Question about Nikon D80 Digital Camera
Broken sd door d80. Where do I get the part in the UK?
  • 4,806 Answers
Reputable service center in the UK here >>>>>>>>>
http://www.fixationuk.com/Fixation/Fixation%20-%20Home/Fixation%20-%20Home.html
Good luck
Posted on Jun 27, 2009
Upgrade firmware for Nikon D80
Confirming the firmware version:
  1. Turn on the D80
  2. Press the MENU button and select Firmware Version from the setup menu. The camera's firmware version will be displayed.
  3. Turn off the D80
Basic Upgrade instructions: for detailed instructions, see pdf files below.
  1. Download and expand the firmware files
  2. Format an approved SD (Secure Digital) memory card in the camera
  3. Connect Camera to computer (in MSC USB mode) or use a SD Card Reader
  4. Copy to the top level of the card the downloaded "A firmware" file
  5. Disconnect camera from computer
  6. Update the firmware from the "Setup" menu
  7. Follow the camera's on-screen menus
  8. Repeat steps 2 through 7 using the "B Firmware"
  9. Re-format Card
D80 1 11 firmware upgrade Nikon Knowledgebase
Apr 03, 2014 | Nikon Cameras
My computer is not reading the memory card. Nikon D80
If you are using a 4GB or higher SD card, some computers cannot read it directly from their in-built SD reader. Buy an external card reader and plug it in. Your computer should now be able to read cards 4GB and larger
Oct 07, 2009 | Nikon D80 Digital Camera with 18-135mm...
When i connect my d80 to my pc it freezes
You can try to a SD card adapter for the USB slot and download without the camera. The adapter is pretty cheap and sometimes comes with the SD Card.
The PC reads the camera as an external drive, make sure your PC and OS is up to date.
Aug 16, 2009 | Nikon D80 Digital Camera with 18-135mm...
I have a Nikon D80. A few months ago, the SD card would not stay in the slot, then for no reason it started working normally agan. Now it won't stay in again. It doesn't catch when you push it in, it just...
the sd card slot is designed in such a way that when you push your card inside the slot till the deepest part and when yout leave it, it fits into the slot. if you want to take the card out you have to push the card again till the deep and leave to get it out.(just like a spring aided trap). i dont think that your slot is damaged.may be you are unsure how to insert the card in the slot. if you still find problems, please write back.
Jul 21, 2009 | Nikon D80 Digital Camera
Getting (CHR)error message on my D80
Your SD card may be "locked." Check the SD cards slider lock and make sure it's set to allow you to write to the card.
Apr 14, 2009 | Nikon D80 Digital Camera with 18-135mm...
Nikon D80 no picture number in LED & menu not working
Format the SD cards with the camera. You might have to do a software upgrade on the camera since the Kodak card files are different than Nikons.
Mar 29, 2017 | Nikon D80 Digital Camera with 18-135mm...
Nikon D80 SD Card slot problem
Is it slightly thicker on the contact end, Or is something stuck on the flat corner? try getting a needle and picking out any plastic that could be stuck there. Is the card under warranty
Sep 09, 2008 | Nikon D80 Digital Camera with 18-135mm...
Nikon D80 Exposure Count
My camera is now fixed. It was a tiny speck of dirt on the sensors between the mounting of the lense & the camera. The uy that fixed it said it is a problem with the camera because they are so sensitive.
Jan 13, 2008 | Nikon D80 Digital Camera with 18-135mm...
Nikon D80 Digital Camera Logo
60 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
