Question about TORK Variable Cycling Timer 8601
How to set the timer 1103
I live in a Condo and I am the new Janitor. Unfortunately there are no instructions to the Dial Timer we have. It is located outside the building. There is a dark black area which i believe is for nite time. then, there is a lite area which i believe is day time. The Tork Timer no. is 02-41 1103.Can you help Thanks I cannot figure out how to set the timer to go on and off, correctly
    President:
  • 1,723 Answers
Grasp the timer wheel and pull out toward you and rotate it to the correct time (line up time with the arrow). Now put the off and on actuators on the wheel at the on & off times that you want, that's it!
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Posted on Jun 27, 2009
How to set Hager timer EH 711 from 7pm to 11pm
Hagar EH711 is surface-mount analog timer with segments located around timer dial.
Timer has 2-position slide switch with I and O.
Timer has NO and NC wiring terminals, and I O switch reverses terminals.
Timer dial can be rotated by moving minute hand clockwise with finger
Open following link for instructions that illustrate how to set analog timers by experimenting with features.
http://waterheatertimer.org/How-to-set-timers.html
Open following link to see Hagar analog and digital timers with illustrations and manuals:
http://waterheatertimer.org/Hagar-timers-and-manuals.html#700-series
Take a moment and rate answer:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Sep 07, 2011 | Hardware & Accessories
An electrician installed a new Tork 1103 24 hr timer for the pool pump. You can only manually turn it on and off. When trying to set the time, the dial is loose and does not stay in position and does not...
I think you have 120Volt pool pump.
Add a comment if this is incorrect since wiring information is based on this assumption.
(1) Wiring problem:
Evidence shows timer is wired in reverse (dial only rotates when pump is ON, and dial stops rotating when pool pump is OFF)
Electrician reversed the wires, but wires need to be tested.
Hot wire from circuit breaker always connects to L
Neutral wire from breaker box connects to unmarked terminal.
This will give clock motor continuous power.
Next:
Black wire going to Load (pump) connects to X
White wire going to Load connects to unmarked terminal along with Neutral wire.
Tork 1103 is SPDT timer with 3 watt 120volt clock motor that can control multiple loads and voltages, and can be wired many different ways.
http://waterheatertimer.org/Tork-timers-and-manuals.html#1101
http://waterheatertimer.org/pdf/1103INSTALLOP.pdf
(2) Loose dial. The dial should only rotate counterclockwise when moved with hand. The fact that trippers work when rotated by hand says dial is probably not problem. If timer is used, and trippers skip over and do not turn on Load (pump) then order P47 replacement trippers.
http://waterheatertimer.org/images/Tork-1102-3-500.jpg
Aug 07, 2011 | Hardware & Accessories
I need instructions on how to set my Grasslin Intermatic FM1 STUZH 120 timer
Open following links for analog timer instructions:
http://waterheatertimer.org/Intermatic-trippers-and-parts.html#FM
FM1STUZH-120 is 120Volt 24 hour timer with manual override button.
Each tripper-or-pin on timer dial represents 15 minutes.
The timer can be set for several different purposes.
Since the timer has manual override and NO NC terminals, the best way to proceed is to wire your timer, turn power ON, move 10 trippers-or-pins outward, leave rest of pins inward, then manually rotate dial to watch when load turns on-off. Then move override switch to each of 3 positions and repeat same test.
These actions will reveal correct wiring and switch setting for your purpose.
Add a comment for more help.
Upvote the help.
Jun 05, 2011 | Intermatic FM1STUZH-120U - 24 Hour...
How do I set mywickes segment timer model WSEG3P
I have no record of WSE timer on file.
If you have a segment timer, meaning a timer with a dial that has segments located around dial, open following link for helpful images, and written tips and instructions
http://waterheatertimer.org/Woods-timers-and-manuals.html#troubleshoot
Add a comment for more free help.
Also take advantage of fixya expert assistance live.
Mar 10, 2011 | RTO Westek Daily Segment Timer, Butter
How do you set the timer
You posted under Woods outdoor timer:
See this timer and other similar types to identify your timer for sure
http://waterheatertimer.org/Woods-timers-and-manuals.html#2001
If this is not your timer, look at other timers on the page and then add a comment, and I will post instructions for another timer.
Generally this type of timer each set the same way:
Instructions:
Timer tuns ON automatically at dusk
Use dial to set 4 possible options:
Set dial to Off , the timer is always OFF
Set dial to ON, the timer is always ON
Set dial to Dusk-Dawn, the timer is ON at dusk, OFF at dawn
Set dial to 2,4,6,8 hours, the timer is ON at dusk, lights OFF 2,4,6,8 hours later
You can also take advantage of fixya phone support.
Fixya expert will walk you through the steps for a price.
Dec 23, 2010 | Woods Outdoor Lighting Timer
CANNOT FIGURE OUT HOW TO SET THIS. OUR JANITOR WHO USED TO DO THIS FOR US RETIRED.
You have a 59200 plug-in timer.
Following link shows timer, timer manual, and written instructions.
http://waterheatertimer.org/Woods-timers-and-manuals.html#59203
If this is not your timer, add a comment and describe the timer.
I have extensive files on timers.
Timer has segments located around dial.
Lift segments up or push segments down to set on-off times
To set current time, rotate dial until current time lines up with arrowhead located on inner dial
Dec 16, 2010 | Woods 59200 Lamp and Appliance Timer with...
We need clear instructions for setting the timer
Woods makes several outdoor timers:
Image that shows with this post is Woods model #49647.
Below are instructions for #49647 timer.
If your timer is different, add a comment with model number and I'll post instructions for that timer.
Woods model #49647 is outdoor timer with photoelectric control that turns timer ON at dusk.
There are 4 possible settings that show on dial.
Rotate dial to make timer selection.
OFF = timer is OFF full-time until you change dial.
ON = timer is ON full-time until you change dial.
Dusk-Dawn = timer turns ON at dusk and OFF at dawn
2, 4, 6, 8 hours = timer turns ON at dusk, and turns OFF 2, 4, 6, or 8 hours later.
Nov 26, 2010 | Woods Outdoor Lighting Timer
My Tork 1103 timer is used at my office building to set the lights outside for security. My maintence person sets them, then all of a sudden they are wacky and come on at the wrong time. I would like to...
This is probably very similar to your timer.
The Tork 1100 series is electro-mechanical timer.
Lift and rotate dial to set current time.
Line up current time with the word Time located to lower right of dial.
The trippers are black and silver.
I think the black is OFF and silver is ON
Clock motor rotates dial as time passes.
Trippers contact a lever.
Off tripper pushes lever one way.
On tripper pushes lever other way.
The manual override clicks back and forth as trippers move lever.
To check function of timer, click manual override
Common problems:
1) Clock motor is not rotating dial
2) Trippers get stuck on lever and can't move lever because timer is dirty or worn out, or clock motor is bad.
3) Trippers are worn down and won't trip the lever.
Replacement of these timers is simple
Check out the functions and problems and then answer this post and I will help more if needed
Oct 21, 2010 | TORK Hardware & Accessories
Want to know how to set the timer intermatic
Following page has instructions and troubleshoot you might find valuable. Including photo of tripper installation.
http://waterheatertimer.org/Malibu-power-pack-stopped-working.html
To set ML series power pack that has analog dial, place trippers on dial at times you want timer to turn on-off. Dial has hours showing with dark background for nighttime. To set current time, rotate dial clockwise two revolutions and then line up current time with arrowhead located on inner dial. Manual override switch is round knob located upper left of dial.
Upvote the help.
Aug 06, 2010 | Intermatic & Malibu& 300 Watt Power/Pack...
I don't know how to set the timer to come on a 7 pm, off at 11 pm. It is a tork 1103 electromechanical timer. Directions lost years ago and new homeowners (myself) do not know how to set the timer. Anne
See T1100 Tork timer on following link:
To set this timer, rotate clock dial clockwise until current time lines up with the word 'TIME' located at 5 o'clock position.
Place black and gold P47 trippers at times you want timer to turn on-and-off.
As time passes, the dial rotates. ON tripper flips a lever that turns Load ON, and then later, the OFF tripper flips same lever and turns Load OFF.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on timer or any do-it-yourself project.
Jun 06, 2009 | TORK Digital Interval Timer Ssa100r-24
TORK  Variable Cycling Timer 8601 Logo
281 people viewed this question
Top TORK Hardware & Accessories Experts
Craig Butler
Craig Butler
Andrew Taylor
Andrew Taylor
pawnpower
Are you a TORK Hardware and Accessory Expert? Answer questions, earn points and help others
