Question about Sub-Zero 601R
601R sub zero vacuum condenser notice
My 601R sub zero refrigerator has the notice vacuum condenser on. I did this but the notice came back within a day. I am also have condensation/freezing on the upper back panel of the unit. now what?
    Problem Solver:
  • 3 Answers
Your problem might be serious enough to warrant a repairman's visit. But this was my experience: An official Sub Zero repair company in NYC told me this: If the "vacumm condenser" light keeps flashing after you've opened and cleaned the condenser grill, then either pull out the plug for the Sub Zero refrigerator or turn off the circuit breaker (or fuse) in your house that leads to it, wait for some minutes and then turn back on. It is NOT enough to turn off the unit using its own internal on-off switch - it has to be totally disconnected from the AC. I did so, waited 15 minutes, turned back on, and it worked!! I had vacuumed the condenser grill twice but the "vacuum condenser" light kept flashing AND the refrig would go bonkers if set below 38. Now the flashing warning is off and it's down to 35. Great !!!
Posted on Oct 30, 2011
  • Sub-Zero Master
  • 4,655 Answers
The repair clinic is about the only people I know that can answer that one for you. http://www.repairclinic.com/Appliance-Parts?s=t-601R-%3d%3dc221
Posted on Jun 27, 2009
Sub-zero refrigerator on but not cooling
thats right, if compressor running you most likely have to go thru this repair.
Jul 21, 2014 | Sub-Zero 601R
How do I reset my Sub Zero 601R refridge so the vacuum seal comes on?
wow never heard of a vacuum sealing door on a fridge. all I ever knew of are magnetic ones and I find no mention of this feature searching .
Jun 23, 2014 | Sub-Zero 601R
Refrigerator is getting warm
Def. needs freon if condenser coil is clean.
Sep 14, 2017 | Sub-Zero 601R
Have a sub-zero 601F about 10 years old and the 'vacuum condensor' light is flashing whenyou open the door in the same box as the temperature.
You should first vacuum condenser coil on top (looks like radiator coil in the car), then try to reset it by turning it off and back on. Otherwise it indicates that it's running too much and most likely it's not getting cold enough.
Sub-zero repair in Orange County, CA
Jan 23, 2010 | Sub-Zero 601R
Subzero--Vacuum Condenser Signal Won't Turn Off
The vacuum condenser indicator keeps flashing on and off. I did vacuum the unit, the the indicator lights keeps flashing on and off. How can I reset it and keep it off?
Thanks,
Rob
Aug 22, 2009 | Sub-Zero 650 / O Bottom Freezer...
Vacuum condenser appeared however there are no visible problems
You have to ID the fault code....down load on the net...
Aug 18, 2009 | Sub-Zero 601R
Sub-Zero 601R Electrical
have you checked the main power button on top of the unit, behind the grill?
Jan 02, 2009 | Sub-Zero 601R
The fridge shows vaccum condenser?
It is just a message advising you to clean the condenser behind the top access panel. Basically an "idiot light" kind of thing although it should be cleaned about once a year
Dec 20, 2008 | Sub-Zero 601R
Sub-zero 601 fridge won't get below 42 degrees
You both sound like you need a qualified factory repairman out there. If there is a blockk of ice on the back wall you have a low charge in the refrigerant system. It is most likely the evaporator or cooling element as you call it which has a five year parts and labor warranty, then parts only for years 6-12. Here is the link to the factory locator site. http://www.subzero.com/locator/locator.aspx?type=0&zip=02030 or call 800-222-7820.
Nov 24, 2008 | Sub-Zero 601R
Refrigerators Logo
1,149 people viewed this question
Top Sub-Zero Refrigerators Experts
Charles T Nevin
Charles T Nevin
Sal De
John Tripp
John Tripp
Are you a Sub-Zero Refrigerator Expert? Answer questions, earn points and help others
