Question about Kenmore 13743 Staimless Steel Built-in Dishwasher
Dishwasher does not drain completely
Built in diplomat
  • 5 more comments
  • Gary List
    Gary List Feb 09, 2008
    dishwasher not draining
  • Anonymous Feb 22, 2008
    My dishwisher seem (sounds like its) running but at the end of the cycle, there is still water at the base. I also noticed a leak in he basement room just below the kitchen and directly under the dishwisher location. I attempted to disassemble the unit and still does the same after re-assembling it back. What could be causing this.......could it be a blocked pipe?
    Martin Phiri
  • Anonymous Mar 09, 2008
    My Bosch SHU43C02 (that's the model # on the door) does not drain completely. It will drain most of the way during the cycle--down to below the square filter usually (sometimes there's an inch of water in the bottom). I can then use the cancel/drain command, pushing two buttons, to get it to drain the rest of the way. It is still cleaning the dishes just fine. The water does move out of the dishwasher and into the disposal side of the sink, and down that drain when the dishwasher does empty.
  • Otto Max Mar 31, 2008
    I am having the same drainage problem. The dishwasher leaves murky water in the bottom of the unit. Help???
  • LEMEEZ May 27, 2008
  • Huskerwest Jul 05, 2008
    Same problem, the dishwashed will bot drain. What's the problem?
  • adiwener Aug 22, 2008
    dishwasher wont drain
The cycle was interrupted and now it will not drain completely. I cannot find the instruction manuel, and when I push the "clear/drain" button I hear the motor start but then when the light goes off the water is still in the bottom.
Posted on Sep 13, 2008
Modle diplomat aca 9102 dirty water does not drain from dishwasher
Dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. First make sure that the drain is not clogged and remove clogs if present. If no visible lint is present then remove the lower front access panel to check the drain filter and drain pump for any clogs, you'll need to clean the drain filter and drain pump completely. Also, check for any food pieces stuck near the pump impeller & clean the chopper assembly. Please note that dishwashers don't drain out the complete water such that heating element doesn't overheat. Hope this helps... Please post back for any further assistance.
Aug 08, 2011 | Dishwashers
Water won't drain, can't get to the drain to check if it's plugged?
Diplomat dishwasher not draining , have replaced drain pump but still not draining.
Dec 31, 2010 | Whirlpool 24 in. DU948PWPQ Built-in...
My dishwasher does not drain completely. There is
Here is a tip that I wrote that will help you with your dishwasher not draining problem...
Dishwasher2_bing.gif Problems - Water will not drain out
Jun 04, 2010 | GE 24 in. Profile PDW7800 Built-in...
Diplomat dishwasher bleeping showing FA
We have just experienced an FA audible error on our Diplomat ADP 8332 dishwasher...after pulling the dishwasher out and removing the low front panel we found the drip tray full of water. We tipped the dishwasher onto it's front and removed the drip tray and found a float pressure appears that once the drip tray is full the float switch activates and causes the FA fault (prevents the dishwasher from continuing) drain off your drip tray replace all covers and you should be good to go!!
Sep 16, 2009 | Dishwashers
Kenmore Elite Not Draining Water Completely
Check this link. Multiple causes are possible yet most is how drain is hooked up to disposal and back pressure built up. Hose must be installed correctly.
Jul 22, 2009 | Siemens 24 in. SE64A630GB Built-In...
Diplomat Dishwasher ADP8352 Will not complete wash Cycle
My Diplomat ADP8352 when running a cycle it will run for ages, doesn't seem to get hot. If i switch off the m/c then switch it on again it dumps the water left in the m/c?
any ideas?
Jan 04, 2009 | Hotpoint 18 in. DC28 Slim-Line Built-in...
Will not Complete a Wash Cycle
Please consider examine the control panel and the circuit of the machine maybe some connection setting is lessen.
Mar 18, 2008 | Dishwashers
Kenmore 13743 Staimless Steel Built-in Dishwasher Logo
878 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
