Question about ASUS P4V8X-X Motherboard
Usb connectors pin arrangementfor usb
  • 34 Answers
Re: usb connectors
Signal name __________ pin
VREG_FP_USBPWR0 ______ 1
VREG_FP_USBPWR0 ______ 2
USB_FP_P0- ___________ 3
USB_FP_P1- ___________ 4
USB_FP_P0+ ___________ 5
USB_FP_P1+ ___________ 6
GROUND _______________ 7
GROUND _______________ 8
KEY __________________ 9
USB_FP_OC0 ___________ 10
Posted on Nov 06, 2007
0 characters
3 Points
I believe you're referring to the AOpen MX46-533V
The Front Panel USB header is Blue in color, and located in-between the white No.3 PCI expansion slot, and bottom edge of the motherboard;
With the motherboard in the installed position;
5 pins across the Top row, 4 pins across the Bottom row.
Pins across the Top row are numbered EVEN
Pins across the Bottom row are numbered ODD
Starting on the Left side coming across to the Right, Top row;
Pins 2, 4, 6, 8, and 10
Bottom row;
Pins 1, 3, 5, and 7
There are TWO USB connectors supported off of this USB front panel header.
For one of the USB front panel connectors;
A) Pin 1 is USB PWR 0
Goes to the VCC contact pin on the USB connector.
B) Pin 3 is USB_FP_P0-
Goes to the D- pin on the USB connector.
(Data - )
C) Pin 5 is USB_FP_P0+
Goes to the D+ pin on the USB connector
(Data +)
D) Pin 7 is Ground (GND)
Goes to the Ground (GND) pin on the USB connector
E) No pin 9
F) Pin 2 is USB PWR 0
For the other Front Panel USB connector;
A) Pin 2 is USB PWR 0
Goes to the VCC pin on the USB connector
B) Pin 4 is USB_FP_P1-
C) Pin 6 is USB FP P1+
D) Pin 8 is GND
E) Pin 8 is USB_FP_OC0
Leave unconnected
This is more information on a standard USB connector pinout,
( A USB connector, and a USB plug are not wired the same.
The plug is wired backwards from what a connector is.
Otherwise you would have power and signal going to the wrong pins, and burn the USB Front Panel header out on the motherboard )
AOpen MX46-533V motherboard manual, but it is in Japanese.
May be one in English out there.
The Front Panel header pinout, USB header pinout, etc, is easily cross identified,
Manual / Japanese manual for MX46533V / Japanese / 1/28/2006
Go to the far right, and click on the Floppy Drive icon above -
3701.1 KB
On the next page click on the mirror server website that is closest to your country.
This is a PDF file.
The computer you are using now has Adobe Reader on it, which uses PDF files.
After you click on the country server name it may take up to 30 seconds, before the first page comes up.
(File is downloading in background)
For additional questions please post in a Comment.
Oct 19, 2012 | ASUS P5PE-VM Motherboard
DID this HDD (Western Digital Caviar Blue WD5000AAKX 500GB 7200 RPM SATA 6.0Gb/s 3.5" Internal Hard Drive -Bare Drive) can atach in ASUS K8U-X, Thank you, Nikola
ASUS K8U-X - motherboard - ATX - Socket 754 - ALi M1689
1.0 x PCI - Socket 754,
2.0 x Processor - DIMM 184-pin,
4.0 x AGP 8x,
1.0 x Memory
  • Storage Interfaces ATA-133 - connector(s): 2 x 7pin Serial ATA - RAID 0 / RAID 1 / JBOD,
    Serial ATA-150 - connector(s): 2 x 40pin IDC
  • Interfaces 1.0 x Keyboard - Floppy interface - RJ-45,
    1.0 x Hi-Speed USB - SPDIF output - 6 pin mini-DIN (PS/2 style),
    4.0 x Network - Generic - 34 pin IDC,
    1.0 x Audio - IEEE 1284 (EPP/ECP) - 25 pin D-Sub (DB-25),
    1.0 x Audio - Ethernet 10Base-T/100Base-TX - 9 pin D-Sub (DB-9),
    1.0 x Parallel - Generic - 4 pin USB Type A,
    1.0 x Serial - RS-232 - 6 pin mini-DIN (PS/2 style),
    1.0 x Storage,
  • Power Connectors 20-pin main power connector,
    4-pin ATX12V connector
  • as long as the PSU and motherboards power and lead connections are the same as the hard drive
    hope this helps
    May 10, 2011 | ASUS K8U-X Motherboard
    I would like to get wiring diagram so I can hook up usb
    The USB connectors are clearly marked on the motherboard.
    There should be an extra set of pins that are not used and you can plug in the USB connector there.
    The connector will have pins that look like this:
    ..... (1,2,3,4,5)
    .... (1,2,3,4)
    You don't use pin #5 on the top row.
    Pin #4 on each row is ground.
    VCC+ goes on pin #1 on each row.
    Jun 20, 2010 | MSI 848P Neo-V Motherboard
    I have problems with usb my usb have 10 pin and sales usb multi funcion usb by 9 pin..
    Not a problem. The 'missing' pin is used as an orientation key. that pin end of the connector is the ground side (shield on cable). Opposite end is the 5 volt supply for the USB device.
    Mar 16, 2010 | QDI Group QDI SynactiX 2EP Motherboard
    I have the same problem!!!
    Diagonally opposite to where you connect your mouse and keyboard, there will be pins for connecting front panel connectors. You can identify them by the names like SPK or Speaker written near them. You just have to match the front panel connectors with that of the pins. USB pins will be near these pins and will be labled as USB5 or USB4 on the motherboard. USB front panel connector can be inserted in only one direction.
    Aug 14, 2009 | IBM (49P1599) Motherboard
    Front panel connector J16 dell dimension 2350
    Visit select your product and download user manual and maintenance manual. It may solve your problem.
    Jul 15, 2009 | Motherboards
    Front panel connectors/jacks is not working
    OK--usually what you will find from the front is 3 connectors.
    One will be a solid block that has one blank hole which is the key. That will plug into the corresponding pins on the motherboard--usually toward the back of the case.
    There will be another other wire that terminates in two plastic connectors. These are the USB connectors. Sometimes the connectors are in two parts. One is a 3-hole and one is a 1-hole. Usually you will find two sets as they sort of go together.
    The pin configuration on the motherboard looks like this ::::.
    The single pin on the end is not used. The other ones are connected with the plastic connector on the first three starting at the left, with the end marked VCC to the left. The fourth pin is the ground which is usually the separate connector.
    The second USB connectors are plugged in right next to the first--so each block of pins controls 2 USB ports.
    Hope this helps.
    May 14, 2009 | ASUS Motherboards
    Need pinouts
    I have an old pc chips M575 motherboard that also uses the J3 ATX Form card. I can only assume the pinouts are the same so here they are from the manual.
    Pins 1-4 and 10- 13 are USB connectors
    Pin Description Pin Description
    1 +5v 10 +5v
    2 data- 11 data-
    3 data+ 12 data+
    4 ground 13 ground
    Pins 5-6 and 15-16 are PS/2 Mouse Connector
    Pin description
    5 +5v
    6 Mouse CLK
    15 Mouse Data
    16 ground
    Pins 7-9 and 17-18 are Infrared connector
    Pin description
    7 Ground
    8 Reserved
    9 +5v
    17 IR in
    18 IR out
    hope that helps
    Nov 18, 2008 | Pc Ware M748LMRT Motherboard
    USB problem
    please let me know what do u mean by one pin?
    Apr 09, 2008 | ASUS K8V-MX Motherboard
    ASUS P4V8X-X Motherboard Logo
    70 people viewed this question
    Top ASUS Motherboards Experts
    Brian Sullivan
    Brian Sullivan
    Sudeep Chatterjee
    Sudeep Chatterjee
    Are you an ASUS Motherboard Expert? Answer questions, earn points and help others
