Plasma Display My Toshiba 42Hp86 model displays a whitish flase countour primarily around faces and bright backgrounds and I can see a ghost image of what looks like the service menu. What would the root cause of this be??
  • ihcscout Feb 06, 2008
    I have the same problem. The image is flickering and appears mostly in very bright areas, such as the light glare from a person's face. Mine is a 42HP16
Call 905 565 6595 Ontario, to get fixed ur tvs.
Posted on Jun 12, 2008
Vizio lcd flatpanel tv with dark background
If half screen is affected it will be either a board (LCD and Plasma have different names) but in those one board drives each side of the screen unit--worst case is the display panel itself which is fatal from a cost point of view.
May 25, 2012 | Vizio VT Televison & Video
Flashing screen on Toshiba 42HP66
Plasma sets use high voltage to produce their displays and it sounds very much like the HV supply is losing (or has lost) regulation likely due to the impending failure of a semiconductor.Check to see if Toshiba has any extended warranty on this since it could be a series problem.If there is none, ask for a price on a new or repaired supply on an exchange basis.
Dec 30, 2011 | Televison & Video
My toshiba has a burn in image that appears as red pixels what can i do to fix it it is a 42hp86 plasma
That's an image burned into the phosphor of the pixels and there's nothing that can cure it aside from replacing the entire panel.....
Oct 10, 2010 | Toshiba 50HP66 50 in. Plasma Television
No picture on dvd player but can hear sound
Usually this is a bad inverter. The best way to check this is to hold the unit up to a very bright light and see if there is a ghost of am image visible and moving, just not bright enough to be seen properly. This means that the display is working, but the flourescent display behind it is not being powered properly, and most LCD displays require a little inverter board to convert the native DC power to AC to light the backlight. inverter boards are cheap if you can find the proper one for your unit. Unfortunately some units have the inverter board integrated into the motherboard of the player, though that is rare. It should be a separate (and thus replacable) component. Good luck!
Dec 01, 2009 | Toshiba SD-P1400 Portable DVD Player
Laptop monitor comes on bright whitish color
may be the LCD display of the laptopisgone or ur VGA adapter has some issues
Jul 26, 2009 | HP Compaq Presario C700T Notebook
Poor picture (fuzzy ghost image/aura)
well you should check the settings and read menual
Jul 22, 2009 | Panasonic TC-P50G10 Plasma TV
Toshiba notbook tecra s1 model no 831l-1104l -- No Display
If you see a very dim image or black screen or flicking image on the LCD screen it means you have a backlight problem.
Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight.
Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out for parts, repair service and DIY info.
Mar 25, 2009 | Toshiba Tecra S1 Notebook
Green line on each side of the plasma display.
Anybody knows how to reapair about vertical color- stripped lines appeared on screens and some trace of greenish images exist after each images changing, my TV is Toshiba Plasma Color 42HP83, I appreciate , thanks
Jun 05, 2008 | Toshiba 42HP83 42 in. HD-Ready Plasma...
Televison & Video Logo
286 people viewed this question
Top Televison & Video Experts
