebooting the phone again.
Safe mode in Android what to do if you see that label on your screen
2answers
How run in safe mode with windows vista
When you turn on your computer, press F8 and that will give you some start up options, the first ones being Safe Mode, Safe Mode with Command Prompt and Safe Mode with Network.
6helpful
Please explain step by step how to reboot a computer into a safe mode?
to boot a system in safe mode restrt your computer as the computer starts press F8 you will see a set of command like safe node safemode command etc click safe mode you will see set of files running wait till the safe mode starts the you will be able to see the mouse icon then it will ask do you want the computer to start in safe mode click yes now you are in the safe mode section in safe mode section the system starts in defult setting you wont be able function somefunctions safe mode is for correctiong your computer or to remove unwanted software or hardware
2helpful
3answers
How do you put windows into safe mode?
Power on or Restart your computer, keep tapping F8 on the keyboard while it boots up. After few seconds, you'll be taken to the "Advanced Boot Options" with "Safe Mode" in the lists. Use the Up-Down arrow keys to highlight the "Safe Mode" and press enter on the keyboard to confirm the selected boot options. Black Screen with white texts will be displayed on the display, wait for few seconds until you see the windows logon Screen. You'll also see a confirmation message box asking you to confirm to boot into Safe Mode, click "yes" or "Ok" and proceed forward. There now you are in the Safe Mode.
If you need further help, let me know.
Good luck.
Thanks for using FixYa.
2helpful
How do I get into safe mode on HP mini 1000? XP OS
To get into safe mode on any computer running Windows you press F8 before or right after the Windows splash screen comes up. You will have three options for safe mode:
Safe Mode: Only the absolutely necessary drivers load.
Safe Mode with Networking: Same as above plus the ability to use the internet/network access
Safe Mode with Command Prompt: Boots into safe mode with a Command Prompt for command line work.
Hope this helps.
Jesse
Top Motorola Mobility Audio Players & Recorders Experts
ADMIN Andrew
ADMIN Andrew
john h
August Brown
August Brown
Are you a Motorola Mobility Audio Player and Recorder Expert? Answer questions, earn points and help others
