1995 waveraider ra700. after pulling it from winter storage will not start.battery and relay fine. i put power directly to the starter and just a humming sound. how can u tell if its the starter or engine froze.should u be able to turn the shaft that comes out of the back of the engine without any difficulty?
Take the spark plugs out of the engine and try to spin the imrellar shaft it should spin fairly easy and yes jet ski motors will freeze and bust most shops tell u that u only have to blow them out this is not true u need to run rv antifreeze thrught the engine in cold temps but you may have a froze impellar bearing that will bind up your motor take your whole impellar assembly out and try to turn the motor and see what happens
