Question about Kenmore 22642 Top Load Washer
I have a kenmore model 110.22642. My problem is when the tub is filled w/ water and is about to agitate it makes mostly a clicking noise and maybe a little of "grinding" sound near the bottom of the washer. It will not go any further in the cycle as it won't drain or do anything else. What do u think?
  • 5,911 Answers
If the washer will fill and drain, but won't agitate or spin, you may have a broken motor coupling. The noise of the motor engaging, lack of agitation and ability to still drain are the usual symptoms. This is a common fail item with this model washer through normal wear and tear. Newer versions of the coupler are more resilient and resist breaking. The following link explains how to replace one:
http://www.fixya.com/support/r385250-replacing_motor_coupling_kenmore_top
The motor coupling is located between the drive motor and the transmission and takes the place of a drive belt. They do wear out and can break. The replacement part number is included in the link I provided and is an improved upgraded coupling that is more resilient. It should last longer. If you have questions, or require additional assistance, please let me know. I hope this helps you.
A replacement coupler can be purchased on line at appliancepartspros.com for about $11. Just use the part number in the link and "Search by Part Number" for your search criteria.
Posted on Jul 07, 2009
3 Suggested Answers
SOURCE: Maytag MAV 9600 grinding noise/no agitation. Tub
I had a problem similar to this. There was a bobbie (?) pin stuck in the pump. Google how to take the front off and then disassemble the pump. (It will be on the bottom right side in the front of the machine). Pretty simple. Took about an hour and a half.
Posted on Feb 03, 2010
  • 942 Answers
SOURCE: 110 92282100 kenmore HD80 won t spin.
Either the motor is trying to run and can't or doesn't start or the motor is running but the belt broke and so it is not transferring any power.
You will need to take a look and see which is the case. If I could hear the sound it is making I could tell you the difference, but hey this is the internet so you will have to do it.
Once you determine the cause you can do a search for appliance parts and enter your model number, the site will then give you exploded diagrams of your machine and a list of parts to order from.
  • The noise could be cause by a broken or defective shock.
  • Worn drum bearings.
Posted on Mar 31, 2010
Washing Machine wont spin/agitate
The most common problem is the lid switch. with a screw driver in hand open the lid and press down on the lid switch. sometimes the mounting screws will crack the switch housing and the striker can't move the actuator far enough. I am interested in the clicking noise, as this could indicate a pump issue or a sock seizing up the tub.
Jun 14, 2009 | Kenmore 12502 Top Load Washer
Kenmore washing machine fills with water then stops
turn the motor to see if it moves it sound like the motor
May 02, 2009 | Kenmore 24032\24036 Top Load Washer
Broken Washer
it could be the direct drive coupling that connects the motor to the transmission. fill it up with water and see if it will agitate, if it will NOT agitate then it is a good chance that this is the problem. 0404472.jpg
worse case scenario is the transmission is bad, but this is unlikely.
Aug 04, 2008 | Kenmore 25862 Top Load Washer
Kenmore Elite Calypso washer won't fill with water!
i assume that the warer is turn on at the warer valves if so then do you have voltage at the water valve if not then water pressure switch could be bad or main control board could be bad
Apr 24, 2008 | Kenmore Elite HE4 Electric Dryer
Kenmore 22956 top loader quit running after agite cycle
If the timer cycles your lid switch is ok.
most likely: motor Switch (on Motor), condenser next to motor, motor itself, or wiring going from the time to the switch,
It is probably cost efficient to replace the unit rather than trowing parts at it .
AB
Apr 06, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore Elite King Size Top Load Washer
If your washer fills, agitates, drains, but will not spin, the likely cause is the gear case (transmission). A new gear case can run about $200 just for the part. With labor, this could be a bit expensive to repair. I hope this helps you some.
Jul 30, 2007 | Kenmore 22642 Top Load Washer
Kenmore 22642 Top Load Washer Logo
183 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
